[No Longer Maintained] Orbit BHyve Integration
LOL. So nothing in particular, because you can do that from the app :wink:
There's an HA integration for anyone that has that running simultaneously with HE like I do. But without soil moisture measurements, I'm not planning to integrate it into my smart home. I've read enough disappointment with the performance, longevity and minimal gains from the investment in wireless moisture sensors to keep me from spending any money or time on them.
True, but the app doesn't let me add a widget to tap to turn the hose on/off. I'm doing that through HE with the HD+ dashboard app.
I am no programmer so I can only assist with testing when someone takes over this code.
I am using this integration mainly for tracking watering times and showing watering time on the dashboard. Also, manually triggering certain sprinklers when needed.
There's an Alexa integration. I have not tried it, but it's probably good enough. One could trigger a virtual sensor via a switch and thus an Alexa routine to turn on the valve.
This is similar to how I fill the coffee maker each morning. I press a button on my 6 button Opple/Xiaomi controller, HA closes a Hubitat virtual switch/contact sensor, and that triggers an Alexa routine to “Ask Delta to pour X amount of water”. Takes a few seconds to respond, but that’s fine. I just stand there blurry-eyed hold the coffee pot until it fills. :joy:
Well, I don't fancy keeping a button on my uncovered back porch :grin:. That's why I went the widget route because the wife and I basically always have our phones on hand. So, functionally, I'm doing your recommendation. Just replacing the actual button with a widget and Alexa with HE as an intermediary.
Yes. Just an example. The trigger can be physical to software, or software directly (i.e. dashboard, voice command, etc)
I'm aware. Just giving my use-case for having it in HE.
FWIW - Since this app wasn't being maintained anymore I took the original app/driver, made a couple of small changes to fix the errors I was seeing on a regular basis in the logs and re-submitted it to HPM. I started a new thread here with details:
I'm NOT trying to take any credit for this app/driver -- it's a very well written app. I'm also not sure how much I can add to it but if anyone else wants to submit pull requests (PR) for additional changes please do and I'll try to make sure it stays updated.
I'm using Google Assistant to control my hose with my voice.. I've got an outdoor speaker that has Google Assistant built-in and I regularly say "hey google, turn hose on" and voila! The hose is turned on for 15 minutes and turns off automatically when done.
FWIW - I used to keep my hoses always on until I had one burst -- so now I try to only turn them on when needed.
It just requires this app and the Google Home app (built-in)
I should also say that the Orbit app is terrible.. I tried adding a second timer the other day and it took forever. Initially the app wouldn't login (I think Orbit was having server issues) but it just froze there.
It's added now but switching between 2 timers is still painfully slow in the Orbit app.
Generally speaking I love my Hubitat Hub because I can pull lots of cloud-based devices (Orbit, Rachio, Harmony, Blink, etc) into HE and control them all using the same rules as my other ZWave/Zigbee devices...
Which really means I can integrate any of them with Google Assistant for voice control. Or, view and control any of them via dashboard (I have 2 wall mounted tablets running HD+ -- #shamelessplug)
The best part is -- I don't need to open multiple apps from different companies to do any of this!
Old threat, I know, but looks like nobody picked the integration up. Here's a quick fix for the controller app, line 335 java.lang.NullPointerException: null on line 335 (method refresh)
Simply replace line 335, 336 with the "if" clause below and the annoying log entries will go away...
                            if (it.status.next_start_time != Null ) {
                                def next_start_time_local = Date.parse("yyyy-MM-dd'T'HH:mm:ssX",it.status.next_start_time)
                                d.sendEvent(name:"next_start_time", value: next_start_time_local.getTime())
