Fix version 1.7.2 released
- fix empty dropdown when you have
httpAdminRoot
or NR credential configured
More information in this debugging thread
httpAdminRoot
or NR credential configuredWanted to report an issue with Node-RED update 1.3.0-1.3.3.
If you are using the MQTT Aedes broker node + MQTT nodes then you might experience some "Close timed out" errors on deploy. This is because Node-RED shuts down the Aedes broker before closing the MQTT nodes. This in turn causes the MQTT Nodes to generate an error due to being unable to close the connection to the Aedes broker.
Sorry for the rookie question here but what is the copy paste method?
So like if you drag your mouse pointer over a select group of nodes and hit the delete keyboard key they disappear.
Can you do the same with copying nodes drag your mouse pointer over a group of them and click " what "???
There is a "right-click" style menu, but I have only ever done it on a touchscreen device by long pressing. It is basically a radial menu with various options, but I can't seem to access it with a kb/m. If anyone knows how I would love to know.
There are also a ton of shortcuts/hotkeys that you can bind to do various things in the settings menu:
Thanks that saved a bunch of time
The visual design aspect + copying and pasting makes flow/sequence maintenance and updating a great experience. Also subflows are good too - can eliminate a lot of redundancy.
Yeah subflows and link-ins/outs are all great ways to reuse the same sequences and on a more advanced level, you can have each subflow have user editable parameters so each instance can be slightly different.
For instance, I have a sort of database that holds all variables associated with my modes, so there is a room subflow that sets all variables for the particular rooms and in the mode subflow, there are multiple instances of the room subflow and then I modify things like level, volume, color temperature, setpoints, etc. for the given mode, and for the given rooms. Then I just pop that mode subflow in wherever I want to use that data, say for instance in a motion lighting sequence, and copy the data to where it needs to go for the endpoints and everything is already setup. And if I need to modify it, I only need to change it one place.
I've been ignoring this for months now since it isn't an actual error, figured I would deal with it now.
Where do I go to find out what node red determines is "device (78)"?
78 should be the Hubitat device ID (which isn’t normally visible unless you have an app that exposes it -Device Characteristics App), but it may be easier to just look at your devices and deduce which may have a pressure attribute.
I have a few that have pressure, if it's referring to barometric pressure. I have 2 weather stations and a few virtual devices.
I tried that app when I select any device (like one of the weather stations) and try to select device characteristics, it pops up "Unexpected Error"
Try importing it again (I just refreshed the code from my hub copy)
If you just want to see what device #x is, then you can enter the URL directly:
http://-hub ip-/device/edit/-device#-
I’d forgotten about that one...
I usually cheat and go to a device detail, then just edit the url and replace the device# with the one I'm looking for, instead of typing the whole url by hand.
Still gives the unexpected error. I uninstalled, copied the code again, then installed again.
But of course @JasonJoel solves my problem again (at least part of the problem of identifying which device)
It show the weather underground device. I don't even think I use anything in node red from there so I'll just uncheck it from maker and should solve we'll see.
Mine shows up as the longitude entry. Annoying, but liveable,
Think I found my issue - attributes that have never been set (weather devices have several optional attributes) were causing an index out of bounds when looking for the last state.
Thank you for testing.
