yes, that behavior seems to work fine and that is how I have reconfigured things.
the setColor command node, however, seems to be interpreting hex values strangely.
command node is only a proxy to Maker API. There is no logic or magic before sending the command. You can try directly with Maker API (copy/paste in your browser):
http://<ip>/apps/api/<app_id>/devices/<device_id>/setColor/{"hex":"15fe21"}?access_token=<token>
If you get the same result, then probably that community can help you better than me (I have never used this command)
If you don't get the same result, then it may be related to the command node
yup. same result. I’ll see if I can run it up the chain.
thanks
@fblackburn Can you remind me what the status is of COMMAND NODE logging? I keep seeing 3x events in rapid succession on some end devices that I am trying to troubleshoot. I expect it is a logic or node-red issue, not a command node issue - for the record.
But there is nothing from the command nodes being logged in the node-red log at all - just device nodes.
I have not went back and turned on debug/additional logging on the node-red side yet. Is that what is currently required to get logs of what the command nodes are doing?
Currently, there is no logging in this node. To know if command is sent or not, you need to check the msg.response from the output message.
msg.response should have some plaintext/weird errormsg.response should return the device properties (the same output that if you try the Maker API command endpoint in your browser)Good idea. In my case it is happening at specific trigger times in Node-RED, so I don't believe it to be a communication issue.
Like any troubleshooting, step 1 is to scope the issue. AKA figure out whether node-red is really SENDING 3 commands to Maker API or if it is the hub side that is doing something unexpected.
If Node-RED is really sending 3 commands, it is likely a logic/concurrency/timing issue.
If it is not, then it is a Maker API, hub, or zwave mesh issue.
I can dump the output of the command node to console so I can look back when the events happen.
Thanks.
Is there any way to get HE hub details in Nodered? It looks like the info is available (I’m primarily interested in the firmware version) but not sure it’s exposed to the Hubitat nodes
The hub version is included in the systemStart event description text and value. So while you can't get it "on demand" you could probably catch the systemStart event and store the value (which is the hub version) in a node-red variable.
Disclaimer - I didn't actually try this.
I would use the location node instead of the event node, as it is somewhat pre-filtered. So just run locaiton node into a switch node then change node and set a global variable to msg.payload.value if msg.payload.name="systemStart".
I’d have to look it to be sure, but I believe this data is exposed in the HE API for drivers and apps (mainly to verify compatibility with developer’s code). Shouldn’t be too hard to create a device or other object to expose it to the MakerAPI (may actually be there too, haven’t checked).
Could definitely do it that way, too, if you want to do a little coding. It is definitely available in apps - I've done that before. I don't think I've ever tried to get it in a driver before, but I bet you could.
EDIT: I checked the dev docs, it says the hub object is available in both apps and drivers, so you could make a simple virtual driver that grabs version and stored it in an attribute. Then the normal device node could be used to get the value on demand if desired.
Had some code laying around:
* Hub Info
* Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
* 2020-12-07 thebearmay Original version 0.1.0
* 2021-01-30. add hub version
static String version() { return '0.2.0' }
metadata {
definition (
name: "Hub Information",
namespace: "thebearmay",
author: "Jean P. May, Jr.",
importURL:"https://raw.githubusercontent.com/thebearmay/hubitat/main/hubInfo.groovy"
capability "Actuator"
attribute "latitude", "string"
attribute "longitude", "string"
attribute "hubVersion", "string"
command "configure", []
preferences {
input("debugEnable", "bool", title: "Enable debug logging?")
def installed() {
log.trace "installed()"
def configure() {
if(debugEnable) log.debug "configure()"
sendEvent(name:"latitude", value:location.getLatitude())
sendEvent(name:"longitude", value:location.getLongitude())
sendEvent(name:"hubVersion", value:location.hub.firmwareVersionString)
def updated(){
log.trace "updated()"
if(debugEnable) runIn(1800,logsOff)
void logsOff(){
device.updateSetting("debugEnable",[value:"false",type:"bool"])
Yep - I saw that in the Location node. I was going down the path of storing the value but that would require me to change NR to context storage (to persist NR restarts) and muck with the settings file. Was hoping that I could avoid that but may have to go with that.
Or you can use @thebearmay's driver for a virtual device (the post just above yours).
Going to try this but have no idea what type of a virtual device ![]()
I don't know how people can live without persistent context variables.
I use them extensively.
It will be obvious when you do it...
My NR setup was relatively simple so never set it up that way
. Time to grow up I guess..
I just set this up. It's a simple edit to the settings.js file I recall. Actually the option is already in the file and just needs the commenting to be removed, and presto! Persistent Context Variables!
If I get some time today I’ll flesh that code out some more and see if I can subscribe to the system start event to force it to update automatically.
Or just add initialize capability and do it in initialize().
