Hello everyone,
I have been trying to make my simple on / off switch that controls my natural gas fireplace smart for over a year now and have tried so much troubleshooting that I need to ask for some general advice. As background, my gas fireplace wiring looks like this:
The on / off switch opens and closes the circuit that I assume opens a valve to allow the flow of natural gas that is ignited by the pilot. I don't see any Transformer under my fireplace, so I presume it is getting millivolt power from the pilot (which I think is the thermopile).
There is no power to the switch.
This is what I have tried:
- I acquired a Zen zigbee thermostat since it appeared to fit the bill, it paired fine, worked for a few hours, the dropped off the zigbee network.
- I acquired a 24 volt transformer to keep power running to the thermostat, it still dropped off the network. At this point I presumed the Zen was defective (purchased on eBay...so no returns).
- Returned the 24V power supply
- Acquired a zigbee Centralite Pearl as it can also run on batteries, pairs fine and still drops off the network after a few hours.
- At this point I am thinking my Zigbee network might be the issue (my C7 hub is on a different floor and I have 3 repeaters around the house).
- Setup Home Assistant Container on my NAS, purchased a new Zigbee coordinator dongle (use a channel far away from my C7 zigbee network) and pair the Centralite. It drops off after a few hours.
- I try to reinstall the Zen, it also drops off after a few hours
- I repurchase the 24V power supply and try both the Zen and the Centralite on the HA network, they pair fine, then drop off after a few hours.
Not sure what to try next...on the HA forum someone suggested that my zigbee network is weak with only 5-6 devices, I don't see any of my other devices dropping off (temp sensors, outlets, roller shades), but maybe thermostats behave differently? How many zigbee devices are needed for a "strong" network?
I still have the 24V power so I technically have what is needed to run power to the thermostat (a C wire), but I am loathed to try another zigbee thermostat (like a Sinope) as I will not be able to return it once the box has been opened.
Should I give up on a zigbee Thermostat and go with a Z-wave device? Perhaps the Honeywell?
Should I just go wifi with something like an Ecobee?
I know I can do something like a Shelly relay and a temp sensor and "make" a thermostat, but I really want the ability to interact with a physical device AND control it with authomation rules.
Any help would be appreciated!
