Monitoring Charging of a TalentCell Battery With a Zooz ZEN04
edit: I am attempting to lengthen the life of my TalentCell battery by charging and discharging via a ZEN04 plug.
How accurate is the AutoOn and AutoOff on say, a ZEN04?
I set a 12 hour, ie 720 minute, cycle, and it was ~17 minutes off this morning.
Not critical, for me.
I have never used the auto on/auto off function, so I cannot respond to your question directly. However, if you want exact times for the switch functions, write a rule using basic rules or rule machine that turns the switch on or off at a specific times of day or relative to sunrise/sunset if appropriate. That should insure activation at precise times. If connected to the Internet, the Hubitat hub syncs with Internet Time Servers periodically.
Of course. But the question involves the auto on/off function.
I would think that’s a question for Zooz. @agnes.zooz maybe?
My guess is that whatever minimal computing guts are in the plug can handle short time calulations (seconds up to a few minutes? dunno), but will start to drift pretty hard at long intervals. It's not like there's an NTP server in there.
Probably uses the 60Hz power source and a counter as indicated here. Unless specially designed to keep extremely accurate time, all clocks will slowly drift. You do not see it as much anymore because so many devices are online, and sync with NTP.
The signal can be extracted from the 60-Hz oscillations in a normal power line. Many clocks that get their power from a wall socket use this technique because it is cheap and easy. The 60-Hz signal on the power line is reasonably accurate for this purpose.
Well, it turned itself on at 07:33:47.224 PM, or ~15 minutes longer than 12 hours (720 minutes) from when it turned itself off last time.
edit: This is greater than any fluctuation in electric utility frequency. I haven't tried this with any other Zooz devices, like the relays. Perhaps @agnes.zooz could shed some light on this.
(I renamed the device)
I had the idea of monitoring power delivered by the plug. It passes the watts along to the battery and the devices. The devices, I'd say, are fairly steady state. As the battery charges up, the total watts delivered should be going down. Perhaps I could turn it off before the state of charge gets to 100%, to preserve battery life...or something. :slight_smile:
edit: I think this has potential. I changed watts interval reporting to 1 minute, the minimum.
It's just clock drift. Asking a simple device like that to track 12 hours with a ton of accuracy is a lot. Auto on/off periods are typically a couple seconds or maybe a few minutes, not 12 hours. For that long of a period, you're better off using a rule via the hub (which does employ NTP).
Again with the NTP.
The prime deal with Hubitat is "no net required".
My clock radio keeps great time with no NTP.
It's not clock drift.
It doesn't affect my current battery charging idea.
@jtp10181 -- my apologies for playing in to this off-topic drift -- I just realized we're in your driver thread.
If velvetfoot wants to continue this line of discussion, I'm done participating, but hopefully a moderator can split this fork here off into its own new thread instead.
Original post no longer relevant due topic split.
Hopefully if hydro311 would not know what he is talking about, he would keep his big mouth shut.
The driver has an option for 65535 minutes auto on or off. 720 in this case is not extraordinary. I am using this driver to set this value. How can one change the value without a driver? You can't. So, to say it's irrelevant is specious.
Yes I was willing to entertain a short discussion about it but this warrants a separate thread now. I have split it off. Carry on.
Looking at the debug logs, it does appear that the auto on and off parameters are indeed set at 720:
So, it's on Zooz.
At roughly the hour and a half mark, the TalentCell's charger is still showing a red light, which means the battery is being charged.
The log verifies this. It is at 6.9 watts now, and still going down. The monitoring reporting interval is set at 1 minute, as I noted earlier.
It started the charge cycle at 29.6 watts. This includes the basic router and Hubitat hub, probably most of the 6.9 watts now being reported.
The charging started after a period of ~12 hours powering the setup on battery only. Four (of 4) lights were still showing on the TalentCell.
The green light on the TalentCell charger was on this morning.
From the logs, it looks like the power consumption as reported by the ZEN04 dropped down to, and stabilized at 2.1 Watts at ~12:44 AM.
This is with a Hubitat C8 and a Netgear N300 WiFi router attached to the TalentCell's USB and 12 V barrel DC connections.
It took a long time to get to the final fully charged state-almost asymptotic-like.
To recap, after the battery discharged 12 hours, it required 5 hours to be fully charged. It went from 29.6 Watts to a final 2.1 Watts.
Now, this is a fuzzy area for me:
IF it is good to not bring a Li-Ion battery to full charge, how far above the final consumption should I target?
Consumption went down to 5 Watts after two hours.
Should I discharge the battery for 12 hours and then bring it back to where it is consuming, say, only 5 Watts?
