If you try to use the standard http request node and copy/paste the requested url (with the right token) and output to debug node
Do you have the same error or you get a result?
If you get a valid result without issue, then it's probably related to hubitat nodes and I can fix something
If you get the same error, then it's probably related to node-red or OS...
You can re-re-validate with node-red-contrib-ping to see if you get the same result
Maybe that node-red community/forum can help you on this issue
This was a great suggestion, and good news! You're off the hook. I'll look into why Node-RED can't resolve mDNS names. Maybe the container is missing something.
Generally only the events/state changes are pushed to node-red; those are informational messages from the driver and may or may not correlate to an event being sent - more to trace progress through the driver’s code.
Can you trap the button presses in RM? I'm not sure you can as they are paired directly to the doorbell and not a separate device I think. I use the Aeotec siren part of the doorbell and trap my Ring doorbell push events.
edit: I agree with @thebearmay it's likely a driver thing since obviously the button press info is being recorded but maybe not as an event. Check your events log for the device as well.
Here's a tip that someone (probably @JasonJoel or @dan.t) gave me a couple of years ago. The simplest way to figure out the message property to evaluate is to use a debug node that captures the output from a device node.
Then configure that debug node to capture/display the complete msg object, as shown below:
I suspect you don't have the Server property properly configured here. Click on the "pencil" button to the right of House Hubitat and post a screenshot of the dialog that pops up.
My apologies; the "configuration missing" is due to my mis-configured Influx node. I get nothing from the Doorbell device node nor do I get anything from the Events node.
