Continuing the discussion from [BETA] Echo Speaks V4:
@672southmain Do I need to do something similar with this pad?
UPDATE : Yep, this worked to get my new pad speaking text. Thanks @672southmain
You ought to either put in a PR on GitHub for this change or else post in the Echo Speaks v4 thread, tagging @tonesto7 (the developer) so that this change gets folded into the base code so that everyone can benefit.
It will also save you work in the long run. Otherwise, you will have to make this same change to your code copy each time an update is released to Echo Speaks.
Good idea. I made a post in the ES v4 thread and tagged tonesto7. Thanks for the tip.