Right now, I have it on a 12 hour on/12 hour off, approximately, lol, schedule.
I suppose anything will be better than keeping it fully charged, which is what killed it, I suppose.
Log attached.
Log
dev:18682024-05-28 05:26:03.979 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 05:25:02.488 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 05:02:30.938 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 05:01:29.561 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:55:21.152 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:53:18.318 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:48:11.246 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:47:09.834 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:25:40.516 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:24:39.113 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:21:34.946 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:20:33.568 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:16:28.115 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:15:26.756 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:14:25.395 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:13:24.020 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:10:19.878 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:08:17.091 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 04:07:15.691 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 04:06:14.294 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 03:36:33.518 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 03:35:32.144 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 03:28:22.261 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 03:27:20.838 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 03:24:16.550 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 03:23:15.097 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 03:22:13.672 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 03:21:12.234 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 03:16:05.081 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 03:15:03.651 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 03:01:45.365 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 03:00:43.965 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 02:45:23.076 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 02:44:21.668 AMinfoLR TalentCell, Hub/Router: power set to 2 W
dev:18682024-05-28 02:31:03.650 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 02:30:02.241 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 01:23:32.966 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 01:22:31.637 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 01:19:27.616 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 01:18:26.261 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 01:03:05.346 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 01:02:03.946 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 01:01:02.572 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 01:00:01.143 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:58:59.775 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 12:57:58.417 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:56:57.052 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 12:55:55.677 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:54:54.368 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 12:53:53.097 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:49:47.887 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 12:48:46.589 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:46:43.963 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 12:45:42.622 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:44:41.295 AMinfoLR TalentCell, Hub/Router: power set to 2.1 W
dev:18682024-05-28 12:07:51.648 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:06:50.215 AMinfoLR TalentCell, Hub/Router: power set to 2.3 W
