Neo Coolcam Power Plug
With the latest 2.0.2 release, I see support for Neo Coolcam Power Plug. Can this driver be used with the Zooz Z-Wave Plus Mini Plug ZEN07 as well?
@mike.maxwell
no idea, give it a shot...
Neo changed some configuration parameters so the Zooz Mini Plug is most likely more compatible with the Dome On Off plug...
Here's a partial port that I did in a few minutes and haven't tested, but it might work. You'll have to manually change the type because I didn't change the fingerprint.
 *  Neo Coolcam Power Plug v1.2.5
 *  (Models: NAS-WR02ZU, NAS-WR02ZE, NAS-WR01ZE)
 *  Author:
 *    Kevin LaFramboise (krlaframboise)
 *  URL to documentation: https://community.smartthings.com/t/release-neo-coolcam-power-plug/144274?u=krlaframboise
 *  Changelog:
 *    1.2.5 (02/25/2019)
 *      - ***WARNING*** because of the paramater number changes mentioned below I had to change the setting names causing all the settings to revert back to their default values.
 *      - Added support for new EU model that has different config params.
 *      	- All param numbers changed so numbers are determined by the "prod" in raw description.
 *      	- Meter Reporting Threshold changed from (0-100%) to (0.01-16A) so still displaying percentage settings, but performing conversion to A for new model before sending to device.
 *      	- Meter Reporting Interval range changed from (1-65535) to (30-32767) so removed options that are not supported by both models.
 *      	- Switch Timer Period maximum value changed from 65535 to 32767 so removed options that are not supported by both models.
 *      	- The options that were removed were just commented out so if you have the original model you can find them near the bottom of the code in the "Setting Options" section and uncomment them.
 *    1.1 (01/30/2019)
 *      - Added security encapsulation because the latest EU version of this device supports it.
 *    1.0 (11/29/2018)
 *      - Initial Release
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (
		name: "Neo Coolcam Power Plug",
		namespace: "krlaframboise",
		author: "Kevin LaFramboise",
		vid:"generic-switch-power-energy"
		capability "Actuator"
		capability "Sensor"
		capability "Switch"
		capability "Outlet"
		capability "Power Meter"
		capability "Energy Meter"
		capability "Voltage Measurement"
		capability "Configuration"
		capability "Refresh"
		capability "Health Check"
		attribute "lastCheckin", "string"
		attribute "syncStatus", "string"
		attribute "history", "string"
		attribute "current", "number"
		attribute "energyTime", "number"
		attribute "energyDuration", "string"
		["power", "voltage", "current"].each {
			attribute "${it}Low", "number"
			attribute "${it}High", "number"
		command "reset"
		fingerprint mfr: "0258", prod: "0003", model: "0087", deviceJoinName: "NEO Coolcam Power Plug"
		fingerprint mfr: "0258", prod: "0003", model: "1087", deviceJoinName: "NEO Coolcam Power Plug"  //EU
		fingerprint mfr: "0258", prod: "0200", model: "1027", deviceJoinName: "NEO Coolcam Power Plug" // New EU
	simulator { }
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00a0dc"
				attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
		standardTile("refresh", "device.refresh", width: 2, height: 2) {
			state "refresh", label:'Refresh', action: "refresh"
		standardTile("reset", "device.reset", width: 2, height: 2) {
			state "refresh", label:'Reset', action: "reset"
		valueTile("energy", "device.energy", width: 2, height: 2) {
			state "energy", label:'${currentValue} kWh', backgroundColor: "#cccccc"
		valueTile("power", "device.power", width: 2, height: 2) {
			state "power", label:'${currentValue} W', backgroundColor: "#cccccc"
		valueTile("voltage", "device.voltage", width: 2, height: 2) {
			state "voltage", label:'${currentValue} V', backgroundColor: "#cccccc"
		valueTile("current", "device.current", width: 2, height: 2) {
			state "current", label:'${currentValue} A', backgroundColor: "#cccccc"
		valueTile("syncStatus", "device.syncStatus", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "syncStatus", label:'${currentValue}'
		standardTile("sync", "device.configure", width: 2, height: 2) {
			state "default", label: 'Sync', action: "configure"
		valueTile("history", "device.history", decoration:"flat",width: 4, height: 4) {
			state "history", label:'${currentValue}'
		main "switch"
		details(["switch", "power", "voltage", "current", "energy", "syncStatus", "sync", "history", "refresh", "reset"])
	preferences {
		getParamInput(meterReportsEnabledParam)
		getParamInput(meterReportingIntervalParam)
		getParamInput(powerReportingThresholdParam)
		getParamInput(ledEnabledParam)
		getParamInput(physicalButtonEnabledParam)
		getParamInput(rememberSwitchStateParam)
		getParamInput(overloadProtectionParam)
		getParamInput(overloadAlarmParam)
		getParamInput(switchTimerEnabledParam)
		getParamInput(switchTimerPeriodParam)
		input "debugOutput", "bool",
			title: "Enable Debug Logging",
			defaultValue: true,
			required: false
private getParamInput(param) {
	input "${param.pref}", "enum",
		title: "${param.name}:",
		required: false,
		defaultValue: "${param.value}",
		options: param.options
// Meters
private getMeterEnergy() {
	return getMeterMap("energy", 0, "kWh")
private getMeterPower() {
	return getMeterMap("power", 2, "W")
private getMeterVoltage() {
	return getMeterMap("voltage", 4, "V")
private getMeterCurrent() {
	return getMeterMap("current", 5, "A")
private getMeterMap(name, scale, unit) {
	return [name:name, scale:scale, unit:unit]
def installed() {
	logDebug "installed()..."
