@jrau272 I've been having the same issue as you with the applestrudel nodes. Bare metal
@aaiyar What counter node are you using? Thanks for sharing your auto-init flow.
Well be sure to report back if possible! Would be a good thing to know..
I just started using the cron node and here's an example of a single node with multiple events. Each output is a different time event.
In addition, each output can have a different payload, which can also be really useful.
And you have the ability to dynamically generate/remove schedules by passing in specially formatted messages as well... very nifty.
Is it possible to have node name span multiple lines rather than just getting wider? I did some searches but no luck.
I'm still trying to wrap my head around your advanced toggle
My stuffs not that sophisticated yet.
It sure is! just put ā \n ā to create a new line. (without the quotes)
I wouldn't worry about it too much - I have a bad habit of over-engineering things. Had not really intended to share that subflow because it might be overly confusing / is a scary window into my inner madness.
But OTOH it's a good example of what you can do with subflows.
Looks like Iām not alone. I found this thread on the github page for cakebake:
looks like people are doing a manual init to try and fix.
Doh! Should've known it would be that simple.
I did take your simple on/off toggle and modified it for a simple open/close.
I am into subflows in a big way. The main reason I am doing simple stuff like toggles etc is so I can make my sequence behavior more predictable and easily modifiable/fixable across all flows.
Yes, I knew about that. That was when I wrote my init sequence. It has failed on very rare occasions - I can't remember the last time it didn't work. But it has happened a couple times over the last 2 years.
So my production version of the sequence uses a crontab node as trigger and also a virtual switch as trigger.
Ha - just checked my Hubitat logs. The last time that virtual switch was triggered was on 11-30-2021. And 6-12-2021 before that.
Is the virtual switch just for you to trigger manually or is it automated somehow?
Virtual (auto-off) switch that is exposed to Alexa. So on the rare occasion TTS doesn't work, I can tell Alexa to "turn virtual switch on".
Is this required or is simply a check that msg.payload.deviceSerial is not empty good enough?
I never tried that. Definitely try it first!
empty doesn't work. I didn't read @aaiyar instructions completely and left mine blank and the flow failed to attempt initialization. Instead it acted like it had run through the 4 attempts and dumped out at the 5th. I stared at the logic for about 2 hours before going back and re-reading his post.
Since I tied my failure notification into the Alexa skill NotifyME I had an notification from her at 2am
