I'm not too familar w/this type of issue, I use Picos but have never run into this, hopefully someone will chime in soon...like @bertabcd1234 (Robert) who is a Pico-master. Also tagging @marktheknife and @neonturbo.
Please clarify. Are you trying to use a button in an app like Button Controller? Are you hoping that the Pico is joined with a Caseta automatically? Other?
When you set these up in Caseta app, did you put them into their own "room", or in the same room as a Caseta dimmer?
How are you generating these digital presses, and how is the automation/app configured on Hubitat (i.e., the thing that it is supposed to be doing)? It looks like the events are coming through fine, though the "Events" tab/button on the device page is the authoritative source (it's up to the driver to make the log entries, but it's not under control of the platform and there could be a discrepancy). This would leave an event subscription issue on the app as a possibility.
But it's hard to say more without knowing your particular configuration.
Thank you very much for the responses. I'm on night #1 with the system so forgive my ignorance.
My goal is to control whole-house scenes from a 4 button Pico remote: PJ2-4B-GWH-L31
I have two of these Picos currently added to my Lutron SmartBridge Pro 2: one that controls all lights (on multiple Caseta switches) in my kitchen (setup through Caseta app) and another is completely blank.
As part of my initial setup, I tried testing button presses through the Devices tab for the Pico connected to the Kitchen. I tried inputting buttons 1-4 (based on what was showing on the activity log, previous screesnshot) as well as 8-11 as shown from my Integration report. None of these approaches were successful.
That's somewhat surprising since the below LOOKS like the same thing should be happening in the kitchen but clearly not the case.
Maybe I'm then looking at this wrong and should just skip to my real question which is how to program Caseta scenes to Pico button presses? I feel like I've searched for every iteration of this question but have not been able to find the answer.
IIRC, Caseta Scenes will show up in the Integration Report with specific ID of # 1.
Using Hubitat’s Lutron integration, if you add this device as a Lutron Keypad, ID 1, a new Hubitat device will be created that can be used to trigger Lutron Scenes.
Once you have this device created, you can use a Pico to trigger an automation to “push()” this Lutron 100 button device with whatever Lutron scene # you’d like.
I have never used the Caseta scenes, any scenes I have set up have been in Hubitat. While it is theoretically possible to use Caseta scenes, I feel they are more limited than using Hubitat. You can use that Hubitat based scene in Button Controller, Basic Rules, or other automation apps.
how is the integrator on hubitat looking? You set up the k,1,integrator name correct? All lower case? It's showing as a device in the devices page? Like this?
@motion732 Your rule seems to be off... Make sure it looks similar to this (specifically button 3) Also turn on debug on the keypad device and pico and see what the logs say when you push the pico button. Open the logs on a separate page.
Now when I digitally push "Smart Bridge 2" button 2 from Devices tab the scene goes on. There seems to be a disconnection between the Nook Pico not triggering the command on the Smart Bridge 2. What's interesting is when I press the top button on the device, which I would think is button 1, it's showing as button 8 in the log. However, if I digitally press button 1 OR button 8 on the Nook, nothing happens.
