Node-Red Flow Samples/Sharing
So you have to make an empty repo in github and then add that repo's link, either https or ssh, I chose https, as a remote repo in NR, then you make a new remote branch which you can push to.
I did all that I also needed to restart NR and then it worked
So how would one go about storing a previous device value in a flow and then restoring it? I.e I have Hue lights that come on in the evening (thanks to the example flows here to get that working); somebody rings the doorbell and I have the hue lights throughout the house turn green for a few minutes before restoring back to the previous state. I've got it working in RM, sort of, but its not consistent (it'll work partially since some of the hue lights will turn the correct color, others won't, and some will restore, while others won't; 'course sometimes it works perfectly...it's those oddball times we end up with a mix of colors that the wife just looks over at me with no comment...)
I've been tinkering with trying to export state to a file and then back in, but of course that doesn't work when the current state would immediately overwrite the previous state...
Thanks in advance; this has been an extremely informative and helpful thread.
Store the device attribute value to a flow variable (using a change node).
Whenever desired, you can set "msg.arguments" to the value of that flow variable (also using a change node) and pass it along to a command node to restore the previous setting for that device attribute.
That's the info I was looking for, thanks!
I'm hoping someone can help me with a NR problem not related to Hubitat.
I am using iSpy Agent DVR for my cameras. They have an API that lets me control the cameras. If I use the command http://192.168.4.213:8090/command.cgi?cmd=setProfile&ind=1 directly in my browser, it executes the command properly. However, in NR I can put in a HTTP request and it does nothing. The debug returns an empty payload. Here is the flow. What do I need to change?
[{"id":"315c41db.5cdf6e","type":"inject","z":"533c47cf.8888e8","name":"Set Profile","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"command.cgi?cmd=setProfile&ind=1","payloadType":"str","x":180,"y":500,"wires":[["e9daca13.fdb898"]]},{"id":"e9daca13.fdb898","type":"http request","z":"533c47cf.8888e8","name":"","method":"PUT","ret":"txt","paytoqs":"body","url":"http://192.168.4.213:8090/","tls":"","persist":false,"proxy":"","authType":"","x":370,"y":500,"wires":[["417801e8.06fb4"]]},{"id":"417801e8.06fb4","type":"debug","z":"533c47cf.8888e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":530,"y":500,"wires":[]}]
You can use context variables. There are 3 levels of these; node, flow, and global level (the last two of which are like local/rule based and global variables in HE respectively). These are also persistent across a Node-RED restart.
https://nodered.org/docs/user-guide/context
When you open that through the browser, do you have to log in?
Also, have you tried a POST vs PUT?
Actually, maybe a GET is what they are looking for since it's all URL parameters and not a payload.
No authorization needed.
Tried POST, PUT, and GET.
Anyway, found another way to make it work using HubitatPublic/httpGetSwitch.groovy at master · hubitat/HubitatPublic · GitHub
Try this?
[{"id":"ea790395.75feb","type":"inject","z":"bf2927e5.5af798","name":"Set Profile","props":[{"p":"cmd","v":"setProfile","vt":"str"},{"p":"ind","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1000,"y":580,"wires":[["56af21d.9b4c4e"]]},{"id":"56af21d.9b4c4e","type":"http request","z":"bf2927e5.5af798","name":"","method":"GET","ret":"txt","paytoqs":"query","url":"http://192.168.4.213:8090/command.cgi","tls":"","persist":false,"proxy":"","authType":"","x":1190,"y":580,"wires":[["da69786b.1b9358"]]},{"id":"da69786b.1b9358","type":"debug","z":"bf2927e5.5af798","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1350,"y":580,"wires":[]}]
or this (with the command as part of the payload object):
[{"id":"ea790395.75feb","type":"inject","z":"bf2927e5.5af798","name":"Set Profile","props":[{"p":"payload.cmd","v":"setProfile","vt":"str"},{"p":"payload.ind","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1000,"y":580,"wires":[["ea882e9c.07a1e","56af21d.9b4c4e"]]},{"id":"56af21d.9b4c4e","type":"http request","z":"bf2927e5.5af798","name":"","method":"GET","ret":"txt","paytoqs":"query","url":"http://192.168.4.213:8090/command.cgi","tls":"","persist":false,"proxy":"","authType":"","x":1190,"y":580,"wires":[["da69786b.1b9358"]]},{"id":"da69786b.1b9358","type":"debug","z":"bf2927e5.5af798","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1350,"y":580,"wires":[]}]
Does anyone have a flow that monitors systems names/IPs on a local network where notifications would be sent to Pushover on a down state? I've seen a few out there with dashboards, and while it's neat it's completely not needed in my case. I could easily create separate flows that monitors a single Name/IP but I'm just having an issue wrapping my head around a single flow that could monitor many Names/IPs and send notifications with the correct Name/IP.
