Node-Red Palette: Common Choices
Not sure what to say... There is literally 1 directory that needs to be specified when running node-red in a docker container.
docker run -it -p 1880:1880 -v node_red_data:/data --name mynodered nodered/node-red
-v "host machine directory to store the stuff that needs to persist":/data
e.g.
-v /home/pi/my-node-red-files:/data
From the node-red install instructions:
    docker run              - run this container, initially building locally if necessary
    -it                     - attach a terminal session so we can see what is going on
    -p 1880:1880            - connect local port 1880 to the exposed internal port 1880
    -v node_red_data:/data  - mount a docker named volume called `node_red_data` to the container /data directory so any changes made to flows are persisted
    --name mynodered        - give this machine a friendly local name
    nodered/node-red        - the image to base it on - currently Node-RED v1.2.0
I will say that some of the confusion may be from their choice of wording in the instructions "named volume". You can use a named volume, but you can also just use a host path.
I'm an ubuntu guy, but when I install I do this - pretty much all taken from the install guide:
  • Install docker
sudo apt-get update
sudo apt-get install \
    ca-certificates \
    curl \
    gnupg \
    lsb-release
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
echo \
"deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \
  $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io
  • Add current user to the docker group so that the current user has rights to docker:
sudo usermod -aG docker $USER
  • Make directory to store node-red data:
mkdir /home/user/node-red-data
  • reboot
  • run the container
docker run -d --restart unless-stopped -p 1880:1880 -v /home/user/node-red-data:/data --name mynodered nodered/node-red
I just did it with those steps < 3 minutes after the OS was installed had node-red running.
