- I use global.mode variable for mode checking inside of other flows (see "mode" switch nodes in picture below).
- I use the mode node + link out to trigger other flows on mode change.
- I use the inject node 10s after startup + mode node + link out node to trigger mode event at startup (to ensure logic is in correct state).
Link in to a random delay to the rest of ther flow to set behavior based on mode.
mode switch node:
