I am trying to automate my basement lights with a motion sensor.
I have an Aeon Multisensor 6. and my lights are GE Link 22604. My motion sensor is sensing temperature, motion, etc and is functioning fine which i verify in the logs. My lights also turn on and off via the Device web page.
I setup a Motion and Mode lighting rule to turn on the lights with motion and turn them off after 1 minute. Under the "Lights to turn on" I have tried both the "Set the dimmers" and the "Turn on switches" but neither of these options are ever turning off the lights. And the lights never go off if they are on.
I am a bit stumped because the exact same ruleset is working for a motion sensor and smart outlet.
Are you able to control your GE Link bulbs from their device pages?
Sorry, I missed the sentence in your post indicating the lights can be controlled via the device page.
Have you added the bulbs individually to your Motion & Mode lighting rule? Or did you create a group of the relevant bulbs and use the group device instead? If you created the group, did you turn zigbee group messaging on?
Can I suggest you still consider grouping the bulbs that will be controlled together. Turn on "zigbee group messaging" for that group, and use the group device in your automations.
The GE bulbs ultimately seem pretty unreliable with these simple automations. They would work for a while and then not respond and then I had to join them again.
Unfortunately, these GE bulbs are not very good zigbee mesh routers. There are ways to get them to work semi-stably, but in general they require some baby-sitting. Most people prefer replacing them with bulbs that work well out of the box (eg. bulbs by Sengled, or Innr). There are also really inexpensive zigbee 3.0 RGBW bulbs made by eWeLink sold under a variety of brand-names that work well with Hubitat. I wrote a review on them a while ago.
