Features by App
**CO Detector**
- Detected/clear based on any sensor in the group.
- List of active devices stored as an attribute.
**Contact**
- Configurable threshold for how many sensors must be open before the group device is open.
- Configurable delay when the threshold is breached before updating the state of the group device.
**Humidity**
- Min/Max/Average humidity of the sensors in the group.
**Locks**
- Locked/unlocked based on monitored devices.
- Configurable threshold for how many devices must be unlocked before the group device is unlocked.
**Lux**
- Min/Max/Average lux of the sensors in the group.
**Motion**
- Configurable threshold for how many sensors must be active before the group device is active.
- Can optionally also add acceleration sensors.
**Power Meter**
- Sum of power reading from all meters.
- List of devices and their power readings stored as an attribute (for dashboard tiles).
**Pressure Sensor**
- Min/Max/Average pressure of the sensors in the group.
- List of devices and their pressure readings stored as an attribute (for dashboard tiles).
- Device identification for the min/max values.
- Conversion from kPa to mbar.
**Smoke Detector**
**Switches (should also include most bulbs)**
- Configurable threshold for how many switches must be on before the group device is on.
**Temp**
- Min/Max/Average temperature of the sensors in the group.
**Water Leak Detector**
- Wet/dry based on any sensor in the group.
Several of the apps will populate a "displayTable" attribute that can be used for dashboard tiles:
