New THIRDREALITY Zigbee Smart Presence Sensor R3
I noticed Third Reality has a new multi-sensor (air quality, lux, 60ghz mmWave plus RGB light & repeater). Seems like a solid deal for only $50. Starts shipping next week.
@mike.maxwell do you anticipate having a driver for this anytime soon?
https://a.co/d/07mYipZp
Oh I really need one of these for the Kitchen for when the son decides to cook and start a fire on the stove.
RBG light! Another device from them that could be usable as a status indicator for items in addition to air quality reporting.
It def checks a lot of boxes for that price-point. Hoping a driver will be available soon.
Speaking of Third Reality, are any of their websites working for anyone?
I've been trying to check some firmware statuses / release notes for a couple things (which I've successfully done in the past), but the website's been down for a while now (i.e. a couple weeks?)
Edit -- solved -- networking shenanigans on my end
Thirdreality.com works just fine for me.
So it is something on my network then... Very odd it's just that one site... Well, thanks for confirming!
Nuts, I should've checked this first, but the 3R website somehow got blacklisted in my firewall. Strange, but it's now back in action :+1:
Of course when you post this Amazon USA is broken. I have major FOMO now, unable to checkout
Did for me too
Curious to hear reviews for anyone who’s purchased one. I’m itching to buy one.
anyone know if there is a driver for it
norton seems to be blocking (thirdreality.com) it even with everything disabled
In the last several weeks, I had to whitelist their domain on my Eero in order to regain access to it -- it's very strange.
Honestly I would dump Norton. It has been 20 years since it was any good.
Subbed for when a driver comes out
I spent a half-hour or so with ChatGPT (it took 4 or 5 passes) to come up with the attached driver. The light functions seem to work well, illuminance responds to light changes, I think motion is working OK, and I have no clue as to what the TVOC number indicates in terms of real world significance.
EDIT: Bug fixed in the attached version re reporting Lux (log spamming).
  • added an illuminance deadband preference, default 3 Lux
  • added a minimum seconds between small illuminance reports preference, default 30 seconds
  • changed the illuminance handling so 1-lux chatter is suppressed unless enough time has passed
  • fixed a second source of spam: the driver was writing info log lines before checking whether the event was actually changing
  • made configure() request less chatty illuminance reporting too
EDIT 2: Revised driver that handles TVOC values better and reduces TVOC spam.
EDIT 2026-03-24: I revised the driver to include additional Preference controls. NOTE: for Hubitat Beta testers, there is now an official driver for this device as of 2026-03-24. However, the version below has additional controls and lacks the "Flash" command which does nothing on my system.
EDIT 2026-04-01: An AQI value of "0" is now characterized as "possible error".
BEST PRACTICE: When switching between this driver and the offiicial R3 driver, first set TYPE to "DEVICE" and clear out all prior states.
 *  THIRDREALITY Smart Presence Sensor R3 (3RPL01084Z)
 *  Hubitat driver that combines:
 *   -  The device's RGB light can be controlled via the standard ColorControl and Switch/Level capabilities.
 *   - mmWave occupancy/presence reporting (as MotionSensor + custom occupancy attribute)
 *   - illuminance reporting
 *   - Air Quality Index reporting from cluster 0x042E
 *   - Air Quality status derived from the device instruction-sheet thresholds
 *   - Air Quality Index deadband / minimum report interval filtering
 *   - Optional driver-side adjustable motion/presence clear timeout
 *   - Air Quality Index is treated as a whole-number value, since observed reports appear integral
 *  Notes:
 *   - The presence side is exposed as MotionSensor because Hubitat apps and RM generally
 *     work better with active/inactive than with PresenceSensor present/not present.
 *   - Air Quality cluster 0x042E is decoded as a float/integer value and is now reported directly
 *     using the sensor's own threshold scheme from the printed instruction sheet:
 *       1-500 good, 501-1000 ventilate, 1001-3000 warning, >3000 danger.