dev:18682024-05-28 12:02:44.469 AMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-28 12:00:41.700 AMinfoLR TalentCell, Hub/Router: power set to 2.3 W
dev:18682024-05-27 11:58:38.965 PMinfoLR TalentCell, Hub/Router: power set to 2.2 W
dev:18682024-05-27 11:33:04.652 PMinfoLR TalentCell, Hub/Router: power set to 2.3 W
dev:18682024-05-27 11:19:46.318 PMinfoLR TalentCell, Hub/Router: power set to 2.4 W
dev:18682024-05-27 11:15:40.652 PMinfoLR TalentCell, Hub/Router: power set to 2.5 W
dev:18682024-05-27 11:14:39.212 PMinfoLR TalentCell, Hub/Router: power set to 2.4 W
dev:18682024-05-27 11:05:26.413 PMinfoLR TalentCell, Hub/Router: power set to 2.5 W
dev:18682024-05-27 11:04:24.994 PMinfoLR TalentCell, Hub/Router: power set to 2.6 W
dev:18682024-05-27 11:01:20.728 PMinfoLR TalentCell, Hub/Router: power set to 2.5 W
dev:18682024-05-27 10:52:07.695 PMinfoLR TalentCell, Hub/Router: power set to 2.6 W
dev:18682024-05-27 10:42:55.423 PMinfoLR TalentCell, Hub/Router: power set to 2.7 W
dev:18682024-05-27 10:37:48.557 PMinfoLR TalentCell, Hub/Router: power set to 2.8 W
dev:18682024-05-27 10:30:39.244 PMinfoLR TalentCell, Hub/Router: power set to 2.9 W
dev:18682024-05-27 10:23:29.903 PMinfoLR TalentCell, Hub/Router: power set to 3 W
dev:18682024-05-27 10:20:25.758 PMinfoLR TalentCell, Hub/Router: power set to 3.1 W
dev:18682024-05-27 10:15:18.759 PMinfoLR TalentCell, Hub/Router: power set to 3.2 W
dev:18682024-05-27 10:11:13.189 PMinfoLR TalentCell, Hub/Router: power set to 3.3 W
dev:18682024-05-27 10:07:07.610 PMinfoLR TalentCell, Hub/Router: power set to 3.4 W
dev:18682024-05-27 10:06:06.219 PMinfoLR TalentCell, Hub/Router: power set to 3.5 W
dev:18682024-05-27 10:05:04.831 PMinfoLR TalentCell, Hub/Router: power set to 3.6 W
dev:18682024-05-27 10:04:03.438 PMinfoLR TalentCell, Hub/Router: power set to 3.5 W
dev:18682024-05-27 10:00:59.096 PMinfoLR TalentCell, Hub/Router: power set to 3.6 W
dev:18682024-05-27 09:59:57.674 PMinfoLR TalentCell, Hub/Router: power set to 3.7 W
dev:18682024-05-27 09:58:56.234 PMinfoLR TalentCell, Hub/Router: power set to 3.6 W
dev:18682024-05-27 09:56:53.368 PMinfoLR TalentCell, Hub/Router: power set to 3.7 W
dev:18682024-05-27 09:53:49.000 PMinfoLR TalentCell, Hub/Router: power set to 3.8 W
dev:18682024-05-27 09:49:43.043 PMinfoLR TalentCell, Hub/Router: power set to 3.9 W
dev:18682024-05-27 09:47:40.073 PMinfoLR TalentCell, Hub/Router: power set to 4 W
dev:18682024-05-27 09:46:38.559 PMinfoLR TalentCell, Hub/Router: power set to 4.1 W
dev:18682024-05-27 09:42:32.265 PMinfoLR TalentCell, Hub/Router: power set to 4.2 W
dev:18682024-05-27 09:41:30.660 PMinfoLR TalentCell, Hub/Router: power set to 4.3 W
dev:18682024-05-27 09:38:25.987 PMinfoLR TalentCell, Hub/Router: power set to 4.4 W
dev:18682024-05-27 09:37:24.362 PMinfoLR TalentCell, Hub/Router: power set to 4.5 W
dev:18682024-05-27 09:34:19.670 PMinfoLR TalentCell, Hub/Router: power set to 4.6 W
dev:18682024-05-27 09:32:16.601 PMinfoLR TalentCell, Hub/Router: power set to 4.7 W
dev:18682024-05-27 09:31:15.084 PMinfoLR TalentCell, Hub/Router: power set to 4.8 W
dev:18682024-05-27 09:29:11.983 PMinfoLR TalentCell, Hub/Router: power set to 4.9 W
dev:18682024-05-27 09:27:09.017 PMinfoLR TalentCell, Hub/Router: power set to 5 W
dev:18682024-05-27 09:25:05.999 PMinfoLR TalentCell, Hub/Router: power set to 5.1 W
dev:18682024-05-27 09:24:04.479 PMinfoLR TalentCell, Hub/Router: power set to 5.2 W
dev:18682024-05-27 09:22:01.351 PMinfoLR TalentCell, Hub/Router: power set to 5.3 W
dev:18682024-05-27 09:20:59.799 PMinfoLR TalentCell, Hub/Router: power set to 5.4 W
dev:18682024-05-27 09:18:56.780 PMinfoLR TalentCell, Hub/Router: power set to 5.5 W
dev:18682024-05-27 09:17:55.230 PMinfoLR TalentCell, Hub/Router: power set to 5.6 W
dev:18682024-05-27 09:16:53.707 PMinfoLR TalentCell, Hub/Router: power set to 5.7 W
dev:18682024-05-27 09:15:52.223 PMinfoLR TalentCell, Hub/Router: power set to 5.8 W
dev:18682024-05-27 09:14:50.762 PMinfoLR TalentCell, Hub/Router: power set to 5.9 W
dev:18682024-05-27 09:12:47.964 PMinfoLR TalentCell, Hub/Router: power set to 6 W
