Multibutton switch
I need a a 4 or 5 button wall mount switch either Zigbee or Z wave. I need to simply push button to turn on a light and push again to turn off light. Also need visual indicator on each switch. I have had a Cooper RFWC5 for some time which looks like exactly what I need, however after much effort I have never been able to make it work correctly or reliably
Thanks for your help
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
Have you seen this:
community
Zooz Zen32 Scene Controller
Did you mean ZEN37 ? It is 4 button. (And is z-wave LR)
Something like this ?
I have a few work well ..
https://www.aliexpress.us/item/3256805016666254.html
No. It's a 5-button
https://www.getzooz.com/zooz-zen32-scene-controller/
Sorry I was confusing ZEN32 with ZEN34.
ZEN34 - 2 buttons, magnet mounted, battery powered
ZEN37 - 4 buttons, magnet mounted, battery powered
ZEN32 - 5 buttons, wired in box
Latest version of all is Long Range capable.
I use this one and I really like it. It does light up when you push a button. But I have labeled the 4 buttons.
Works with C7 and C8 using Aeon WallMote driver.
If it has to STAY lit up, the Zooz scene controller is good. I have one and like it.
If a battery powered device that just flashes a light when the button is pushed is acceptable, the Minoston/Zooz 4 button remotes (wall mountable) are great and reasonably priced.
https://www.amazon.com/Minoston-Controller-Control-Support-MR40Z/dp/B09BQKD5FQ
One last comment, the Aeotec and the ZEN37 are rechargeable via USB.
