This issue still exists. Why cant the 'hub details' coordinates for each hub be queried and loaded for that selected hub in the app? So geofence not going to work for me, still.
You can manually move the pin. But if that location sticks when you switch hubs then you would need to move it every time you change locations. May or may not be a deal breaker.
Its a deal breaker, moving the pin everytime I change location then what the purpose of geofence.
The mobile app only supports one Geofence at the moment. While connected to the second hub, you can change the pin around, the settings are not saved. Only one device, one hub work at the same time. Additional Geofence is on the future enhancements but there is no time-frame when the enhancement will be implemented at this time.
The app currently only supports one Geofence (see above comment).
OK, thanks. Will keep an eye out for future capability.