dev:18682024-05-27 09:11:46.526 PMinfoLR TalentCell, Hub/Router: power set to 6.1 W
dev:18682024-05-27 09:09:43.737 PMinfoLR TalentCell, Hub/Router: power set to 6.2 W
dev:18682024-05-27 09:07:40.878 PMinfoLR TalentCell, Hub/Router: power set to 6.3 W
dev:18682024-05-27 09:06:39.341 PMinfoLR TalentCell, Hub/Router: power set to 6.4 W
dev:18682024-05-27 09:05:37.751 PMinfoLR TalentCell, Hub/Router: power set to 6.5 W
dev:18682024-05-27 09:04:36.216 PMinfoLR TalentCell, Hub/Router: power set to 6.6 W
dev:18682024-05-27 09:03:34.637 PMinfoLR TalentCell, Hub/Router: power set to 6.8 W
dev:18682024-05-27 09:01:31.327 PMinfoLR TalentCell, Hub/Router: power set to 6.9 W
dev:18682024-05-27 08:59:28.120 PMinfoLR TalentCell, Hub/Router: power set to 7.1 W
dev:18682024-05-27 08:58:26.637 PMinfoLR TalentCell, Hub/Router: power set to 7.2 W
dev:18682024-05-27 08:57:25.142 PMinfoLR TalentCell, Hub/Router: power set to 7.3 W
dev:18682024-05-27 08:56:23.670 PMinfoLR TalentCell, Hub/Router: power set to 7.4 W
dev:18682024-05-27 08:55:22.226 PMinfoLR TalentCell, Hub/Router: power set to 7.5 W
dev:18682024-05-27 08:54:20.697 PMinfoLR TalentCell, Hub/Router: power set to 7.6 W
dev:18682024-05-27 08:53:19.112 PMdebugLR TalentCell, Hub/Router: power set to 7.7 W [NOT CHANGED]
dev:18682024-05-27 08:52:17.555 PMinfoLR TalentCell, Hub/Router: power set to 7.7 W
dev:18682024-05-27 08:51:16.042 PMinfoLR TalentCell, Hub/Router: power set to 8.5 W
dev:18682024-05-27 08:50:14.510 PMinfoLR TalentCell, Hub/Router: power set to 8.7 W
dev:18682024-05-27 08:49:12.995 PMinfoLR TalentCell, Hub/Router: power set to 8.8 W
dev:18682024-05-27 08:48:11.366 PMinfoLR TalentCell, Hub/Router: power set to 8.9 W
dev:18682024-05-27 08:47:09.760 PMinfoLR TalentCell, Hub/Router: power set to 9.2 W
dev:18682024-05-27 08:46:08.198 PMdebugLR TalentCell, Hub/Router: power set to 9.4 W [NOT CHANGED]
dev:18682024-05-27 08:45:06.629 PMinfoLR TalentCell, Hub/Router: power set to 9.4 W
dev:18682024-05-27 08:44:04.917 PMinfoLR TalentCell, Hub/Router: power set to 9.6 W
dev:18682024-05-27 08:43:03.081 PMinfoLR TalentCell, Hub/Router: power set to 9.8 W
dev:18682024-05-27 08:42:01.217 PMinfoLR TalentCell, Hub/Router: power set to 9.9 W
dev:18682024-05-27 08:40:59.371 PMinfoLR TalentCell, Hub/Router: power set to 10.1 W
dev:18682024-05-27 08:39:57.619 PMinfoLR TalentCell, Hub/Router: power set to 10.2 W
dev:18682024-05-27 08:38:55.908 PMinfoLR TalentCell, Hub/Router: power set to 10.4 W
dev:18682024-05-27 08:37:54.236 PMinfoLR TalentCell, Hub/Router: power set to 10.6 W
dev:18682024-05-27 08:36:52.491 PMinfoLR TalentCell, Hub/Router: power set to 10.8 W
dev:18682024-05-27 08:35:50.749 PMdebugLR TalentCell, Hub/Router: power set to 11.1 W [NOT CHANGED]
dev:18682024-05-27 08:34:49.053 PMinfoLR TalentCell, Hub/Router: power set to 11.1 W
dev:18682024-05-27 08:33:47.447 PMinfoLR TalentCell, Hub/Router: power set to 11.4 W
dev:18682024-05-27 08:32:45.800 PMinfoLR TalentCell, Hub/Router: power set to 11.7 W
dev:18682024-05-27 08:31:44.093 PMinfoLR TalentCell, Hub/Router: power set to 11.8 W
dev:18682024-05-27 08:30:42.503 PMinfoLR TalentCell, Hub/Router: power set to 12 W
dev:18682024-05-27 08:29:40.851 PMinfoLR TalentCell, Hub/Router: power set to 12.2 W
dev:18682024-05-27 08:28:39.158 PMinfoLR TalentCell, Hub/Router: power set to 12.5 W
dev:18682024-05-27 08:27:37.520 PMinfoLR TalentCell, Hub/Router: power set to 12.7 W
dev:18682024-05-27 08:26:35.789 PMinfoLR TalentCell, Hub/Router: power set to 13 W
dev:18682024-05-27 08:25:33.977 PMinfoLR TalentCell, Hub/Router: power set to 13.2 W
dev:18682024-05-27 08:24:32.160 PMinfoLR TalentCell, Hub/Router: power set to 13.5 W
dev:18682024-05-27 08:23:30.285 PMinfoLR TalentCell, Hub/Router: power set to 13.6 W
dev:18682024-05-27 08:22:28.986 PMinfoLR TalentCell, Hub/Router: power set to 14 W
dev:18682024-05-27 08:21:47.264 PMinfoLR TalentCell, Hub/Router: power set to 14.1 W
dev:18682024-05-27 08:20:45.499 PMinfoLR TalentCell, Hub/Router: power set to 14.3 W
