I was just about to point you to this recent post by Bruce, which I'd hoped would remove the need do change all the Device IDs, but I just realized that what this post describes is a way to preserve (or re-assign) old Device Network IDs (DNIs) on the new hub. Apparently this will allow your Hubitat automations to continue to work on the new hub. However, I notice that the NR nodes use the Device ID as identifiers, and not the DNIs, so I guess this wouldn't help us.
However, one great thing about NR is that we can also edit our flows in text editors (via export and import), which means you could do some find-and-replace-ing to change the Device IDs in your flows. You might even find a way to do it throw a NR flow
haha. Or, failing that, I believe we can edit our flow files directly, making it easier than export/importing each flow.
EDIT: I forgot to include a link to the post:
