When I turn on/off a light (from either the Home app or HE dashboard), I do see the event in Nodered, so I guess the POST events does work, just something funky about the MS6.
It looks like the image that you have and I do get the green checkmark on clicking "Configure webhook" and the App IDs match in MakerAPI and Nodered Config node.
AND - today the "request" node is WORKING! The only thing that I can think of is that after I went to look at the config node to confirm that it matched your pic, I clicked on "update" and not "cancel". I thought I had done that yesterday as well, so not sure what changed
That's a cool start to the New Year!
The other thing you might want to do is make sure your palette is up to date. I assume you know how to do this but for posterity go to "manage palette" and look for any "update" buttons next to the nodes. You will likely have to restart Node-RED afterwards.
I apologize if this has been asked before, but this is a very long thread!
I have 2 Hubitat hubs (I know, I'm a lightweight!) connected to Node Red and it all works brilliantly.
What I wondered though, is there a way of having nodes coloured differently for each Configuraton Node? I've recently been moving devices from one Hubitat to the other and it would have been really useful in Node Red if one Hub's nodes had been say Light Green and the other one Dark to quickly distinguish which hub they relate to in the flows.
Yes he did. And at one point of time, I did as well. However, AFAIK, the colors cannot be changed per instance of "node-red-contrib-hubitat"; they would apply to all instances (meaning all Maker API integrations).
Yes, I set it up so that each Hubitat node type is a different color.
BUT it's not a pain because you challenged me to create a flow to do it automatically so I click one inject node after every Hubitat Node version update.
Understanding that I know NOTHING about creating nodes, is it possible to make this statement that determines color a conditional based on a value in the node?
I assume even if you could, it would require a Node Red restart for the color change to happen.
It's just the "name" property of the node instance in Node-RED. That's why it might be more of a pain to use.. you might see if @fblackburn would consider having an option to prepend the config name in the name property itself in each hub config instance.
Automatically adding the hub name in front, as you suggest, would be very helpful if it is possible. The colour change was just an idea but any way of distinguishing easily between different hubs works for me. With the amount of hubs some people have a name prefix might be better as they would soon run out of colour options!
Oh it's a good request "Be able to distinguish nodes from different configs"
With my limited NR experience, I never saw any palette resolving this issue. If any of you have seen this
I like the color idea because it keeps the flow clean. I don't know if it's possible, but should be fun to try
I like the idea of user field for prefix too, but the only small downside, I fear to visually load flows with the same info duplicate under every node.
My color changing process is working just fine as is my entire system (knock on wood). It's not time to start playing with the settings.js file and bringing down my entire home automation system.
Does anyone know what the circle with the line next to my House Lights mean? All of my flows on that page is not working and has dashes around them? I have about ten pages/sheet of flows with different titles and have two pages that are like this? I look around the net but didn't find anything? Thanks
