@mike did you replace the drivers on your switches with the native one? Did you factory reset them and re-pair them or simply change the driver in the drop down?
Yes. I'm pretty sure Mike Maxwell said it was necessary, especially for the double and triple gangs, to get the multi endpoints.
I still use the community driver.
I have issues with the built in one
Is support helping you? What are the issues?
This was my support thread about it. Based on the above, I just use the community driver.
Calling it an outlet irked me and the community driver works fine.
When I re-join it, it doesn't see it as a nue so it calls it a generic zigbee outlet and I only get to control 1 switch on a 2 gang plate. Any tips?
The Nue zigbee switch is the closest thing I can find to an array of panel-mounted indicator lights. Descriptions say "Smart Touch Switch with LED indicator OFF (Blue, can be turned off) and ON (Red)"
On a multi-gang switch, does each switch's red indicator light toggle off & on?
https://www.amazon.com.au/Approved-Wireless-Automation-Lighting-Control/dp/B078LVQ8XC"
Change it manually to the Nue, and hit configure.
