I spent several days trying to figure out how to add control of my Yamaha receiver to Hubitat. There are guides out there that assume a lot of knowledge that I didn't have as a NEWB. So I will try to give step by step directions of how I added and made use of a Yamaha receiver driver to my Hubitat. Experts are more than welcome to constructively critique my methods and correct/enhance upon the information I present.
- I found 2 Yamaha .groovy files in GitHub.
a) Driver for Yamaha receiver: Yamaha-NVR-Hubitat/YamahaNetworkReceiver.groovy at main · CreatureOfHubitat/Yamaha-NVR-Hubitat · GitHub
b) Driver for Yamaha zone: Yamaha-NVR-Hubitat/YamahaZonesDriver.groovy at main · CreatureOfHubitat/Yamaha-NVR-Hubitat · GitHub
Neither of these two .groovy drivers allowed this newb to do anything with my receiver. I ended up having to combine the two drivers then delete the duplicated functions. This is my merge of the Yamaha Receiver .groovy and the Yamaha Zone .groovy files that I use in this thread.
* Hubitat Driver: Yamaha Network Receiver
* Author: Ben Rimmasch
* Derived from redloro@gmail.com's ST work for Yamaha Receivers
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* https://github.com/PSeitz/yamaha-nodejs
* http://<RECEIVER_IP_ADDRESS>/YamahaRemoteControl/desc.xml
import groovy.util.XmlSlurper
metadata {
definition(name: "Yamaha Receiver", namespace: "codahq-hubitat", author: "Ben Rimmasch") {
preferences {
section("Yamaha Receiver") {
//input name: "receiverName", type: "text", title: "Name", required: true, defaultValue: "Yamaha"
input name: "receiverIp", type: "text", title: "IP", required: true
input name: "receiverZones", type: "enum", title: "Zones", required: true, multiple: true, options: ["Main_Zone", "Zone_B", "Zone_2", "Zone_3", "Zone_4"]
input name: "descriptionTextEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: false
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: false
input name: "traceLogEnable", type: "bool", title: "Enable trace logging", defaultValue: false
private logInfo(msg) {
if (descriptionTextEnable) log.info msg
def logDebug(msg) {
if (logEnable) log.debug msg
def logTrace(msg) {
if (traceLogEnable) log.trace msg
def updated() {
updateDNI()
//removeChildDevices()
addChildDevices()
def uninstalled() {
def map = parseLanMessage(description)
def body = getHttpBody(map.body);
logTrace "Headers: ${map.headers}"
logTrace "Body: ${body}"
updateZoneDevices(body.children()[0])
private updateZoneDevices(evt) {
logDebug "updateZoneDevices: ${evt.toString()}"
if (evt.name() == "System") {
logDebug "Update all zones"
childDevices *.zone(evt)
return
def zonedevice = getChildDevice(getDeviceId(evt.name()))
if (zonedevice) {
zonedevice.zone(evt)
//check for Zone_B
zonedevice = getChildDevice(getDeviceId("Zone_B"))
if (zonedevice && evt.name() == "Main_Zone") {
private addChildDevices() {
// add yamaha zone device(s)
//temporary workaround to add Strings to lists
def selectedZones = []
if (settings.receiverZones instanceof java.lang.String) {
selectedZones = [settings.receiverZones]
else {
selectedZones = settings.receiverZones
selectedZones.each {
def deviceId = getDeviceId(it)
if (!getChildDevice(deviceId)) {
addChildDevice("codahq-hubitat", "Yamaha Zone", deviceId, [name: "Yamaha Zone ${it}", label: "${device.name} - Zone ${it}", isComponent: false])
logInfo "Added Yamaha zone: ${deviceId}"
childDevices *.refresh()
private removeChildDevices() {
getChildDevices().each {
log.warn "deleting ${it}"
deleteChildDevice(it.deviceNetworkId)
private sendCommand(body) {
logDebug "Yamaha Network Receiver send command: ${groovy.xml.XmlUtil.escapeXml(body)}"
def hubAction = new hubitat.device.HubAction(
headers: [HOST: getReceiverAddress()],
method: "POST",
path: "/YamahaRemoteControl/ctrl",
body: body
sendHubCommand(hubAction)
private getHttpHeaders(headers) {
def obj = [: ]
new String(headers.decodeBase64()).split("\r\n").each { param ->
def nameAndValue = param.split(":")
obj[nameAndValue[0]] = (nameAndValue.length == 1) ? "" : nameAndValue[1].trim()
return obj
private getHttpBody(body) {
def obj = null;
if (body) {
obj = new XmlSlurper().parseText(new String(body))
return obj
private getDeviceId(zone) {
return "yamaha|${settings.receiverIp}|${zone}".toString()
private getReceiverAddress() {
return settings.receiverIp + ":80"
private String convertIPtoHex(ipAddress) {
return ipAddress.tokenize('.').collect { String.format('%02x', it.toInteger()) }.join().toUpperCase()
private String convertPortToHex(port) {
return port.toString().format('%04x', port.toInteger()).toUpperCase()
private setDeviceNetworkId(ip, port = null){
def myDNI
if (port == null) {
myDNI = ip
} else {
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
myDNI = "$iphex:$porthex"
log.debug "Device Network Id set to ${myDNI}"
return myDNI
private updateDNI() {
//if (state.dni != null && state.dni != "" && device.deviceNetworkId != state.dni) {
// device.deviceNetworkId = state.dni
def dni = convertIPtoHex(settings.receiverIp)
if (dni != device.deviceNetworkId) {
device.deviceNetworkId = dni
private getHostAddress() {
if (getDeviceDataByName("ip") && getDeviceDataByName("port")) {
return "${getDeviceDataByName("ip")}:${getDeviceDataByName("port")}"
else {
return "${ip}:80"
I went to the "Drivers section in my Hubitat and selected "New Driver":
I pasted the code (shown above) into the new driver text window:
After clicking "save" I then had the driver registered with hubitat:
I checked my modem/router/firewall DHCP leases and found the IP address of my Yamaha receiver. On "MY" router I can click on the MAC address and it will show me info on the device associated with the lease:
I should add static DHCP address leases to my router for all of these devices so they always come up on the same IP address but that is a different tutorial which is specific to your specific router.
Next I go into the Devices section on Hubitat and select "Add device":
I select "Virtual Device":
After searching for "Yama", selecting "Yamaha Receiver" and giving the device a name I click save:
Which takes me to the device config page. Note the name of the Volume Down button is "volumeDown", this will be used later when adding a button to a Dashboard.
I add the IP address of the Yamaha receiver and select "Main Zone" which is the only Yamaha receiver zone I have speakers connected to. Down at the bottom of the Device Config page I click "Save Device":
At this point I can open the device and control it with the buttons in the device config page.
After which the device appears in my list of devices:
Then I go into one of my Dashboards and add the Yamaha device:
Unfortunately I have not figured out how to create/configure buttons for virtual devices in a dashboard that will actually do anything yet. I will post more when I have had a chance to sit down and work through this. Or maybe someone can give me some direction here?
