NOUS humidity and temp sensor
Hi,
I bought NOUS Zigbee: Outlet and Hum/Temp sensor.
Hubitat is not integrating them automatically. Outlet has been integrated after adding the drivers for Tuya Metering Plug drivers from @kkossev
I downloaded Tuya Temp Humidity sensor as well from @kkossev but during pairing Hubi took also the drivers for the plug.
I'm new in Hubitating - is there a way to show to Hubitat which drivers it should try to integrate. Or it chooses the most fitting once?
Attached the screen of my drivers and here is the link to the sensor I bought:
Or any idea for the drivers which could match?
Thanks for answer in advance.
You can change the driver to use (or attempt to use) on the Devices page for the driver - see the Type dropdown widget.
There are lot of posts about tuya devices that don't work - I bought a eMylo Temp/Humidity last week and it does not work after pairing. It joins another non working Tuya based device. Further down that page is the 'fingerprint' data that hubitat uses to figure out what driver to try initially.
Screenshot from 2024-05-12 17-57-49
Sometimes, the same device is made by another manufacturer, or use newer electronics - in such cases it will not be recognised automatically by the driver that worked with the old manufacturer.
Please show the sensor Model and Manufacturer data as in the example above , then we will know what the case is.
For my reference : (link)
Hello,
Sorry for such a long delay - out of home by now.
I can find such settings:
Update the driver to the latest dev.branch version 1.5.2 2024/05/14 7:25 PM :
https://raw.githubusercontent.com/kkossev/Hubitat/development/Drivers/Tuya%20Temperature%20Humidity%20Illuminance%20LCD%20Display%20with%20a%20Clock/Tuya_Temperature_Humidity_Illuminance_LCD_Display_with_a_Clock.groovy
Then pair the sensor again to your hub.
It may be the same case - a new manufacturer of a device that is already supported, and what needs to be done is to add the new device fingerprint to the correct device profile in the custom driver.
If you still keep it - please post this device fingerprint.
Hi
Thank you for reply.
Unfortunately no match.
It takes automatically the drivers from the metering plug.
After I change the "Type*" for drivers of humidity sensor the available settings don't change.
Here are screens what I see:
Piotr
OK, will follow up later this evening.
Seems like you are still using an old driver version please check whether you have updated to the latest one from the link above
OK - thanks.
And what I did as well.
Because I"m new and I have only two devices: Metering Plug and Temp/Hum Sensor from Nous I cleaned all the drivers added and removed all devices.
Started pairing the Sensor on clean Hubi and is such reality it's not finding the Sensor at all.
Maybe it can be kind of hint as well.
Have a nice day.
Piotr
... to clarify: I uploaded only the driver you sent me the link from GitHub and then start pairing. Hubi didn't see the device.
Hello,
I found over internet.
Seems working - testing it
First conclusions:
  1. The device is reporting status every 3 minutes
  2. It's not reporting "on event" like the programmed parameter increase/decrease
I have programmed events:
  • humidity change 1%
  • temp change 0,2
Anyone was able to program it for parameter change reporting? It's really not working or I do something incorrectly?
Piotr
Hi Piotr,
This new manufacturer of the NOUS E6 was in the wrong device group, also the inClusters fingerprint was wrong in the previous version (thank you for the fingerprint!)
I have corrected these issues in version 1.6.0 2024/05/19 9:42 PM. Please update again the driver and click on the Initialize button. Then press F5 in the browser to refresh the web page.
Check whether the near-real-time updates of the T&H are working. Have in mind, that some devices have an internal refresh limit, which may be higher than 10 seconds between the updates. For this device, it may be 30 or 60 seconds. Every device is different.
