This works for the open side but results in NULL when all are closed.
I found another app called Device Status Announcer that looks to do all I need for the notification part. I have a rule turn on a virtual switch when my Sensor group TotalOpen changes and that triggers DSA to announce which device or devices are open and an all-closed message if none are open.
I started adding in descriptive text for the devices being closed and realized that this is why I didn't do it in the first place. Inherently, if the virtual device is closed, then everything is closed. So you're rule would just need a conditional:
IF(contact sensor = open) THEN
Message/Log/Speak: %text%
ELSE
Message/Log/Speak: Everything is closed.
END-IF
Although...I do suppose that setting the descriptive text on close would let the rule be simpler.
I lied. I realized that since there's a varying threshold for most of the groups, putting in a blanket statement of "all the contact sensors are closed", "all locks are locked", etc. would potentially be incorrect.
That is also correct. No more changes need on this issue for me. I can use Device Status Announcer with your group as the trigger and it is working how I want. Thanks for your help.
I am trying to get this going and struggling a bit. The idea and applications that pointed me to this post are great and I cannot wait to get this to work. I believe I have everything installed correctly but when I have selected the contact sensors for the group, the logs are saying this: java.lang.IllegalArgumentException: A device with the same device network ID exists, Please use a different DNI on line 129 (method updated)
When I look at all my devices and include the Device Network ID, I don't see a duplicate. Do I just need to edit the virtual device ID to something way different?
I am pretty sure this is then what is preventing anything else from working when I'm setting up a basic rule to notify me which device is open?
It means the child app created a virtual device, lost track of it, and then tried to create it again. Best just to remove the child app and start over from scratch.
I've had this happen once or twice but haven't been able to reliably reproduce it to put in a fix.
I may oddly be your repeatable source? lol. I just did that and same error in the log after creating the child app.
I can uninstall everything and powercycle and reinstall? I used HPM and did the options to repair and such to ensure the files were in sync. Not sure if there was a hiccup in that process that is now causing this.
Yeah, I was just trying out the contract group to start before looking at the other child groups. I've removed everything and will take the latest hub update to reboot and get a fresh start. I very well could have installed it incorrectly as I tried to manually do it vs. HPM at first and got tripped up on that process.
No change to the settings.. I went through those steps for the uninstall and re-install. I get this error when I go to set the child app for contact sensors:
