Can anyone tell me in a simple way how to get Node Red working on my C7 Hubitat device. It was so simple in-Home Assistant
In case you meant how to install Node Red outside of Home Assistant, not how to then add the Hubitat pallet, I use this script that also works to upgrade when available.
https://nodered.org/docs/getting-started/raspberrypi
You run this script:
Sounds like you already have a home assistant install with the node red addon. In that case just install the hubitat node pallete in NR as per post #2 above and set up your devices in NR via maker API.
OK @user3077 , so what is your question?