Title Log Proxmox data to influxDB
Summary -
A very simple flow to log CPU utilization, Memory usage and disk usage for a proxmox server
Flow
"id": "c91fde37.9e188",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": ""
"id": "2b9b14aa.15da2c",
"type": "group",
"z": "c91fde37.9e188",
"name": "Log Proxmox",
"style": {
"fill": "#bfdbef",
"label": true,
"color": "#0070c0"
"nodes": [
"d8ac4a74.7936f8",
"78d57918.4be748",
"5169f3e2.cfb74c",
"9457217c.43276"
"x": 34,
"y": 139,
"w": 852,
"h": 82
"id": "d8ac4a74.7936f8",
"type": "proxmox-api",
"g": "2b9b14aa.15da2c",
"name": "",
"path": "/nodes",
"method": "GET",
"payload": "",
"server": "7baaadb4.455784",
"x": 410,
"y": 180,
"wires": [
"78d57918.4be748"
"id": "78d57918.4be748",
"type": "function",
"name": "prep data",
"func": "msg.payload = [\n {\n measurement: "CPU",\n fields: {\n value:msg.payload[0].cpu \n },\n tags:{\n unit:"%",\n host:msg.payload[0].node\n },\n },\n {\n measurement: "Memory",\n fields: {\n value:msg.payload[0].mem / 1000000000\n },\n tags:{\n unit:"Gb",\n host:msg.payload[0].node\n },\n },\n {\n measurement: "Disk",\n fields: {\n value:msg.payload[0].disk / 1000000000\n },\n tags:{\n unit:"Gb",\n host:msg.payload[0].node\n },\n }\n];\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 600,
"y": 180,
"wires": [
"5169f3e2.cfb74c"
"id": "5169f3e2.cfb74c",
"type": "influxdb batch",
"influxdb": "4bcce287.69402c",
"precision": "",
"retentionPolicy": "",
"name": "Load influx",
"x": 790,
"y": 180,
"wires": []
"id": "9457217c.43276",
"type": "cronplus",
"name": "Every MInute",
"outputField": "payload",
"timeZone": "America/New_York",
"persistDynamic": false,
"commandResponseMsgOutput": "output1",
"outputs": 1,
"options": [
"name": "schedule1",
"topic": "schedule1",
"payloadType": "str",
"payload": "start",
"expressionType": "cron",
"expression": "0 * * * * *",
"location": "",
"offset": "0",
"solarType": "all",
"solarEvents": "sunrise,sunset"
"x": 150,
"y": 180,
"wires": [
"d8ac4a74.7936f8"
"id": "7baaadb4.455784",
"type": "proxmox-server",
"z": "",
"host": "192.168.1.32",
"port": "8006"
"id": "4bcce287.69402c",
"type": "influxdb",
"z": "",
"hostname": "192.168.1.183",
"port": "8086",
"protocol": "http",
"database": "hubitat",
"name": "",
"usetls": false,
"tls": ""
Title: Control lights specific to room with Alexa using same phrase
Summary: This allows you to use a single command to any Alexa and she will turn on lights based on which Alexa you are speaking.
Details: This flow allows for me to say "Illuminate" (Wesley Snipes in The Demolition Man); "Lumos Maxima" (Harry Potter), or "Make it light" to any Alexa and she will turn on the lights specific to the Alexa that I am speaking. With the node-red-contrib-alexa-remote2 node palette, there is a node that listens and msg.payload.description.summary is a summary of what she heard. The 1st Switch Node determines if she heard one of the phrases and acts appropriately. The Listening Node also provides msg.payload.deviceSerialNumber which is specific to each of the Alexas. The 2nd Switch Node determines which device to send command(s) based on Serial Number of device
I have a second flow that turns lights off to "Deluminate"; "Make it Dark" or "Lumos Minima". My third one will turn on appropriate fan to low when I say "It is hot in here".
I know this is not a complicated flow but the Listening Node in alexa-remote2 palette is powerful in this way and I thought some that installed it might not realize all of the information that it generates into a debug node. I recommend setting up the Listening Node and a Debug node (showing complete message object) and looking closely at the result in the debug window when you speak to Alexa. You might be surprised.
Note: You MUST also create a Routine in Alexa app with same name as the word/phrase you are using in flow and make it perform a 5 second wait. Otherwise, Alexa will try on her own to figure out what you mean and go looking out on the "interwebs". The 5 second wait won't affect the speed of your flow.
EDIT 9 MONTHS LATER: Instead of creating a bunch of dummy routines, you should be able to instead create an Alexa Q&A Blueprint and all of the phrase variations can all be in that one skill, thereby eliminating all of the dummy routines. See my post #461 below.
[{"id":"1dd953c7.b02acc","type":"alexa-remote-event","z":"f7404a38.ee3e88","name":"","account":"f3ed7c17.a3729","event":"ws-device-activity","x":170,"y":1700,"wires":[["3b54ccd6.116214"]]},{"id":"3b54ccd6.116214","type":"switch","z":"f7404a38.ee3e88","name":"Light It Up; Illuminate: or Lumos Maxima","property":"payload.description.summary","propertyType":"msg","rules":[{"t":"cont","v":"light it up","vt":"str"},{"t":"cont","v":"illuminate","vt":"str"},{"t":"cont","v":"lumos maxima","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":460,"y":1700,"wires":[["1c465de.e0a58a2"],["1c465de.e0a58a2"],["1c465de.e0a58a2"]]},{"id":"5abca6ca.45a228","type":"hubitat command","z":"f7404a38.ee3e88","name":"Ainsleys Fan Bulb ON","server":"e2175bd0.e82808","deviceId":"681","command":"on","commandArgs":"","x":1200,"y":1740,"wires":[[]]},{"id":"678d6870.abe8e8","type":"hubitat command","z":"f7404a38.ee3e88","name":"Declans Fan Bulb ON","server":"e2175bd0.e82808","deviceId":"347","command":"on","commandArgs":"","x":1160,"y":1880,"wires":[[]]},{"id":"9228e75e.a045d8","type":"hubitat command","z":"f7404a38.ee3e88","name":"Living Room ON","server":"e2175bd0.e82808","deviceId":"2185","command":"on","commandArgs":"","x":1100,"y":1440,"wires":[[]]},{"id":"401d936c.30afcc","type":"hubitat command","z":"f7404a38.ee3e88","name":"Master Bedroom Bulb ON","server":"e2175bd0.e82808","deviceId":"582","command":"on","commandArgs":"","x":1210,"y":1580,"wires":[[]]},{"id":"68d93176.6f7f6","type":"hubitat command","z":"f7404a38.ee3e88","name":"Kitchen ON","server":"e2175bd0.e82808","deviceId":"485","command":"on","commandArgs":"","x":1110,"y":1480,"wires":[[]]},{"id":"a8df8300.8d8b4","type":"hubitat