	state.refreshConfig = true
	state.newModel = isNewModel()
	return refresh()
def updated() {
	if (!isDuplicateCommand(state.lastUpdated, 3000)) {
		state.lastUpdated = new Date().time
		logDebug "updated()..."
		return executeConfigure()
def configure() {
	logDebug "configure()..."
	runIn(2, executeConfigure)
def executeConfigure() {
	def cmds = []
	if (state?.newModel == null) {
	if (!device.currentValue("switch")) {
		cmds += reset()
	configParams.each { param ->
		def storedVal = getParamStoredValue(param.num)
		def paramVal = param.value
		if (param == overloadAlarmParam && overloadProtectionParam.value <= paramVal) {
			log.warn "Unable to set Current Overload Alarm Threshold to ${paramVal} because it must be lower than Current Overload Protection Threshold"
			paramVal = (overloadProtectionParam.value - 1)
		if (state.newModel && param.num == powerReportingThresholdParam.num) {
			paramVal = getNewModelPowerReportingThreshold(paramVal)
		if (state.refreshConfig || "${storedVal}" != "${paramVal}") {
			logDebug "Changing ${param.name}(#${param.num}) from ${storedVal} to ${paramVal}"
			cmds << configSetCmd(param, paramVal)
			cmds << configGetCmd(param)
	state.refreshConfig = false
	return cmds ? delayBetween(cmds, 500) : []
private getNewModelPowerReportingThreshold(oldModelVal) {
	def newModelVal
	if (oldModelVal == 0) {
		// new model doesn't support disabled so using least frequent reporting instead
		newModelVal = 1600
	else {
		// New model supports 1-1600 (x0.01A) instead of 0-100%
		newModelVal = Math.round((oldModelVal / 100) * 1600)
	return newModelVal
// private sendCommands(cmds) {
	// def actions = []
	// cmds?.each {
		// actions << new hubitat.device.HubAction(it)
	// sendHubCommand(actions, 500)
	// return []
void updateHealthCheckInterval() {
	def minInterval = minReportingInterval
	if (state.minReportingInterval != minInterval) {
		state.minReportingInterval = minInterval
		// Set the Health Check interval so that it can be skipped twice plus 5 minutes.
		def checkInterval = ((minInterval * 3) + (5 * 60))
		def eventMap = getEventMap("checkInterval", checkInterval, false)
		eventMap.data = [protocol: "zwave", hubHardwareId: device.hub.hardwareID]
		sendEvent(eventMap)
private getMinReportingInterval() {
	if (meterReportsEnabledParam.val) {
		return meterReportingIntervalParam.val
	else {
		return (60 * 60 * 12)
def ping() {
	logDebug "Pinging device because it has not checked in"
	return [switchBinaryGetCmd()]
def on() {
	logDebug "on()..."
	return delayBetween([
		basicSetCmd(0xFF),
		basicGetCmd()
	], 100)
def off() {
	logDebug "off()..."
		basicSetCmd(0x00),
		basicGetCmd()
	], 100)
def refresh() {
	logDebug "refresh()..."
