I did a soft reset (and lost all devices) only after did I try resetting the zigbee radio, because I am at the point of trying anything to get it working.
Because I was looking for a way factory reset anyway. I had already gone through every option to get a device to communicate that I was aware of. I am not trying to sound like a know it all, I am sorry if I come off that way.
Whatβs the device? Have you confirmed its radio is functional? Does it support all zigbee channels, or more specifically, the zigbee channel your Hubitat is on?
There are some devices like the Konke Temp/Humidity Sensor that ONLY work on channels 15, 20, and 23. (@aaiyar gets credit for finding this!)
And apparently the newer versions of this model don't seem to pair with HE at all.
You have to be careful if using cheap devices like Tuya/Aqara or off-brand devices. For the non 3.0 stuff they should be on a separate hub as they don't play well with the other "good" Zigbee devices for some reason.
A lot of us have been through this at least once or twice (my case 3 times) on our HE/Home Automation journey so understand the frustration. Zigbee is the more forgiving of the 2 protocols. You can re-include a device and it will automatically find it's place.
Note: You can still restore from a backup and start re-including your devices. Any rules etc should remain intact. Only the Z-Wave devices will have to be adjusted and there are ways to handle that as well.
So I have gone 2 weeks with this issue and not a peep in response to my email to support (beyond an automated message acknowledging). Is support normally this horrid? Because I about to the point of throwing the hub in the trash and moving on.
That may be a large part of your problem. Sengled bulbs do not repeat. Your mesh may be extremely weak and not repeating or sending messages downline. Just a thought