command","z":"f7404a38.ee3e88","name":"Dining Room ON","server":"e2175bd0.e82808","deviceId":"37","command":"on","commandArgs":"","x":1150,"y":1520,"wires":[[]]},{"id":"de322c3c.8bca9","type":"hubitat command","z":"f7404a38.ee3e88","name":"Reading Nook ON","server":"e2175bd0.e82808","deviceId":"3142","command":"on","commandArgs":"","x":1190,"y":1620,"wires":[[]]},{"id":"ab9685bb.4a8cf8","type":"hubitat command","z":"f7404a38.ee3e88","name":"Master Lamp ON","server":"e2175bd0.e82808","deviceId":"967","command":"on","commandArgs":"","x":1190,"y":1660,"wires":[[]]},{"id":"84f133e3.265","type":"hubitat command","z":"f7404a38.ee3e88","name":"Ainsleys Lamp ON","server":"e2175bd0.e82808","deviceId":"852","command":"on","commandArgs":"","x":1190,"y":1780,"wires":[[]]},{"id":"f974442.d233cb8","type":"hubitat command","z":"f7404a38.ee3e88","name":"Ainsleys Night Light ON","server":"e2175bd0.e82808","deviceId":"851","command":"on","commandArgs":"","x":1210,"y":1820,"wires":[[]]},{"id":"3b8d1b62.9ac5c4","type":"hubitat command","z":"f7404a38.ee3e88","name":"Declans Lamp ON","server":"e2175bd0.e82808","deviceId":"40","command":"on","commandArgs":"","x":1130,"y":1920,"wires":[[]]},{"id":"11ade24c.5da0ee","type":"hubitat command","z":"f7404a38.ee3e88","name":"Declans Night Light ON","server":"e2175bd0.e82808","deviceId":"329","command":"on","commandArgs":"","x":1130,"y":1960,"wires":[[]]},{"id":"1c465de.e0a58a2","type":"switch","z":"f7404a38.ee3e88","name":"Which Device?","property":"payload.deviceSerialNumber","propertyType":"msg","rules":[{"t":"eq","v":"G000MW0474520JG4","vt":"str"},{"t":"eq","v":"90F0071863140022","vt":"str"},{"t":"eq","v":"G0014B05949214EG","vt":"str"},{"t":"eq","v":"G090LF1073240EBM","vt":"str"},{"t":"eq","v":"G090LF11822302U5","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":740,"y":1700,"wires":[["9228e75e.a045d8","68d93176.6f7f6","a8df8300.8d8b4"],["401d936c.30afcc","de322c3c.8bca9","ab9685bb.4a8cf8"],["401d936c.30afcc","de322c3c.8bca9","ab9685bb.4a8cf8"],["5abca6ca.45a228","84f133e3.265","f974442.d233cb8"],["11ade24c.5da0ee","3b8d1b62.9ac5c4","678d6870.abe8e8"]],"outputLabels":["LIVING ROOM","MASTER BEDROOM","ANTIQUE RADIO ECHO FLEX","AINSLEYS BEDROOM","DECLANS DOT"]},{"id":"f3ed7c17.a3729","type":"alexa-remote-account","z":"","name":"ALEXA-192.168.68.139","authMethod":"proxy","proxyOwnIp":"192.168.68.139","proxyPort":"3456","cookieFile":"authFile","refreshInterval":"3","alexaServiceHost":"pitangui.amazon.com","amazonPage":"amazon.com","acceptLanguage":"en-US","userAgent":"","useWsMqtt":"on","autoInit":"on"},{"id":"e2175bd0.e82808","type":"hubitat config","z":"","name":"HUBITAT HUB","usetls":false,"host":"192.168.68.124","port":"80","appId":"2569","nodeRedServer":"http://192.168.68.139:1880","webhookPath":"/hubitat/webhook","autoRefresh":false}]
EDIT: Since posting this originally, issues have arisen with the alexa2-remote palette. Instead, please use node-red-contrib-alexa-applestrudel which was forked from alexa2-remote.
Haven't done this (yet)
but should be easily done using this node
I use the Ping Node that @pat.richards mentioned but I have a node for each IP address. Immediately after each Ping Node, I use a Change Node to set the topic so that I can use the values to graph all of the results onto a single graph. You could do the same to send a single notification that specifies the name/IP.
The Ping Node does allow you to inject the IP address in the msg.topic so if you did a Function Node that would periodically spit out your IP addresses into the Ping Node, that would achieve your goal I think with only using one Ping Node. I don't know how to do that though. My flow generates a random number from 1-6 (I ping 6 different devices) then injects into the appropriate Ping Node.
EDIT: Flow added @stircwazy
Summary
[{"id":"4cc3a368.a54b6c","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"Hubitat A 192.168.68.124","host":"192.168.68.124","timer":"251","inputs":1,"x":730,"y":80,"wires":[["a5ee4a2.8ad3fb8"]]},{"id":"415c92e.5d5446c","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"SmartThings 192.168.68.127","host":"192.168.68.127","timer":"311","inputs":1,"x":740,"y":140,"wires":[["23c8775a.a82b88"]]},{"id":"9a0360b7.ae324","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"Pi 4 Pi-Hole 192.168.68.132","host":"192.168.68.132","timer":"291","inputs":1,"x":740,"y":200,"wires":[["5969fac3.df0d24"]]},{"id":"dba3888b.8f38e8","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"Pi Zero 192.168.68.140","host":"192.168.68.140","timer":"331","inputs":1,"x":740,"y":260,"wires":[["d07450ee.118c6"]]},{"id":"a5ee4a2.8ad3fb8","type":"change","z":"a9a038bb.6321d8","name":"Set to Hubitat","rules":[{"t":"set","p":"topic","pt":"msg","to":"HUBITAT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":80,"wires":[["1136ca32.945a56","7c8010ad.a22be"]]},{"id":"23c8775a.a82b88","type":"change","z":"a9a038bb.6321d8","name":"Set to SmartThings","rules":[{"t":"set","p":"topic","pt":"msg","to":"SMARTTHINGS","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":140,"wires":[["1136ca32.945a56","7c8010ad.a22be"]]},{"id":"5969fac3.df0d24","type":"change","z":"a9a038bb.6321d8","name":"Set to Pi Hole 4","rules":[{"t":"set","p":"topic","pt":"msg","to":"PI 4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":200,"wires":[["1136ca32.945a56","7c8010ad.a22be"]]},{"id":"d07450ee.118c6","type":"change","z":"a9a038bb.6321d8","name":"Set to Pi Zero Pi-Hole","rules":[{"t":"set","p":"topic","pt":"msg","to":"PI ZERO","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":260,"wires":[["1136ca32.945a56","7c8010ad.a22be"]]},{"id":"96325f7f.25924","type":"ui_chart","z":"a9a038bb.6321d8","name":"","group":"fdbcb9aa.554fa8","order":12,"width":"24","height":"15","label":"PINGING","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"0","ymax":"8","removeOlder":"48","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1720,"y":200,"wires":[]},{"id":"ad6e010a.2b70f","type":"inject","z":"a9a038bb.6321d8","name":"reset","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Button","payload":"","payloadType":"json","x":1550,"y":320,"wires":[["96325f7f.25924"]]},{"id":"1136ca32.945a56","type":"switch","z":"a9a038bb.6321d8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1370,"y":200,"wires":[["d8919679.ca4848","85752497.c638e8"]]},{"id":"d8919679.ca4848","type":"debug","z":"a9a038bb.6321d8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1530,"y":260,"wires":},{"id":"7c8010ad.a22be","type":"debug","z":"a9a038bb.6321d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1410,"y":120,"wires":},{"id":"85752497.c638e8","type":"smooth","z":"a9a038bb.6321d8","name":"","property":"payload","action":"mean","count":"5","round":"","mult":"multi","reduce":false,"x":1540,"y":200,"wires":[["96325f7f.25924"]]},{"id":"45887652.ca8348","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"Hubitat B 192.168.68.161","host":"192.168.68.161","timer":"247","inputs":1,"x":730,"y":320,"wires":[["8f69334c.e2723"]]},{"id":"8f69334c.e2723","type":"change","z":"a9a038bb.6321d8","name":"Set to Hubitat B","rules":[{"t":"set","p":"topic","pt":"msg","to":"HUBITAT B","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":320,"wires":[["7c8010ad.a22be","1136ca32.945a56"]]},{"id":"437effb7.87342","type":"inject","z":"a9a038bb.6321d8","name":"","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"29","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":200,"wires":[["bdfabb46.506218"]]},{"id":"bdfabb46.506218","type":"random","z":"a9a038bb.6321d8","name":"Random 1-6","low":"1","high":"7","inte":"true","property":"payload","x":290,"y":200,"wires":[["75a5adfa.9bbee4"]]},{"id":"75a5adfa.9bbee4","type":"switch","z":"a9a038bb.6321d8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"num"},{"t":"eq","v":"7","vt":"num"}],"checkall":"true","repair":false,"outputs":7,"x":450,"y":200,"wires":[["4cc3a368.a54b6c"],["415c92e.5d5446c"],["9a0360b7.ae324"],["dba3888b.8f38e8"],["45887652.ca8348"],["2b662a0b.4a0356"],["399bbdc7.6f6472"]]},{"id":"399bbdc7.6f6472","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"Cloudflare 1.1.1.1","host":"1.1.1.1","timer":"247","inputs":1,"x":710,"y":440,"wires":[["c086482e.19f278"]]},{"id":"c086482e.19f278","type":"change","z":"a9a038bb.6321d8","name":"Set to Cloudflare","rules":[{"t":"set","p":"topic","pt":"msg","to":"CLOUDFLARE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":440,"wires":[["7c8010ad.a22be","1136ca32.945a56"]]},{"id":"2b662a0b.4a0356","type":"ping","z":"a9a038bb.6321d8","mode":"triggered","name":"Hubitat C-7 192.168.68.166","host":"192.168.68.166","timer":"247","inputs":1,"x":740,"y":380,"wires":[["d5344d0a.0dfe1"]]},{"id":"d5344d0a.0dfe1","type":"change","z":"a9a038bb.6321d8","name":"Set to Hubitat C-7","rules":[{"t":"set","p":"topic","pt":"msg","to":"HUBITAT C-7","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":380,"wires":[["7c8010ad.a22be","1136ca32.945a56"]]},{"id":"fdbcb9aa.554fa8","type":"ui_group","z":"","name":"PING MONITOR","tab":"28e0f341.9ade5c","order":1,"disp":true,"width":"24","collapse":true},{"id":"28e0f341.9ade5c","type":"ui_tab","z":"","name":"MAIN","icon":"dashboard","order":6,"disabled":false,"hidden":false}]
Hmmm, OK I think I get it, thanks @stephen_nutt. Would you mind exporting that flow so I can look at it?
This is awesome @stephen_nutt, many thanks for posting!!
This means if I remove all devices in Alexa, I no longer need to mess around with any of them in that bloody Alexa app. It doesn't alter my Alexa routines at all, and my NR is still configured, amazing :smiley: Thanks!!
Not only this, I can now open and close the curtains etc in any room :wink:
This is a built-in feature with Alexa devices since at least 2017. Assign the lights and the echo device to the same room and when you ask Alexa to turn on the lights it will do it based on the Alexa you are speaking to.
While your flow will work, it still depends on the node having an up to date cookie so I'd estimate that it is only 95% reliable whereas the built-in one would be 100%.
I know but you must group all of the lights in that room and can only say "Turn on/off Lights". I don't want to say it that way. My way doesn't require grouping and I can use the same phrase in any room and Alexa knows which room I am in and turns on/off appropriate lights. Also, my way let's me have one phrase "Its hot in here" that will turn on fan in the room of the Alexa that I am speaking.
You will still have to create "dummy" Alexa routines for each phrase you want to use that don't do anything but wait for 5 seconds. Otherwise, Alexa will search the internet to try to find out how to process what you said. However, if you don't mind her saying something like "I don't know how to help you with that" or similar every time, you don't.