 *       0 = "possible error" since the sheet specifies the device reports 1-500 for good air quality,
 *            but it's unknown if 0 is possible or what it might mean.
import groovy.transform.Field
@Field static final Integer CLUSTER_ON_OFF       = 0x0006
@Field static final Integer CLUSTER_LEVEL        = 0x0008
@Field static final Integer CLUSTER_COLOR        = 0x0300
@Field static final Integer CLUSTER_ILLUMINANCE  = 0x0400
@Field static final Integer CLUSTER_OCCUPANCY    = 0x0406
@Field static final Integer CLUSTER_TVOC         = 0x042E
metadata {
    definition(name: "THIRDREALITY Smart Presence Sensor R3", namespace: "openai v0.16", author: "OpenAI") {
        capability "Actuator"
        capability "Sensor"
        capability "Light"
        capability "Switch"
        capability "Switch Level"
        capability "ChangeLevel"
        capability "ColorControl"
        capability "MotionSensor"
        capability "IlluminanceMeasurement"
        capability "Refresh"
        capability "Configuration"
        attribute "occupancy", "enum", ["occupied", "clear"]
        attribute "AirQualityIndex", "number"
        attribute "AirQuality", "enum", ["good", "ventilate", "warning", "danger"]
        attribute "colorName", "string"
        fingerprint profileId: "0104", endpointId: "01",
            inClusters: "0000,0003,0004,0005,0006,0008,0012,0300,0400,0406,042E,1000",
            outClusters: "0019",
            manufacturer: "Third Reality, Inc",
            model: "3RPL01084Z",
            deviceJoinName: "THIRDREALITY Smart Presence Sensor R3"
    preferences {
        input name: "levelTransitionTime", type: "enum", title: "Level transition time (default: 1s)",
            options: [[500:"500 ms"], [1000:"1 s"], [1500:"1.5 s"], [2000:"2 s"], [5000:"5 s"]], defaultValue: 1000
        input name: "startLevelChangeRate", type: "enum", title: "Start level change rate (default: Fast)",
            options: [[25:"Slow"], [50:"Medium"], [100:"Fast"]], defaultValue: 100
        input name: "onTransitionTime", type: "enum", title: "On transition time (default: 1s)",
        input name: "offTransitionTime", type: "enum", title: "Off transition time (default: 1s)",
        input name: "rgbTransitionTime", type: "enum", title: "RGB transition time (default: 1s)",
        input name: "minimumLevel", type: "number", title: "Minimum level (default: 5%)",
            description: "Requested levels above 0% but below this minimum are raised to this value", defaultValue: 5, range: "0..100"
        input name: "colorStaging", type: "bool", title: "Enable color pre-staging when light is off", defaultValue: false
        input name: "hiRezHue", type: "bool", title: "Use hue in degrees (0-360) instead of percent", defaultValue: false
        input name: "autoRefreshMinutes", type: "enum", title: "Automatic refresh interval",
            options: [[0:"Disabled"], [1:"Every 1 minute"], [5:"Every 5 minutes"], [10:"Every 10 minutes"], [15:"Every 15 minutes"], [30:"Every 30 minutes"]], defaultValue: 0
        input name: "illuminanceMinDeltaLux", type: "number", title: "Illuminance deadband (Lux)",
            description: "Ignore smaller lux changes than this amount", defaultValue: 3, range: "0..1000"
        input name: "illuminanceMinSeconds", type: "number", title: "Minimum seconds between small illuminance reports",
            description: "Changes smaller than the deadband are ignored until this much time has passed", defaultValue: 30, range: "0..3600"
        input name: "tvocMinDelta", type: "number", title: "Air Quality Index deadband",
            description: "Ignore Air Quality Index changes smaller than this amount unless the Air Quality status band changes", defaultValue: 2, range: "0..10000"
        input name: "tvocMinSeconds", type: "number", title: "Minimum seconds between Air Quality Index reports",
            description: "Do not send changed Air Quality Index values more often than this, unless the Air Quality status band changes", defaultValue: 30, range: "0..3600"
        input name: "motionClearSeconds", type: "number", title: "Driver motion/presence clear timeout (seconds)",
            description: "0 = follow device clear reports only. Any value > 0 makes the driver clear motion/occupancy this many seconds after the last occupied report.", defaultValue: 0, range: "0..3600"
        input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
        input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
def installed() {
    log.info "installed..."
    sendEvent(name: "motion", value: "inactive")
    sendEvent(name: "occupancy", value: "clear")
    unschedule("syntheticMotionClear")
    scheduleAutoRefresh()
def updated() {
    log.info "updated..."
    log.warn "debug logging is: ${logEnable == true}"
    log.warn "description logging is: ${txtEnable == true}"
    log.warn "driver motion/presence clear timeout is: ${safeToInt(settings.motionClearSeconds, 0)} second(s)"
    if (logEnable) runIn(1800, "logsOff")
    if (safeToInt(settings.motionClearSeconds, 0) <= 0) unschedule("syntheticMotionClear")
def logsOff() {
    log.warn "debug logging disabled..."
    device.updateSetting("logEnable", [value: "false", type: "bool"])
private void scheduleAutoRefresh() {
    unschedule("refresh")
    Integer mins = safeToInt(settings.autoRefreshMinutes, 0)
    switch (mins) {
        case 1:
            runEvery1Minute("refresh")
            break
        case 5:
            runEvery5Minutes("refresh")
            break
        case 10:
            runEvery10Minutes("refresh")
            break
        case 15:
            runEvery15Minutes("refresh")
            break
        case 30:
            runEvery30Minutes("refresh")
            break
        default:
            break
    if (logEnable) log.debug "parse description: ${description}"
    if (!description || description.startsWith("catchall")) return
    Map descMap = zigbee.parseDescriptionAsMap(description)
    if (logEnable) log.debug "descMap: ${descMap}"
    if (!descMap?.clusterInt) return
    String descriptionText
    String name
    Object value
    String unit
    switch (descMap.clusterInt as Integer) {
        case CLUSTER_ON_OFF:
            if (descMap.attrInt == 0 && descMap.value != null) {
                value = hexToInt(descMap.value, 0) == 1 ? "on" : "off"
                name = "switch"
                descriptionText = (device.currentValue(name) == value) ?
                    "${device.displayName} is ${value}" :
                    "${device.displayName} was turned ${value}"
            break
        case CLUSTER_LEVEL:
                value = Math.round(hexToInt(descMap.value, 0) * 100 / 254.0)
                if ((value as Integer) > 0) state.lastNonZeroLevel = (value as Integer)
                unit = "%"
                name = "level"
                Integer current = safeToInt(device.currentValue(name), -1)
                descriptionText = (current == (value as Integer)) ?
                    "${device.displayName} is ${value}${unit}" :
                    "${device.displayName} was set to ${value}${unit}"
            break
        case CLUSTER_COLOR:
            return parseColorCluster(descMap)
        case CLUSTER_ILLUMINANCE:
                Integer raw = hexToInt(descMap.value, 0)
                Integer lux = raw > 0 ? Math.round(Math.pow(10, ((raw - 1) / 10000.0d))) : 0
                handleIlluminanceReport(lux)
            return
        case CLUSTER_OCCUPANCY:
                Boolean occupied = (raw & 0x01) == 0x01
                handleOccupancyReport(occupied)
            return
        case CLUSTER_TVOC:
                BigDecimal tvocValue = parseTvocValue(descMap)
                String rawString = "enc=${descMap.encoding ?: '??'} hex=${descMap.value}"
                if (logEnable) log.debug buildTvocDebugLine(descMap, tvocValue)
                if (tvocValue != null) {
                    Integer roundedValue = tvocValue.setScale(0, BigDecimal.ROUND_HALF_UP).toInteger()
                    handleTvocReport(roundedValue)
                } else if (logEnable) {
                    log.debug "Unable to parse Air Quality Index value from ${rawString}"
            break
        default:
            if (logEnable) log.debug "ignoring ${descMap.clusterId}:${descMap.attrId}"
            return
    if (descriptionText && name) {
        sendEventIfChanged(name, value, descriptionText, unit)
private Object parseColorCluster(Map descMap) {
    String name
    Object value
    String unit
    Integer rawValue = hexToInt(descMap.value, 0)
    switch (descMap.attrInt as Integer) {
        case 0: // hue
            if (hiRezHue) {
                value = Math.round(rawValue * 360 / 254)
                if ((value as Integer) == 361) value = 360
                unit = "°"
            } else {
                value = Math.round(rawValue / 254 * 100)
                unit = "%"
            name = "hue"
            state.lastHue = descMap.value
            descriptionText = (safeToInt(device.currentValue(name), -999) == (value as Integer)) ?
