Included in Raspbian for some time. Use it.
This is a good way to do it too, over the network. Works in Windows WSL, too.
You would have to use a template node. I'm not great at those, though. Maybe someone else will chime in...
More dashboard stuff.
Result: (balcony door not opened yet, since I did the colors) Blue = closed, Red = Open
Visual:
Code: (shove a HE contact sensor in front of each of the flows). I have not copied my contact sensors.
[{"id":"64190c5c.0aa904","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":680,"wires":[["d461e68.dfe5918"]]},{"id":"aa54a7b1.f67308","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":980,"wires":[["754c3a87.e2ae44"]]},{"id":"3a3b75d3.40f5aa","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":860,"wires":[["1b283887.db2117"]]},{"id":"593c7979.70e598","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":740,"wires":[["721920a6.38df6"]]},{"id":"e770577f.5cae68","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":920,"wires":[["2dcfe43a.2dd95c"]]},{"id":"76ebefab.ea4c6","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":1060,"wires":[["247fe4fa.d3ac4c"]]},{"id":"57d146d3.e68828","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":800,"wires":[["2a4a10aa.ffd9a"]]},{"id":"95ff292c.e10608","type":"change","z":"ec8abfc3.b90c4","name":"unwrap payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":1120,"wires":[["d78dab9.88dfc58"]]},{"id":"4c6bcf1e.c346b","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":4,"width":3,"height":1,"name":"4. Front Screen","label":"<font color= {{msg.color}} ><b>Front Screen</b></font>","format":"","layout":"row-center","x":1620,"y":860,"wires":[]},{"id":"539fcf54.2f3be","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":7,"width":3,"height":1,"name":"8.Balcony","label":"<font color= {{msg.color}} ><b>Balcony</b></font>","format":"","layout":"row-center","x":1600,"y":1120,"wires":[]},{"id":"1847aa10.4f03a6","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":2,"width":3,"height":1,"name":"2. Front","label":"<font color= {{msg.color}} ><b>Front</b></font>","format":"","layout":"row-center","x":1600,"y":740,"wires":[]},{"id":"52b55033.876bb","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":5,"width":3,"height":1,"name":"5. Laundry","label":"<font color= {{msg.color}} ><b>Laundry</b></font>","format":"","layout":"row-center","x":1610,"y":920,"wires":[]},{"id":"7a105462.4b060c","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":3,"width":3,"height":1,"name":"6. Under Stairs","label":"<font color= {{msg.color}} ><b>Under Stairs</b></font>","format":"","layout":"row-center","x":1620,"y":980,"wires":[]},{"id":"598f06e2.fa9ee8","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":1,"width":3,"height":1,"name":"1. Garage","label":"<font color= {{msg.color}}><b>Garage</b></font>","format":"","layout":"col-center","x":1600,"y":680,"wires":[]},{"id":"4c87a8de.e54f58","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":6,"width":3,"height":1,"name":"7. Garage Side","label":"<font color= {{msg.color}} ><b>Garage Side</b></font>","format":"","layout":"row-center","x":1620,"y":1060,"wires":[]},{"id":"133ac60d.518a7a","type":"ui_text","z":"ec8abfc3.b90c4","group":"fb26db16.195408","order":3,"width":3,"height":1,"name":"3. Back","label":"<font color= {{msg.color}} ><b>Back</b></font>","format":"","layout":"row-center","x":1600,"y":800,"wires":[]},{"id":"d461e68.dfe5918","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":680,"wires":[["598f06e2.fa9ee8"]]},{"id":"721920a6.38df6","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":740,"wires":[["1847aa10.4f03a6"]]},{"id":"2a4a10aa.ffd9a","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":800,"wires":[["133ac60d.518a7a"]]},{"id":"1b283887.db2117","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":860,"wires":[["4c6bcf1e.c346b"]]},{"id":"2dcfe43a.2dd95c","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":920,"wires":[["52b55033.876bb"]]},{"id":"754c3a87.e2ae44","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":980,"wires":[["7a105462.4b060c"]]},{"id":"247fe4fa.d3ac4c","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":1060,"wires":[["4c87a8de.e54f58"]]},{"id":"d78dab9.88dfc58","type":"function","z":"ec8abfc3.b90c4","name":"Set Color","func":"if (msg.payload == \"closed\" ) {\n msg.color = 'DodgerBlue';\n}\nelse {\n msg.color = 'Red'\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1440,"y":1120,"wires":[["539fcf54.2f3be"]]},{"id":"fb26db16.195408","type":"ui_group","z":"","name":"Doors","tab":"1895180c.da6e38","order":1,"disp":true,"width":3,"collapse":true},{"id":"1895180c.da6e38","type":"ui_tab","z":"","name":"Mike","icon":"dashboard","disabled":false,"hidden":false}]
We (and by we I mean one of you guys smarter than me) need to figure out a way to show pieces of a Node Red Dashboard on a HE dashboard. Then you could have some of the charting like I posted earlier and what @mike just posted show up within the HE Dashboard shell. I know its easy to create a link but that's just not the same if I have to make an extra click.
Just changed it to behave the same way....
I'm telling you...
This new revelation (on my part) on how the device node works changes how I do quite a number of things.
I've been doing some tests redoing (really undoing) some of the traps I put in my nodes to ensure no 'duplicate hubitat maker api messages', and it is really cleaning things up nicely!
Well, there is a way. Here is my hack....
I have the following customer driver:
preferences {
input("src", "text", title: "iFrame Url", required: true)
input ( name: 'pollInterval', type: 'enum', title: 'Update interval (in seconds)', options: ['10', '30', '60', '300'], required: true, displayDuringSetup: true, defaultValue: "60" )
metadata {
definition (name: "iFrame Tile", namespace: "srp", author: "srp") {
capability "Switch"
capability "Initialize"
attribute "myFrame", "text"
def on() {
sendEvent(name: "switch", value: "on")
sendEvent(name: "myFrame", value: "<iframe src='${src}' width='500' height='300' frameborder='0'></iframe>")
def off() {
sendEvent(name: "switch", value: "off")
def installed() {
initialize()
def initialize() {
updated()
def updated() {
configure()
def configure() {
unschedule()
def pollInt = settings["pollInterval"]?.toInteger()
// If change polling options in UI, may need to modify some of these cases:
switch (pollInt ?: 0) {
case 0:
break
case 1..59:
schedule("${Math.round(Math.random() * pollInt)}/${pollInt} * * ? * * *", "on")
break
case 60..259:
runEvery1Minute("on")
break
case 300..1800:
runEvery5Minutes("on")
break
default:
runEvery1Hour("on")
on()
In this driver, I can set a URL as source.
I hardcoded the width and height for my application, but you can change that in the code line here:
just change the width and height
Then, on my dashboard, I have a tile that shows the attribute "myFrame".
It's not elegant but it works....
I am with you. My head is ... Going through my flows myself right now...
@dan.t just proved my point. Thank you.
I don't consider myself smart. I am lazy.... I will do anything for making my life easier... That's how I got hooked on home automation.....
Lol...this exactly. Lazy breeds ingenuity. That's my motto.
Thanks for the iFrame driver! That works great. I am not asking you to do it but I could modify your driver so that the width and height is in the preferences correct? Then, instead of having multiple device drivers with a device corresponding to each, I could have one device driver and a device corresponding to each size I want correct?
Hi @mike, so how can I show temperature of few devices on dashboard? Which palette should I use?
You asked me by not asking me?????
Here you go:
preferences {
input("width", "number", title: "iFrame width in pixel", required: true, default: 500)
input("height", "number", title: "iFrame height in pixel", required: true, default: 300)
metadata {
capability "Switch"
def on() {
sendEvent(name: "myFrame", value: "<iframe src='${src}' width='${width}' height='${height}' frameborder='0'></iframe>")
def off() {
def installed() {
initialize()
def initialize() {
updated()
def updated() {
configure()
def configure() {
unschedule()
case 0:
break
case 1..59:
break
case 60..259:
break
case 300..1800:
break
default:
runEvery1Hour("on")
on()
NO!!! I am seriously going to figure this out. I am not looking!!!!
I modified your driver to make the tile 1000x1400 to accommodate my temperature chart so when i first created a device, the Current State myFrame was so big it pushed everything so far over you couldn't enter anything in the device page. Oops.
EDIT: I promise I didn't look first.
One of these days I am going to break down and try to learn Groovy.
Worst feeling in the world, you plug in the power and that activity light just never turns green. I had this happen not too long ago due to power failure. Had to totally rebuild my RPi that ran my DIYHue bridge, my Assistant Relay Server, my Cast-Web-API server, my Email/Text server, my Motiioneye Server, and my VPN server. It was WEEKS before i had everything rebuilt. I will definitely be picking up on of these!
I have to take some time to make an image backup again. But it takes like 2 hours to do it and I lose all that other stuff while it's running. lol
Yeah, it definitely stinks!
Where I don't use rpi-clone, I manually back up over the network... Pretty easy to do from Windows WSL, mac terminal, or *nix machine - and it can be done online without taking the rpi down.
I do it manually, but could probably be scripted, too.
Example from Windows WSL2 backing up to D:\backup:
ssh user@ip "sudo dd if=/dev/mmcblk0 bs=1M" | gzip | dd of=/mnt/d/backup/file.gz
Huh....I didn't know you could do that while it was running. I always shut down and imaged on my desktop via Win32DiskImager.
mind blown!
It took me a while but I did finally find a method to shrink those images too...so I can save more than one without taking up ALL my storage space. It doesn't work all the time but I've had good luck with it.
Well, I now have a new project to do this week...this is wonderful!
You know... To be slightly more technically correct I really should have said to do a "-t" on the ssh... Should work without it, but could fail in some scenarios if it isn't specified.
ssh -t user@ip "sudo dd if=/dev/mmcblk0 bs=1M" | gzip | dd of=/mnt/d/backup/file.gz
I was going to automate with a bash script in my pi run on a cron entry anyway, so wouldn't have even noticed.
But do you really need pseudo -tty for that command? I wouldn't think that command would be affected but I am no ssh expert.