	refreshSyncStatus()
		switchBinaryGetCmd(),
		meterGetCmd(meterEnergy),
		meterGetCmd(meterPower),
		meterGetCmd(meterVoltage),
		meterGetCmd(meterCurrent)
	], 500)
def reset() {
	logDebug "reset()..."
		sendEvent(getEventMap("${it}Low", getAttrVal(it), false))
		sendEvent(getEventMap("${it}High", getAttrVal(it), false))
	sendEvent(getEventMap("energyTime", new Date().time, false))
	def result = []
	result << meterResetCmd()
	result << "delay 500"
	result += refresh()
	return result
private meterGetCmd(meter) {
	return secureCmd(zwave.meterV3.meterGet(scale: meter.scale))
private meterResetCmd() {
	return secureCmd(zwave.meterV3.meterReset())
private basicGetCmd() {
	return secureCmd(zwave.basicV1.basicGet())
private basicSetCmd(val) {
	return secureCmd(zwave.basicV1.basicSet(value: val))
private switchBinaryGetCmd() {
	return secureCmd(zwave.switchBinaryV1.switchBinaryGet())
private switchBinarySetCmd(val) {
	return secureCmd(zwave.switchBinaryV1.switchBinarySet(switchValue: val))
private configSetCmd(param, value) {
	return secureCmd(zwave.configurationV1.configurationSet(parameterNumber: param.num, size: param.size, configurationValue: intToHexBytes(value, param.size)))
private configGetCmd(param) {
	return secureCmd(zwave.configurationV1.configurationGet(parameterNumber: param.num))
private secureCmd(cmd) {
	if (getDataValue("zwaveSecurePairingComplete") == "true") {
		return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
	else {
		return cmd.format()
private getCommandClassVersions() {
		0x20: 1,	// Basic
		0x25: 1,	// Switch Binary
		0x27: 1,	// All Switch
		0x32: 3,	// Meter v4
		0x55: 1,	// Transport Service
		0x59: 1,	// AssociationGrpInfo
		0x5A: 1,	// DeviceResetLocally
		0x5E: 2,	// ZwaveplusInfo
		0x6C: 1,	// Supervision
		0x70: 1,	// Configuration
		0x71: 3,  // Notification v8
		0x72: 2,	// ManufacturerSpecific
		0x73: 1,	// Powerlevel
		0x85: 2,	// Association
		0x86: 1,	// Version (2)
		0x8E: 2,	// Multi Channel Association
		0x98: 1,	// Security 0
		0x9F: 1		// Security S2
	def result = []
	def cmd = zwave.parse(description, commandClassVersions)
	if (cmd) {
		result += zwaveEvent(cmd)
	else {
		log.warn "Unable to parse: $description"
	if (!isDuplicateCommand(state.lastCheckinTime, 60000)) {
		state.lastCheckinTime = new Date().time
		sendEvent(getEventMap("lastCheckin", convertToLocalTimeString(new Date()), false))
	return result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCmd = cmd.encapsulatedCommand(commandClassVersions)
	def result = []
	if (encapsulatedCmd) {
		result += zwaveEvent(encapsulatedCmd)
	else {
		log.warn "Unable to extract encapsulated cmd from $cmd"
	return result
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
	logTrace "ConfigurationReport ${cmd}"
	updateSyncingStatus()
	runIn(4, refreshSyncStatus, [overwrite: true])
	def param = configParams.find { it.num == cmd.parameterNumber }
	if (param) {
		def val = hexBytesToInt(cmd.configurationValue,cmd.size)
		logDebug "${param.name}(#${param.num}) = ${val}"
		setParamStoredValue(param.num, val)
		// if (param == meterReportsEnabledParam || param == meterReportingIntervalParam) {
			// updateHealthCheckInterval()
	else {
		logDebug "Parameter #${cmd.parameterNumber} = ${cmd.configurationValue}"
	return []
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
	logTrace "SwitchBinaryReport: ${cmd}"
	sendSwitchEvent(cmd.value, "physical")
	return []
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	logTrace "BasicReport: ${cmd}"
	sendSwitchEvent(cmd.value, "digital")
	return []
private sendSwitchEvent(value, type) {
	def eventVal = (value == 0xFF) ? "on" : "off"
	def map = getEventMap("switch", eventVal, null, "Switch is ${eventVal}")
	map.type = type
	sendEvent(map)
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd) {
	logTrace "MeterReport: $cmd"
	def val = roundTwoPlaces(cmd.scaledMeterValue)
	if (val >= 0) {
		def meter
		switch (cmd.scale) {
			case meterEnergy.scale:
				sendEvent(getEventMap("energyDuration", calculateEnergyDuration(), false))
				meter = meterEnergy
				break
			case meterPower.scale:
				meter = meterPower
				break
			case meterVoltage.scale:
				meter = meterVoltage
				break
			case meterCurrent.scale:
				meter = meterCurrent
				break
			default:
				logDebug "Unknown Meter Scale: $cmd"
		if (meter?.name && getAttrVal("${meter.name}") != val) {
			sendEvent(getEventMap(meter.name, val, null, null, meter.unit))
			if (meter.name != meterEnergy.name) {
				sendHighLowEvents(meter, val)
			runIn(5, refreshHistory)
	return []
private sendHighLowEvents(meter, val) {
	def highLowNames = []
	def highName = "${meter.name}High"
	def lowName = "${meter.name}Low"
	if (!getAttrVal(highName) || val > getAttrVal(highName)) {
		highLowNames << highName
	if (!getAttrVal(lowName) || meter.value < getAttrVal(lowName)) {
		highLowNames << lowName
	highLowNames.each {
		sendEvent(getEventMap("$it", val, false, null, meter.unit))
private calculateEnergyDuration() {
	def energyTimeMS = getAttrVal("energyTime")
	if (!energyTimeMS) {
		return "Unknown"
	else {
		def duration = roundTwoPlaces((new Date().time - energyTimeMS) / 60000)
		if (duration >= (24 * 60)) {
			return getFormattedDuration(duration, (24 * 60), "Day")
		else if (duration >= 60) {
			return getFormattedDuration(duration, 60, "Hour")
		else {
			return getFormattedDuration(duration, 0, "Minute")
private getFormattedDuration(duration, divisor, name) {
	if (divisor) {
		duration = roundTwoPlaces(duration / divisor)
	return "${duration} ${name}${duration == 1 ? '' : 's'}"
def refreshHistory() {
	def history = ""
	def items = [:]
	items["energyDuration"] = "Duration"
		items["${it}Low"] = "${it.capitalize()} - Low"
		items["${it}High"] = "${it.capitalize()} - High"
	items.each { attrName, caption ->
		def attr = device.currentState("${attrName}")
		def val = attr?.value ?: ""
		def unit = attr?.unit ?: ""
		history += "${caption}: ${val} ${unit}\n"
	sendEvent(getEventMap("history", history, false))
def zwaveEvent(hubitat.zwave.Command cmd) {
	logDebug "Unhandled zwaveEvent: $cmd"
	return []
private updateSyncingStatus() {
	if (device.currentValue("syncStatus") != "Syncing...") {
		sendEvent(getEventMap("syncStatus", "Syncing...", false))
def refreshSyncStatus() {
	def changes = pendingChanges
	sendEvent(name: "syncStatus", value: (changes ?  "${changes} Pending Changes" : "Synced"), displayed: false)
private getPendingChanges() {
	def total = 0
	configParams.each {
		def val = it.value
		if (state.newModel && it.num == powerReportingThresholdParam.num) {
			val = getNewModelPowerReportingThreshold(val)
		total += ("${val}" == "${getParamStoredValue(it.num)}") ? 0 : 1
	return total
private getParamStoredValue(paramNum) {
	return safeToInt(state["configVal${paramNum}"] , null)
private setParamStoredValue(paramNum, value) {
	state["configVal${paramNum}"] = value
// Configuration Parameters
private getConfigParams() {
	return [
		meterReportsEnabledParam,
		meterReportingIntervalParam,
		overloadProtectionParam,
		overloadAlarmParam,
		ledEnabledParam,
		powerReportingThresholdParam,
		rememberSwitchStateParam,
		switchTimerEnabledParam,
		switchTimerPeriodParam,
private getMeterReportsEnabledParam() {
	def num = state?.newModel ? 6 : 1
	return getParam(num, "Meter Reports Enabled", 1, 1, enabledDisabledOptions, "meterEnabled")
private getMeterReportingIntervalParam() {
	def num = state?.newModel ? 7 : 2
	return getParam(num, "Meter Reporting Interval", 2, 300, meterReportingIntervalOptions, "meterInterval")
private getOverloadProtectionParam() {
	def num = state?.newModel ? 8 : 3
	return getParam(num, "Current Overload Protection Threshold", 1, 13, getOverloadOptions(2, 16), "overloadProtection")
private getOverloadAlarmParam() {
	def num = state?.newModel ? 10 : 4
	return getParam(num, "Current Overload Alarm Threshold", 1, 12, getOverloadOptions(1, 15), "overloadAlarm")