                "${device.displayName} ${name} is ${value}${unit}" :
                "${device.displayName} ${name} was set to ${value}${unit}"
            break
        case 1: // saturation
            unit = "%"
            name = "saturation"
            state.lastSaturation = descMap.value
            break
        case 8: // color mode
            value = rawValue == 2 ? "CT" : "RGB"
            name = "colorMode"
            descriptionText = "${device.displayName} ${name} is ${value}"
            break
        default:
            if (logEnable) log.debug "0x0300:${descMap.attrId}:${rawValue}"
            return
    if (name in ["hue", "saturation"]) {
        setGenericColorName()
private void handleOccupancyReport(Boolean occupied) {
    Integer clearSeconds = Math.max(0, safeToInt(settings.motionClearSeconds, 0))
    if (occupied) {
        sendEventIfChanged("motion", "active", "${device.displayName} motion is active", null)
        sendEventIfChanged("occupancy", "occupied", "${device.displayName} occupancy is occupied", null)
        state.lastOccupiedReportMs = now()
        if (clearSeconds > 0) {
            runIn(clearSeconds, "syntheticMotionClear")
            if (logEnable) log.debug "Scheduled synthetic motion clear in ${clearSeconds} second(s)"
    } else {
        sendEventIfChanged("motion", "inactive", "${device.displayName} motion is inactive", null)
        sendEventIfChanged("occupancy", "clear", "${device.displayName} occupancy is clear", null)
def syntheticMotionClear() {
    if (clearSeconds <= 0) return
    Long lastOccupiedMs = state.lastOccupiedReportMs != null ? (state.lastOccupiedReportMs as Long) : 0L
    Long elapsedMs = lastOccupiedMs > 0L ? (now() - lastOccupiedMs) : Long.MAX_VALUE
    Long targetMs = clearSeconds * 1000L
    if (elapsedMs < targetMs) {
        Integer remainingSeconds = Math.max(1, Math.ceil((targetMs - elapsedMs) / 1000.0d) as Integer)
        runIn(remainingSeconds, "syntheticMotionClear")
        return
    String motionCurrent = device.currentValue("motion")?.toString()
    String occupancyCurrent = device.currentValue("occupancy")?.toString()
    if (motionCurrent != "inactive" || occupancyCurrent != "clear") {
        if (txtEnable) log.info "${device.displayName} motion/presence was cleared by driver timeout (${clearSeconds}s)"
private void handleTvocReport(Integer tvoc) {
    Integer minDelta = Math.max(0, safeToInt(settings.tvocMinDelta, 2))
    Integer minSeconds = Math.max(0, safeToInt(settings.tvocMinSeconds, 30))
    Long nowMs = now()
    Integer lastReportedTvoc = state.lastReportedTvoc != null ? safeToInt(state.lastReportedTvoc, tvoc) : null
    Long lastReportMs = state.lastTvocReportMs != null ? (state.lastTvocReportMs as Long) : 0L
    String status = classifyTvoc(tvoc)
    String currentStatus = device.currentValue("AirQuality")?.toString()
    Boolean shouldSendValue = false
    if (lastReportedTvoc == null) {
        shouldSendValue = true
    } else if (currentStatus != status) {
    } else {
        Integer delta = Math.abs(tvoc - lastReportedTvoc)
        Long elapsedMs = nowMs - lastReportMs
        if (delta >= minDelta && elapsedMs >= (minSeconds * 1000L)) {
    sendEventIfChanged("AirQuality", status, "${device.displayName} Air Quality is ${status}", null)
    if (shouldSendValue) {
        state.lastReportedTvoc = tvoc
        state.lastTvocReportMs = nowMs
        sendEventIfChanged("AirQualityIndex", tvoc, "${device.displayName} Air Quality Index is ${tvoc} (${status})", null)
        log.debug "Filtered Air Quality Index report: ${tvoc} (${status})"
private void handleIlluminanceReport(Integer lux) {
    Integer minDelta = Math.max(0, safeToInt(settings.illuminanceMinDeltaLux, 3))
    Integer minSeconds = Math.max(0, safeToInt(settings.illuminanceMinSeconds, 30))
    Long nowMs = now()
    Integer lastReportedLux = state.lastReportedIlluminanceLux != null ? safeToInt(state.lastReportedIlluminanceLux, lux) : null
    Long lastReportMs = state.lastIlluminanceReportMs != null ? (state.lastIlluminanceReportMs as Long) : 0L
    Boolean shouldSend = false
    if (lastReportedLux == null) {
        shouldSend = true
    } else {
        Integer delta  = Math.abs(lux - lastReportedLux)
        if (delta >= minDelta) {
            shouldSend = true
        } else if (lux != lastReportedLux && elapsedMs >= (minSeconds * 1000L)) {
            shouldSend = true
    if (shouldSend) {
        state.lastReportedIlluminanceLux = lux
        state.lastIlluminanceReportMs = nowMs
        sendEventIfChanged("illuminance", lux, "${device.displayName} illuminance is ${lux} Lux", "Lux")
        log.debug "Filtered illuminance report: ${lux} Lux"
private String buildTvocDebugLine(Map descMap, BigDecimal tvocValue) {
    String hex       = (descMap?.value ?: "").toString()
    Integer encoding = hexToInt(descMap?.encoding, -1)
    Float fBig       = decodeFloatBigEndian(hex)
    Float fLittle    = decodeFloatLittleEndian(hex)
    Long unsignedVal = null
    Long signedVal   = null
    try {
        unsignedVal = parseUnsignedHex(hex)
    } catch (ignored) { }
    try {
        signedVal = parseSignedHex(hex, Math.max(1, (hex?.length() ?: 0) / 2))
    String status = tvocValue != null ? classifyTvoc(tvocValue.setScale(0, BigDecimal.ROUND_HALF_UP).toInteger()) : null
    return "Air Quality Index 0x042E debug: enc=${String.format('0x%02X', encoding)} hex=${hex} unsigned=${unsignedVal} signed=${signedVal} floatBE=${fBig} floatLE=${fLittle} decoded=${tvocValue} status=${status}"
private BigDecimal parseTvocValue(Map descMap) {
    Integer encoding = hexToInt(descMap.encoding, -1)
    String hex = descMap.value ?: ""
    if (!hex) return null
    switch (encoding) {
        case 0x39: // single-precision float; likely ppm
            Float f1     = decodeFloatBigEndian(hex)
            Float f2     = decodeFloatLittleEndian(hex)
            Float chosen = chooseReasonableFloat(f1, f2)
            if (chosen == null) return null
            return BigDecimal.valueOf(chosen as Double)
        case 0x20: // uint8
        case 0x21: // uint16
        case 0x22: // uint24
        case 0x23: // uint32
            return BigDecimal.valueOf(parseUnsignedHex(hex))
        case 0x28: // int8
        case 0x29: // int16
        case 0x2A: // int24
        case 0x2B: // int32
            return BigDecimal.valueOf(parseSignedHex(hex, hex.length() / 2))
        default:
            // Fall back to unsigned integer interpretation; this matches how many Hubitat descMap values appear.
            try {
            } catch (ignored) {
                return null
private static String classifyTvoc(Integer value) {
    if (value == null) return null
    if (value == 0)  return "possible error"
    if (value <= 500)  return "good"
    if (value <= 1000) return "ventilate"
    if (value <= 3000) return "warning"
    return "danger"
private static Float chooseReasonableFloat(Float a, Float b) {
    List<Float> candidates = [a, b].findAll { it != null && !it.isNaN() && !it.isInfinite() && it >= 0.0f && it < 10000.0f }
    if (!candidates) return null
    // Prefer a practical non-subnormal value; cluster 0x042E reports on this device are arriving as
    // IEEE-754 values like 41.0 / 42.0 / 60.0, while the opposite endianness decodes to tiny near-zero noise.
    List<Float> practical = candidates.findAll { it >= 0.001f }
    if (practical) return practical.max()
    return candidates.max()
private static Float decodeFloatBigEndian(String hex) {
    try {
        int bits = (int) Long.parseLong(hex, 16)
        return Float.intBitsToFloat(bits)
    } catch (ignored) {
        return null
private static Float decodeFloatLittleEndian(String hex) {
    try {
        return Float.intBitsToFloat(Integer.reverseBytes(bits))
    } catch (ignored) {
        return null
private static Long parseUnsignedHex(String hex) {
    return Long.parseLong(hex, 16)
private static Long parseSignedHex(String hex, Integer bytes) {
    long unsigned  = Long.parseLong(hex, 16)
    long signBit   = 1L << ((bytes * 8) - 1)
    long fullRange = 1L << (bytes * 8)
    return (unsigned & signBit) ? (unsigned - fullRange) : unsigned
private void setGenericColorName() {
    Integer hue = safeToInt(device.currentValue("hue"), 0)
    Integer sat = safeToInt(device.currentValue("saturation"), 100)
    if (!hiRezHue) hue = Math.round(hue * 3.6)
    String colorName
    switch (hue) {
        case 0..15:    colorName = "Red";        break
