A question, which I think will not be possible. I know a command node can retrieve the command from incoming msg, but can the device(text or devid) be set from the incoming msg ?
Take a look at the help for the command node - you can pass a msg.deviceId to select the device you want. Unfortunately if you have multiple hubs you have to get a little fancy. Is this what you were looking for?
Hey this is great! One little issue I ran into: I tried to use the mDNS name for my Hubitat (hubitat.local), but it didn't work until I put the IP address in there. Is that expected? Any chance of getting it to work using mDNS?
Note: this is only temporary, will go away on reboot. Sadly on my RPI running NR it does not work but have not really dug into why not (not a firewall issue).
edit: you could also just add the entry into your /etc/hosts file as well but that is more of a hard-coded solution...
In the early stages of my Hubitat experience I ended up messing up my configuration for various exploratory/experimental "reasons" and had to re-pair over 100 devices. As soon as that was all taken care of I accidentally did it again...
Was a sad, sad couple of days... Wife was not pleased with me or my "hobby"...
