I have seen couple of threads on Nanoleaf, but I didnt see one that spoke about how to do the initial configuration with HE. As such, it must be very simple, but I am overlooking whatever it is that needs to be done.
I created a virtual device -Nanoleaf. At first I though it would have to do something like enter a username and password, but saw no way to do that. Then i thought maybe I needed the Nanoleaf IP address on my LAN, but entering that doesnt seem to allow control. My guess is that it has something to do with the GetAuthToken button, but not really sure what to do with that. Can anyone point me in the right direction?
thank you. It took me a few tries, but after pressing and holding the power button, putting it into what looked like a pairing mode, it was able to work!
sorry, i am new to hubitat and still didn't understand what you mean can you please add step by step instructions? what do you mean put the IP in the driver UI what is the driver UI?
Go to devices, then add virtual device.
In the type drop down, select Nanoleaf Aurora, Enter a name for the Aurora, then save device.
Enter the ip address of the Aurora, press the pairing button on the Aurora, then within 15 seconds click save preferences in the driver ui.
It should then populate all the current values.
If this doesn't happen, verify the Auaora ip address, place the Aurora in pairing mode and click save preferences again.
Any chance support for Nanoleaf canvas will be added?
I get the following when trying to pair: dev:3222019-11-02 01:37:08.850 am errorstateSet error status:408
dev:3222019-11-02 01:36:49.985 am warngetAuthToken failed, place Aurora in pairing mode!, hold the power button until it begins flashing, then click getAuthToken.
dev:3222019-11-02 01:36:39.896 am warndescription logging is: true
Okay, I seem to be having trouble pairing it...
I put it in pair mode (holding power and dim until it flashes) (which also unpairs it from my cell).
Then I click 'save' in hubitat - and it gives me an error retrieving authcode...
Thanks - yeah, I think it must have been 'holding to long and resetting'.
I actually only pressed the power button for 7 seconds this time until it started cycling through the commands - then it was able to pair, and grab all the scenes.
Now I'm off to buy another set of nanoleafs!
Thank You for the help! My mistake was loading some custom driver instead of using the one already included! I am now up and running and am able to pull up the stored scenes in the Nanoleaf Aurora.
I'm a new Hubitat user and have had great fun setting up my WeMo devices and building some simple automations around them. However, I've hit a wall with setting up my Nanoleaf Aurora panels. I've followed the instructions above many times and followed the advice in this thread, with as many variations as I can think of, and I simply cannot make it work. The step that always fails is when I press (or, rather, hold for a few seconds) the Nanoleaf pairing button and then click Get Auth Token. The log always shows this error:
"getAuthToken failed, place Aurora in pairing mode!, hold the power button until it begins flashing, then click getAuthToken."
As I say, I'm a new user and so is it possible I'm misinterpreting and instruction or overlooking something obvious?
Sorry for the super slow reply - but that's similar to what I had, and the problem on my side was just holding the power button too long - so I'd miss the window for the token... Did you ever get it working?