private getLedEnabledParam() {
	def num = state?.newModel ? 3 : 5
	return getParam(num, "LED Enabled", 1, 1, enabledDisabledOptions, "ledEnabled")
private getPowerReportingThresholdParam() {
	def num = state?.newModel ? 9 : 6
	def size = state?.newModel ? 2 : 1
	return getParam(num, "Power Reporting Threshold", size, 5, powerReportingThresholdOptions, "meterThreshold")
private getRememberSwitchStateParam() {
	def num = state?.newModel ? 1 : 7
	return getParam(num, "Remember Switch State After Power Failure", 1, 1, enabledDisabledOptions, "rememberState")
private getSwitchTimerEnabledParam() {
	def num = state?.newModel ? 4 : 8
	return getParam(num, "Switch Off Timer Enabled", 1, 0, enabledDisabledOptions, "timerEnabled")
private getSwitchTimerPeriodParam() {
	def num = state?.newModel ? 5 : 9
	return getParam(num, "Swith Off Timer Period", 2, 120, switchTimerPeriodOptions, "timerPeriod")
private getPhysicalButtonEnabledParam() {
	def num = state?.newModel ? 2 : 10
	return getParam(num, "Physical Button Enabled", 1, 1, enabledDisabledOptions, "btnEnabled")
private getParam(num, name, size, defaultVal, options, pref) {
	def val = safeToInt((settings ? settings["${pref}"] : null), defaultVal)
	def map = [num: num, name: name, size: size, value: val, pref:pref]
	map.valueName = options?.find { k, v -> "${k}" == "${val}" }?.value
	map.options = setDefaultOption(options, defaultVal)
	return map
private setDefaultOption(options, defaultVal) {
	return options?.collect { k, v ->
		if ("${k}" == "${defaultVal}") {
			v = "${v} [DEFAULT]"
		["$k": "$v"]
// Setting Options
private getEnabledDisabledOptions() {
	 return [
		"0":"Disabled",
		"1":"Enabled"
private getMeterReportingIntervalOptions() {
	def options = [:]
	// if (!state?.newModel) {
		// [5,10,15,20].each {
			// options["${it}"] = "${it} Seconds"
	[30,45].each {
	options["60"] = "1 Minute"
	options["90"] = "1 Minute 30 Seconds"
	options["120"] = "2 Minutes"
	options["150"] = "2 Minutes 30 Seconds"
	(3..10).each {
		options["${it * 60}"] = "${it} Minutes"
	[15,20,25,30,45].each {
	options["${60 * 60}"] = "1 Hour"
	(2..9).each {
		options["${it * 60 * 60}"] = "${it} Hours"
	// if (state?.newModel) {
		// (10..18).each {
			// options["${it * 60 * 60}"] = "${it} Hours"
	return options
private getOverloadOptions(min, max) {
	def options = [:]
	(1..16).each {
		if (it >= min && it <= max) {
			options["${it}"] = "${it}A"
	return options
private getPowerReportingThresholdOptions() {
	def options = ["0":"Disabled"]
	[1,2,3,4,5,10,15,20,25,30,35,40,45,50,60,70,80,90,100].each {
		options["${it}"] = "${it}%"
	return options
private getSwitchTimerPeriodOptions() {
	def options = ["1":"1 Minute"]
	(2..10).each {
		options["${it}"] = "${it} Minutes"
	options["60"] = "1 Hour"
	options["90"] = "1 Hour 30 Minutes"
	options["120"] = "2 Hours"
	options["150"] = "2 Hours 30 Minutes"
	(3..12).each {
		options["${it * 60}"] = "${it} Hours"
	[15,18,21].each {
	options["60 * 24"] = "1 Day"
	(2..6).each {
		options["${it * 60 * 24}"] = "${it} Days"
	options["60 * 24 * 7"] = "1 Week"
	(2..3).each {
		options["${it * 60 * 24 * 7}"] = "${it} Weeks"
		// (4..6).each {
			// options["${it * 60 * 24 * 7}"] = "${it} Weeks"
	return options
private hexBytesToInt(val, size) {
	if (size == 2) {
		return val[1] + (val[0] * 0x100)
	else {
		return val[0]
private intToHexBytes(val, size) {
	if (size == 2) {
		if (val > 32767) val = (val - 65536)
		return [(byte) ((val >> 8) & 0xff),(byte) (val & 0xff)]
	else {
		if (val > 127) val = (val - 256)
		return [val]
private getEventMap(name, value, displayed=null, desc=null, unit=null) {
	desc = desc ?: "${name} is ${value}"
	def eventMap = [
		value: value,
		displayed: (displayed == null ? ("${getAttrVal(name)}" != "${value}") : displayed),
		isStateChange: true
	if (unit) {
		eventMap.unit = unit
		desc = "${desc} ${unit}"
	if (desc && eventMap.displayed) {
