Please help me troubleshoot my Motion Lights setup. As per my high level need, if there is motion in basement, then turn on a scene. If there is no motion for 30 mins, turn lights off. As per the below logs, the "turn off" seems to be trigerred correctly...but the lights/scene does not really turn off
I am trying not not turn off the scene, only if "movie lights" switch is on.
You may see below, that currently the movie lights is indeed off right now
For every scene there is a device created that be used to activate the scene, such as on dashboards. Open the devices page and search for a device with the same name as your scene and a type of Scene Activator.
Then I'm not sure. You may want to re-create the motion lighting setup, adding each bit one at a time, testing the behaviour does what you want it to do. Start with the basic motion triggering the scene, then introduce each additional setting one at a time.
