I have been getting 3 text messages per event/action, when I only should be getting 1 message. This is currently happening in the Notification App, but it also happens in Rule Machine. Any ideas on why this is happening?
What's more likely: are you sure the contact sensor isn't sending multiple "opened" or "closed" events? Check your live logs as you open (or close) it and see what happens (assuming you have descriptionText logging enabled for this device on a standard driver or the equivalent on a custom driver; or in any case you can probably check the "Events" tab on the device page for history). For example, users of a certain other platform have noticed the Ecolink contact sensor sends duplicate events: Ecolink Z-Wave plus *ALMOST* always throws duplicate messages - Devices & Integrations - SmartThings Community. A revered Hubitat user and Z-Wave expert has found a way to eliminate one of these (porting the ST driver and removing some code, the closest we can get without the Hubitat driver being open source or them having a separate driver for devices like these): Aeotec Siren 6 is FINALLY here (I know, the thread title sounds unrelated, but...).
That being said, I'm not sure where the third event would be coming from since these are normally just two, but in any case, seeing what the device is actually doing would be a good first step. It's quite likely the Notifications app is just blindly sending one each time this happens. Regardless of the cause, you can probably work around this in Notifications by utilizing the option to only send once every x minutes or similar, and in RM you can work around it by setting the rule's private boolean and un-doing it after your desired period of time (a few seconds?) if there are no further "open"s.
Thanks ... I did most of the testing with just the Pixel 3XL being the notification and it was still sending multiple notifications, although just 2 vs. 3 messages. I'm going to change it back to just the Pixel 3XL for testing (and no text messaging). Also, my understanding is we're limited to 10 text message per day, right?
Thank you for the insight ... I didn't have logging setup on the device, but I do now. So I'll do some testing and see what happens. I'll also try your suggestions of extending the minutes in the Notifications App and trying RM again.
@bertabcd1234, I've been testing different methods, including variants of Notifications, Hubitat Safety Monitor and Rule Machine 4.0. All of the tests normally now yield 2 notifications. This is also shown in the logs.
I'm beginning to think, as you said, that the sensor is sending 2 duplicate events. Therefore, is there a way to find, or create, a specific device driver for the Aeotec Door/Window Sensor 6? I'm currently using the Generic Z-Wave Contact Sensor.
I've also attempted to use the private boolean, as you suggested. Although, I really am a novice and haven't been able to figure out how to set the rule's private boolean and un-doing it after a desired period of time.
Update ... I modified the Existing SmartThings driver, by replacing "physicalgraph" with "hubitat". It works, but still gives 2 alerts per event.
So, I've now tried 3 different drivers; the "Generic Z-Wave Contact Sensor", the "Generic Z-Wave Water Sensor" and now the new "Aeon Water Sensor" I just created. Does that mean it's not the Driver causing the duplicate alerts?
But did you make the modifications krlaframboise suggested in the other thread? (I think that was for a different type of device, so you'd have to figure out what the equivalent is here, and this is assuming it's the same cause, but it's likely reporting the event multiple times via different Z-Wave command classes.)
Staff stated in the last Hubitat Live episode that they would look into this behavior, but I think they were only aware of it for the Ecolinks. If the same issue fixes it for you with the Aeon, they may want to know about that too (assuming it's a contact sensor).
@bertabcd1234 ... I read through that thread before, but really didn't understand much, since I'm such a newbie. Although, now I'm a little more familiar with the code, so hopefully I'll be able to make the modifications. Thanks.
That's great ... here's the log. I opened the sensor (put it in the water), waited 10 seconds, then closed the sensor (took it out of the water). Thanks!
This is the first log I did and it seemed to have it backward. As in Dry first, then wet.
It's creating 2 water events so receiving 2 text messages makes sense, but not 3... It looks like the notification app is also throwing an exception so maybe that has something to do with it, but I thought that error was fixed in update 2.1.2.
The Ecolink device sends a Notification Report and a Basic Report every time the contact changes so all you had to do to fix the problem for that device was prevent one of those reports from creating the event by commenting out some code.
Your device is sending 2 of the same type of report so there really isn't a simple solution, but using runIn to delay the creation of the water event by 1 second might solve the problem.
When runIn is used to schedule a method Hubitat should overwrite any existing schedules for that method which would eliminate the duplicate, but since the method would be scheduled twice within 20ms I'm not sure if the overwrite feature will work as expected.
You should have a block of code that starts with the following and ends with }:
If that doesn't work, another possible solution is to ignore one of the reports based on the isMulticast value since one is true and the other is false, but if that behavior changes at some point it could end up ignoring both reports so it's probably not worth risking.
The device might also have some association group related settings that could solve the problem, but I don't have time to look into that.