        case 16..45:   colorName = "Orange";     break
        case 46..75:   colorName = "Yellow";     break
        case 76..105:  colorName = "Chartreuse"; break
        case 106..135: colorName = "Green";      break
        case 136..165: colorName = "Spring";     break
        case 166..195: colorName = "Cyan";       break
        case 196..225: colorName = "Azure";      break
        case 226..255: colorName = "Blue";       break
        case 256..285: colorName = "Violet";     break
        case 286..315: colorName = "Magenta";    break
        case 316..345: colorName = "Rose";       break
        default:       colorName = "Red";        break
    if (sat == 0) colorName = "White"
    sendEventIfChanged("colorName", colorName, "${device.displayName} color is ${colorName}", null)
def on() {
    if (logEnable) log.debug "on()"
    Integer transitionMs = getConfiguredTransitionMs("onTransitionTime", 1000)
    Integer targetLevel  = resolveOnLevelPercent()
    Integer zigbeeLevel  = scalePercentToZigbeeLevel(targetLevel)
    Integer transition   = transitionMsToTenths(transitionMs)
    Integer delayMs      = Math.max(400, transitionMs + 400)
    return [
        "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0008 4 {0x${intTo8bitUnsignedHex(zigbeeLevel)} 0x${intTo16bitUnsignedHexLE(transition)}}",
        "delay ${delayMs}",
        readAttrCmd(CLUSTER_ON_OFF, 0x0000),
        "delay 200",
        readAttrCmd(CLUSTER_LEVEL,  0x0000)
def off() {
    if (logEnable) log.debug "off()"
    Integer transitionMs = getConfiguredTransitionMs("offTransitionTime", 1000)
    return [
        "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0008 4 {0x00 0x${intTo16bitUnsignedHexLE(transition)}}",
        "delay ${delayMs}",
        "delay 200",
def startLevelChange(direction) {
    if (logEnable) log.debug "startLevelChange(${direction})"
    Integer upDown = direction == "down" ? 1 : 0
    Integer unitsPerSecond = Math.max(1, safeToInt(settings.startLevelChangeRate, 100))
    return "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0008 1 { 0x${intTo8bitUnsignedHex(upDown)} 0x${intTo16bitUnsignedHexLE(unitsPerSecond)} }"
def stopLevelChange() {
    if (logEnable) log.debug "stopLevelChange()"
    return [
        "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0008 3 {}",
        "delay 200",
def setLevel(value) {
    if (logEnable) log.debug "setLevel(${value})"
    return setLevel(value, getConfiguredTransitionSeconds("levelTransitionTime", 1.0G))
def setLevel(value, rate) {
    if (logEnable) log.debug "setLevel(${value}, ${rate})"
    Integer requestedLevel = Math.max(0, Math.min(100, safeToInt(value, 0)))
    Integer level = clampLevelPercent(requestedLevel)
    BigDecimal defaultRateSeconds = getConfiguredTransitionSeconds("levelTransitionTime", 1.0G)
    BigDecimal rateSeconds = hasMeaningfulValue(rate) ? safeToBigDecimal(rate, defaultRateSeconds) : defaultRateSeconds
    if (rateSeconds <= 0) rateSeconds = defaultRateSeconds > 0 ? defaultRateSeconds : 1.0G
    Integer scaledRate  = Math.max(1, (rateSeconds * 10).toInteger())
    Integer zigbeeLevel = scalePercentToZigbeeLevel(level)
    Boolean isOn    = device.currentValue("switch") == "on"
    Integer delayMs = Math.max(400, (rateSeconds * 1000).toInteger() + 400)
    if (level > 0) state.lastNonZeroLevel = level
    if (isOn) {
        return [
            "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0008 4 {0x${intTo8bitUnsignedHex(zigbeeLevel)} 0x${intTo16bitUnsignedHexLE(scaledRate)}}",
            "delay ${delayMs}",
    } else {
        return [
            "delay ${delayMs}",
            "delay 200",
def setColor(Map value) {
    if (logEnable) log.debug "setColor(${value})"
    if (value?.hue == null || value?.saturation == null) return
    Integer hueInput   = safeToInt(value.hue, 0)
    Integer satInput   = safeToInt(value.saturation, 100)
    Integer levelInput = value.level != null ? clampLevelPercent(safeToInt(value.level, 100)) : null
    Integer requestedRateSeconds = value.rate != null ? safeToInt(value.rate, 0) : 0
    Integer rateMs = requestedRateSeconds > 0 ? (requestedRateSeconds * 1000) : getConfiguredTransitionMs("rgbTransitionTime", 1000)
    String hexHue = hiRezHue ?
