An unexpected error has occurred trying to load the app.
When trying to start google sdm api
You'd be better off posting in the thread for the app:
@user1663 I'm guessing this is the same as this GitHub issue?
In both cases, I will need a bit more information in order to diagnose the problem. Any additional errors listed in the browser? Or error logs generated in the Hubitat logs?
app:9102023-01-15 11:25:32.947 AMerrorgroovy.json.internal.Exceptions$JsonInternalException: unexpected character r on line 198 (method uninstalled)
app:9102023-01-15 11:25:18.364 AMerrorgroovy.json.internal.Exceptions$JsonInternalException: unexpected character r on line 198 (method mainPage)
app:9102023-01-15 11:25:15.127 AMerrorgroovy.json.internal.Exceptions$JsonInternalException: unexpected character r on line 198 (method
Looks like a problem with the credentials.json input. I can make this more robust, but in the short term, remove the existing App install in Hubitat. Then re-install and make sure this input is valid JSON.
Should i get another json?
Can i just open the json in a editor and transpose?
Yes, copy and paste the contents of the file into this input field. You can use a site such as jsoneditoronline.com to validate it. If it is not valid JSON, then yes, I would recommend to retry the download from Google.
