Need help selecting hardware
Hello,
I have a shop light connebted to a smart outlet. I would li, e to add a battry-powered wall switch or button that will send a signal to the hubitat and use that signal to turn the outlet on and off.
Any suggestions for a switch (something like a casseta 5 button) but simpler?
Zooz Zen34 should be a good fit for that.
If you want it to look and work like a normal smart light switch, with up and down taps, the Zooz ZEN34 would work good Zooz 800 Series Z-Wave Long Range Remote Switch ZEN34 800LR (Battery P - The Smartest House.
If you want 5 buttons like a scene controller there is a new ZEN37 that I have a custom driver built for HE support: [DRIVER] Zooz ZEN37 Wall Remote
Thank you, it looks good
Anything comparable for zigbee?
Mostly I have only seen Zigbee buttons, not designed like switches. But you could use a single button to toggle the light on and off, or get a multi-button remote.
-- https://www.amazon.com/THIRDREALITY-Compatible-SmartThings-Assistant-Included/dp/B09ZQGZX3G/ref=sr_1_6?keywords=zigbee+button&qid=1705976884&sr=8-6
-- https://www.amazon.com/SONOFF-SNZB-01P-Wireless-Supports-Connected/dp/B0CL9JTMWF/ref=sr_1_7?keywords=zigbee+button&qid=1705976884&sr=8-7
-- https://www.amazon.com/MOES-Wireless-Connection-Controller-Automation/dp/B0BJKBR1J6/ref=sr_1_8?keywords=zigbee%2Bbutton&qid=1705976884&sr=8-8&th=1
Always search around on the compatibility list or forums for random zigbee devices, not all have drivers that work for them and some of these sketchy Zigbee devices use non-standard clusters which need custom drivers.
Thanks, a button is all I need. It's just a shop light with a pull-cord in an inaccessible location
The Third Reality one I linked to should have good support, that company works with HE to get devices supported and firmware updates pushed. Sometimes their firmware is a little quirky but they keep at it and keep pushing out updates to fix issues. Sonoff typically works good using generic drivers, not all Sonoff devices are great though. I know there are all sorts of other Zigbee buttons as well.
Thanks for the additional info