        zigbee.convertToHexString(Math.round(hueInput / 360.0 * 254).toInteger(), 2) :
        zigbee.convertToHexString(Math.round(hueInput / 100.0 * 254).toInteger(), 2)
    String hexSat = zigbee.convertToHexString(Math.round(satInput / 100.0 * 254).toInteger(), 2)
    List<String> cmds = []
    Integer transition = transitionMsToTenths(rateMs)
    Integer zigbeeLevel = levelInput != null ? scalePercentToZigbeeLevel(levelInput) : null
    if (levelInput != null && levelInput > 0) state.lastNonZeroLevel = levelInput
    if (isOn) {
        cmds << "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0300 0x06 {${hexHue} ${hexSat} ${intTo16bitUnsignedHexLE(transition)}}"
        if (zigbeeLevel != null) {
            cmds << "delay 200"
            cmds << "he cmd 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0008 4 {0x${intTo8bitUnsignedHex(zigbeeLevel)} 0x${intTo16bitUnsignedHexLE(transition)}}"
            cmds << "delay ${rateMs + 400}"
            cmds << readAttrCmd(CLUSTER_COLOR, 0x0000)
            cmds << "delay 200"
            cmds << readAttrCmd(CLUSTER_COLOR, 0x0001)
            cmds << "delay 200"
            cmds << readAttrCmd(CLUSTER_LEVEL, 0x0000)
        } else {
            cmds << "delay 200"
    } else if (colorStaging) {
        cmds << "delay ${Math.max(200, rateMs + 200)}"
        cmds << "delay 200"
    } else if (zigbeeLevel != null) {
        cmds << "delay 200"
        cmds << readAttrCmd(CLUSTER_ON_OFF, 0x0000)
        cmds << "delay 200"
        cmds << "delay 200"
        cmds << "delay 200"
    } else {
        cmds << "delay 200"
        cmds << on()
        cmds = cmds.flatten()
    state.lastHue = hexHue
    state.lastSaturation = hexSat
    return cmds
def setHue(value) {
    if (logEnable) log.debug "setHue(${value})"
    setColor([hue: value, saturation: safeToInt(device.currentValue("saturation"), 100), level: safeToInt(device.currentValue("level"), 100)])
def setSaturation(value) {
    if (logEnable) log.debug "setSaturation(${value})"
    setColor([hue: safeToInt(device.currentValue("hue"), 0), saturation: value, level: safeToInt(device.currentValue("level"), 100)])
def refresh() {
    if (logEnable) log.debug "refresh()"
    return [
        readAttrCmd(CLUSTER_ON_OFF, 0x0000),      "delay 200",
        readAttrCmd(CLUSTER_LEVEL,  0x0000),      "delay 200",
        readAttrCmd(CLUSTER_COLOR,  0x0000),      "delay 200",
        readAttrCmd(CLUSTER_COLOR,  0x0001),      "delay 200",
        readAttrCmd(CLUSTER_ILLUMINANCE, 0x0000), "delay 200",
        readAttrCmd(CLUSTER_OCCUPANCY,   0x0000), "delay 200",
        readAttrCmd(CLUSTER_TVOC,   0x0000)
def configure() {
    log.warn "configure..."
    // Bind standard reporting clusters to the hub.
    cmds += [
        "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x0006 {${device.zigbeeId}} {}",
        "delay 200",
        "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x0008 {${device.zigbeeId}} {}",
        "delay 200",
        "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x0300 {${device.zigbeeId}} {}",
        "delay 200",
        "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x0400 {${device.zigbeeId}} {}",
        "delay 200",
        "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x0406 {${device.zigbeeId}} {}",
        "delay 200",
        "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x042E {${device.zigbeeId}} {}",
        "delay 200"
    // Configure reporting where datatype is known or strongly expected.
    cmds += zigbee.configureReporting(CLUSTER_ON_OFF,      0x0000, 0x10, 0,  3600, null)
    cmds += zigbee.configureReporting(CLUSTER_LEVEL,       0x0000, 0x20, 1,  3600, 1)
    cmds += zigbee.configureReporting(CLUSTER_COLOR,       0x0000, 0x20, 1,  3600, 1)
    cmds += zigbee.configureReporting(CLUSTER_COLOR,       0x0001, 0x20, 1,  3600, 1)
    cmds += zigbee.configureReporting(CLUSTER_ILLUMINANCE, 0x0000, 0x21, 30, 300,  50)
    cmds += zigbee.configureReporting(CLUSTER_OCCUPANCY,   0x0000, 0x18, 0,  3600, 1)
    cmds += refresh()
    return cmds
private Integer getConfiguredTransitionMs(String settingName, Integer defaultMs = 1000) {
    Object configured = settings?.get(settingName)
    Integer ms = safeToInt(configured, defaultMs)
    return ms > 0 ? ms : defaultMs
private BigDecimal getConfiguredTransitionSeconds(String settingName, BigDecimal defaultSeconds = 1.0G) {
    Integer ms = getConfiguredTransitionMs(settingName, (defaultSeconds * 1000).toInteger())
    return BigDecimal.valueOf(ms / 1000.0d)
private Integer transitionMsToTenths(Integer ms) {
    Integer safeMs = Math.max(0, ms ?: 0)
    return Math.max(0, (int) Math.round(safeMs / 100.0d))
private Integer getMinimumLevelPercent() {
    Integer minLevel = safeToInt(settings.minimumLevel, 5)
    return Math.max(0, Math.min(100, minLevel))
private Integer clampLevelPercent(Integer level) {
    Integer safeLevel = Math.max(0, Math.min(100, level ?: 0))
    if (safeLevel == 0) return 0
    Integer minLevel = getMinimumLevelPercent()
    return Math.max(minLevel, safeLevel)
private Integer resolveOnLevelPercent() {
    Integer currentLevel = safeToInt(device.currentValue("level"), 0)
    Integer rememberedLevel = safeToInt(state.lastNonZeroLevel, 100)
    Integer candidate = currentLevel > 0 ? currentLevel : (rememberedLevel > 0 ? rememberedLevel : 100)
    return clampLevelPercent(candidate)
private Integer scalePercentToZigbeeLevel(Integer levelPercent) {
    Integer safeLevel = Math.max(0, Math.min(100, levelPercent ?: 0))
    return Math.round(safeLevel * 254 / 100.0d)
private Boolean hasMeaningfulValue(Object value) {
    if (value == null) return false
    if (value instanceof String) return value.toString().trim() != ""
    return true
private String readAttrCmd(Integer cluster, Integer attrId) {
    return "he rattr 0x${device.deviceNetworkId} 0x${device.endpointId} 0x${zigbee.convertToHexString(cluster, 4)} 0x${zigbee.convertToHexString(attrId, 4)} {}"
private Boolean sendEventIfChanged(String name, Object value, String descriptionText = null, String unit = null) {
    if (name == null) return false
    String current = device.currentValue(name)?.toString()
    String incoming = value?.toString()
    if (current == incoming) return false
    Map evt = [name: name, value: value]
    if (descriptionText != null) evt.descriptionText = descriptionText
    if (unit != null) evt.unit = unit
    sendEvent(evt)
    if (txtEnable && descriptionText) log.info descriptionText
    return true
private static Integer hexToInt(Object value, Integer defaultValue = 0) {
    try {
        if (value == null) return defaultValue
        String s = value.toString().trim()
        if (!s) return defaultValue
        if (s.startsWith("0x") || s.startsWith("0X")) s = s.substring(2)
        return Integer.parseInt(s, 16)
    } catch (ignored) {
        return defaultValue
private static Integer safeToInt(Object value, Integer defaultValue = 0) {
    try {
        if (value instanceof Number) return ((Number) value).intValue()
        if (s.startsWith("0x") || s.startsWith("0X")) return Integer.parseInt(s.substring(2), 16)
        if (s ==~ /[0-9A-Fa-f]+/ && s.length() > 1 && !(s ==~ /\d+/)) return Integer.parseInt(s, 16)
        return Integer.parseInt(s)
    } catch (ignored) {
        return defaultValue
private static BigDecimal safeToBigDecimal(Object value, BigDecimal defaultValue = 0G) {
    try {
        if (value instanceof BigDecimal) return (BigDecimal) value
        if (value instanceof Number) return new BigDecimal(value.toString())
        return new BigDecimal(s)
    } catch (ignored) {
        return defaultValue
private String intTo8bitUnsignedHex(Object value) {
    return zigbee.convertToHexString(safeToInt(value, 0) & 0xFF, 2)
private String intTo16bitUnsignedHex(Object value) {
    return zigbee.convertToHexString(safeToInt(value, 0) & 0xFFFF, 4)
private String intTo16bitUnsignedHexLE(Object value) {
    String hex = intTo16bitUnsignedHex(value)
    return hex.substring(2, 4) + hex.substring(0, 2)
ordered one to try thanks for the beta driver
See new 2026-03-24 version above.
built in now in latest beta
Can't wait for the beta to be released but the driver posted here seems to be working fine. Just received my sensor today and it paired as a "device" added your driver @John_Land. Going to be testing the Lux and occupancy all weekend and into next week. Need to augment my mmWave Inovelli switches in rooms that the switches aren't in the right location for occupancy sensing. If this works out I will order a few more.
