Dear Colleague,
I see that on Aliexpress is new multisensor with CO2.
Someone of you try to connect with habitat?
https://www.aliexpress.com/item/1005005183166662.html?spm=a2g0o.cart.0.0.f48e38da69UlOc&mp=1
Based on this feedback looks we should be able to connect.
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
kkossev
February 12, 2024, 7:26am
2
These cheap Tuya sensors are known to be extremely chatty , spamming the ZIgbee network with several messages per second.
I highly recommend NOT using these Tuya CO2 sensors paired directly to Hubitat.
do you think that will be completely the same inside?
i know that old Tuya is very bad.
kkossev
February 12, 2024, 8:27am
4
If you have a second HE hub to isolate this device from the others, you could use it.
See the comments on the seller’s site - talking about its spamming behaviour.
Do you think that is not possible to bloc by drivers this abnormal communication?
TomG
February 12, 2024, 4:33pm
7
A review on AE mentions the chatiness.
I have a Tuya air quality sensor in ‘the drawer’ that is also very talkative.
I have two of these IKEA VINDSTRYKA sensors
The driver is ‘VINDSTRYKA Air Quality Monitor’ from @kkossev
You can see when my wife is cooking.
Correction - this does NOT measure CO2
this is zigbee? or need some integration?
aaiyar
February 12, 2024, 7:45pm
10
damianPL:
this is zigbee?
It is zigbee, but AFAIK, it doesn't measure CO2. It does:
PM2.5, tVOC, RH, Temperature
TomG
February 15, 2024, 3:26pm
11
aaiyar:
doesn’t measure CO2
You are correct. I missed the OP’s requirement of CO2