		logDebug desc
		eventMap.descriptionText = "${device.displayName} - ${desc}"
	else {
		logTrace "Creating Event: ${eventMap}"
	return eventMap
private getAttrVal(attrName) {
	try {
		return device?.currentValue("${attrName}")
	catch (ex) {
		logTrace "$ex"
		return null
private safeToInt(val, defaultVal=0) {
	return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private safeToDec(val, defaultVal=0) {
	return "${val}"?.isBigDecimal() ? "${val}".toBigDecimal() : defaultVal
private roundTwoPlaces(val) {
	return Math.round(safeToDec(val) * 100) / 100
private convertToLocalTimeString(dt) {
	def timeZoneId = location?.timeZone?.ID
	if (timeZoneId) {
		return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
	else {
		return "$dt"
private isNewModel() {
	return getDataValue("deviceId") == "512"
private isDuplicateCommand(lastExecuted, allowedMil) {
	!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
	if (settings?.debugOutput || settings?.debugOutput == null) {
		log.debug "$msg"
private logTrace(msg) {
	// log.trace "$msg"
I have the ZEN07 Zooz Power Plug and I have it configured with the Neo Coolcam Power Plug type. It seems to report everything and I have had no problem controlling it.
Sorry it is impossible to tell where someone is from which makes the answer no good. I was going on the assumption you were in the USA. As far as the EU version I cannot help you with that. You would think the only difference would be the frequency but maybe not.
The US and EU versions of the Neo Smart Plug were the same, but Neo released a new model for the EU version about a month ago and they changed every configuration parameter number and some of the configuration parameter value ranges so the new model won't work with any of the built-in drivers.
Technically it does work with the built-in Neo driver, but you won't be able to configure it.
Aah, that makes a huge difference. Changing configurations and parameters will definitely mess it all up. Makes you wonder why they would do that knowing it would mess everyone up.
what's specific to the EU configuration?
They changed the numbers of several configuration parameters...
Hi! Following this as I would like to see this implemented too. EU Neo Coolcam Plug works fine but impossible to set any configuration parameters.
I get:
No signature of method: static com.hubitat.hub.dao.DeviceDao.getState() is applicable for argument types: (null) values: [null] Possible solutions: getState(long), getData(long), getClass(), getAt(java.lang.String)
I'm not versed in the ways of groovy, but pulling the 1.2.6 from your Github and doing rote "physicaldevice->hubitat" changes gets the the same result. How do I track down where this is getting thrown from? (I see a few fooGet() calls w/o arguments, but they look like just wrapper functions, and commenting them out doesn't change anything...)
Are you sure you're pasting it into the driver section and not the app section?
Absolutely.
I've not sure if the handler will work, but it will at least stop those errors...
put the following on line 178:
setDataValue("newModel", "true")
change line 235 to:
return cmds
change line 901 to:
return true
find:
physicalgraph
replace with:
hubitat
find:
state?.newModel ?
replace with:
getDataValue("newModel") == "true" ?
Can you tweak parameters in the plug with @mike.maxwell ‘s basic tool?
Zwave Tweeker
It was easier to just port it than to try and explain how to fix it...
I don't have your model so I can't test it, but it's cleanly ported so it should work...
I might have used the wrong deviceType code so post what's shown in the Data section.
I just realized that the original code had a workaround for an old issue and that workaround breaks things in Hubitat 2.1.7 and above so I just removed it.
Both models should now work with the version I just posted, assuming I specified the correct deviceType.
Also a thank you from me Kevin. Having it all working too....
