On your way past your hue bridge, stop and give it a little peck on the cheek. I think that's why you have no troubles. They're not directly connected to your HE hub. An angel on your shoulder, per se.
[EDIT]
I still have ten up for grabs.
Hah! I actually want to replace it with a second HE eventually, but yes, it's been an angel. I def woulda bought your Crees a couple years ago, but I'm fully bulbed out over here.
That's a new one. I'm going to file this next to "booblights" in my dictionary!
@adamkempenich
Should've bought it when it is $69.95 yesterday!
What!
Be sure you state that when telling someone how stable things are for you with Cree bulbs. Of course you have stability. Just like me, your bulbs are in a completely separate Zigbee network. Of course they donât interfere with the devices on the HE Zigbee network!
I still have 10 bulbs up for grabs.
Ok, so now we should be back to @Kevin.tosca problem. Wondering if you can post a bit more of your configuration and update the status. Sorry for getting so far off topic on you.
Sorry, but you are far too late. I had one of those four-flow bulbs and I really liked them (before I knew better), but then for whatever reason, they stopped selling them in Canada. I still had it in use for a long time, but then one day I decided I couldnât stand the crappy color of the one TRĂ DFRI color bulb I had (I just like a splash. Not that into color bulbs). So I replaced it with a Hue full spectrum bulb and decided I would use the TRĂ DFRI in place of the Cree. What a difference it made to those late night trips to the bathroom, because I could make the TRĂ DFRI turn burnt orange late at night and early in the morning. Whereas with the Cree, it was still really bright, even a 1%. I also realized that even the cheap TRĂ DFRI had a bit of fade before off, whereas the Cree didnât.
So i should delete them from Hubitat hub and pair in the hue hub ?
Also whatâs up with the dashboard? It sucks. Canât control anything and it doesnât update status?!
Why canât I log in locally instead of the dashboard
Wow! Just plain WOW!
I highly recommend that. Use the Hue integration app to control the lights from Hubitat.
I donât know what you mean exactly. The Dashboard works, but obviously isnât working on your end for some reason. I suggest you get the lights in Hue, always test from the device driver first to see if itâs all working as expected, and then letâs circle back to control from the Dashboard.
It is difficult to change the mind of one that has already formed an opinion...
