Hi!
Fairly new user here.. I'm in the process of migrating from Smartthings and got must of my stuff working but I have a problem with my Sinope thermostats with GT125 hub.
I always got an error saying that the GT125 is generating too much hub load. I have only 5 thermostats connected in hubitat right now (on 11 total).
I'm using this driver: https://community.hubitat.com/t/release-sinope-gt125-hubitat-integration/56508
Error is showing in the thermostat logs only, no errors in the Sinope hub logs.
Here's a screenshot from the thermostat log, device 31 is the Sinope Hub:
and here's a screenshot from the Sinope hub itself:
System is effectively showing that the Sinope hub is using very high % of busy time:
Here's what I tried so far to fix the issue:
- Up the poll interval in the driver for every thermostat to maximum (60 minutes)
- Up the poll interval in the GT125 driver to max (5 min.)
- Remove all thermostats and GT125 from hubitat, repair driver package from HEPM and reinstall devices
- Set poll interval in GT125 and all thermostats to off and create a rule in rule machine to refresh thermostats once every 10 min.
- With poll interval off, create a piston in WebCore to refresh thermostats.
- Revert Hubitat's hub firmware to 2.3.4.120
It's the same behavior with every tests.. On hubitat reboot, refresh work for 2-3 times then I got the errors in the log. Thermostats won't refresh until Hubitat's hub reboot but I they still respond to sent commands from the hubitat interface (change setpoint for example).
I had a piston running in Smarthhings that did refresh every 2 min. that worked great for many months.
I'm clueless now as what to try next to fix the issue.
Can you please point me what you think should be the next step?
Sorry for the long post, thanks a lot!