dev:18682024-05-27 08:19:43.791 PMinfoLR TalentCell, Hub/Router: power set to 14.7 W
dev:18682024-05-27 08:18:42.110 PMinfoLR TalentCell, Hub/Router: power set to 15 W
dev:18682024-05-27 08:17:40.439 PMinfoLR TalentCell, Hub/Router: power set to 15.2 W
dev:18682024-05-27 08:16:38.800 PMinfoLR TalentCell, Hub/Router: power set to 15.5 W
dev:18682024-05-27 08:15:37.160 PMinfoLR TalentCell, Hub/Router: power set to 15.8 W
dev:18682024-05-27 08:14:35.526 PMinfoLR TalentCell, Hub/Router: power set to 16 W
dev:18682024-05-27 08:13:33.807 PMinfoLR TalentCell, Hub/Router: power set to 16.3 W
dev:18682024-05-27 08:12:32.090 PMinfoLR TalentCell, Hub/Router: power set to 16.7 W
dev:18682024-05-27 08:11:30.366 PMinfoLR TalentCell, Hub/Router: power set to 16.9 W
dev:18682024-05-27 08:10:28.706 PMinfoLR TalentCell, Hub/Router: power set to 17.3 W
dev:18682024-05-27 08:09:27.031 PMinfoLR TalentCell, Hub/Router: power set to 17.7 W
dev:18682024-05-27 08:08:25.465 PMinfoLR TalentCell, Hub/Router: power set to 18 W
dev:18682024-05-27 08:07:23.815 PMinfoLR TalentCell, Hub/Router: power set to 18.4 W
dev:18682024-05-27 08:06:22.133 PMinfoLR TalentCell, Hub/Router: power set to 18.8 W
dev:18682024-05-27 08:05:20.507 PMinfoLR TalentCell, Hub/Router: power set to 19.1 W
dev:18682024-05-27 08:04:18.921 PMinfoLR TalentCell, Hub/Router: power set to 19.5 W
dev:18682024-05-27 08:03:17.367 PMinfoLR TalentCell, Hub/Router: power set to 19.8 W
dev:18682024-05-27 08:02:15.829 PMinfoLR TalentCell, Hub/Router: power set to 20.3 W
dev:18682024-05-27 08:01:14.119 PMinfoLR TalentCell, Hub/Router: power set to 20.7 W
dev:18682024-05-27 08:00:12.486 PMinfoLR TalentCell, Hub/Router: power set to 21 W
dev:18682024-05-27 07:59:10.877 PMinfoLR TalentCell, Hub/Router: power set to 21.4 W
dev:18682024-05-27 07:58:09.251 PMinfoLR TalentCell, Hub/Router: power set to 21.8 W
dev:18682024-05-27 07:57:07.839 PMinfoLR TalentCell, Hub/Router: power set to 22.5 W
dev:18682024-05-27 07:52:56.022 PMinfoLR TalentCell, Hub/Router: power set to 24.4 W
dev:18682024-05-27 07:44:04.163 PMinfoLR TalentCell, Hub/Router: power set to 29.3 W
dev:18682024-05-27 07:33:49.185 PMinfoLR TalentCell, Hub/Router: power set to 29.6 W
I use the AccuBattery app for my phone. It recommends charging to 80%. It takes about half the time to charge to 80% as it does to 100%.
With your setup, is your plug powering more than the charger? It's hard to know what exactly is happening if other devices are on the same plug.
My recommendation is compare the run time on a full charge to the run time on a half the full-time charge. If your battery pack doesn't give you an accurate % full reading, then the run time is the next best thing.
You may need to do the halftime charge then the run time to empty several times to get an estimate of the battery %full for a half time charge.
Thanks.
80% sounds like a plan!
No other devices are powered by the plug.
The lights indicating charge I don't think are accurate.
I believe other people have noted this as well.
I do think the watts being delivered can be an indicator as well, and can also probably correlate to charge time.
edit: But, having the thinking done by the plug vs hub might have advantages during a power outage where power availability could be variable depending on temporary power supplies.
ZEN04 AutoOn and AutoOff Durations
AutoOn and AutoOff both set to 720 minutes
On to Off:
736.632 minutes
737.24 minutes
Off to On:
735.24 minutes
735.19 minutes
Imperial to Metric conversion errors? :stuck_out_tongue_winking_eye:
See post above. I'm keeping track of deviation from the 720 minute auto on/off set through ZEN04 parameters. However, I'll very soon shorten the charging duration so it doesn't get to 100%, also as discussed above.
I might try to put together a graph of the power log, but I'll be using the charting tool in OpenOffice; can't afford anything fancier. I'm no GraphMaster, for sure, but I was given that nickname when I was working by a coworker friend of mine. :slight_smile:
