Monitor Uptime Kuma itself via Hubitat
UPDATE: See this post below for an updated (better IMO) way, without using a virtual device driver to monitor: Monitor Uptime Kuma itself via Hubitat - #4 by jtp10181
ORIGINAL POST / METHOD:
So, I had my system which hosts Uptime Kuma go partially down the other day, one of which services was Uptime Kuma itself. So obviously I had no idea what else was not working until I found out the hard way. Decided I should setup a redundant check to monitor Uptime Kuma and what better place than Hubitat since I have easy access to send notifications.
So I used this driver to setup a monitor for UK:
[RELEASE] Network Monitor HealthCheck (HTTP)
I just set it up as the "Internet" monitor since that is required for some reason, even though technically it is a LAN device.
Made a rule which is probably overly complicated for this, but I wanted it to repeat on a loop until I fixed it, so it does not get overlooked.
If the state gets changed to online with the checkNow() called in the loop, using the variable for the state gets the current state so it will report online then end. Not a guarantee to get the final online notification however, just depends on the order things happen in. I didn't want to make this even more complicated so called this good enough.
You could also use the %text% in the notification if you want all that info in there.
That's why you need (at least) two Uptime Kuma instances on different machines :slight_smile:
You could also use two monitors on the Uptime Kuma side to create a monitoring loop where either side will tell you if the other side isn't working.
On Hubitat - Rule Machine:
On Uptime Kuma, set up two monitors:
  • A regular http monitor pointed at the Hubitat local endpoint that triggers the rule. In this example I set it to run every 300 seconds (5 minutes) and notify after 2 failures
  • A push monitor. The URL for the push monitor is called by the Hubitat rule. It is set to expect a call every 360 seconds and notify after 2 failures.
So, every 5 minutes, the UK http monitor calls the Hubitat. The Hubitat calls back to Uptime Kuma push monitor and sets a cancelable delayed notification that will send if there isn't another inbound call within 11 minutes.
  • If Uptime Kuma stops calling, the Hubitat sends its notification (this could be looped for repeated notifications if needed).
  • If Hubitat stops responding on the endpoint, the Kuma http monitor will alert on its next call.
  • If Hubitat stops processing rules, the Kuma push monitor will alert.
The alerts on the http monitor could be disabled to avoid double notifications from UK, and obviously times can be shortened for faster alerts or extended to avoid false alerts during device reboots.
This doesn't just monitor ping response, but ensures that automations / actions are actually running on both ends.
I like that approach, I was actually thinking of doing something like that when I was revisiting my setup afterwards. Your rule is clean and simple. I also realized the push monitor in UK does not give any sort of ping, so you just know up or down not any response time or lag.
  • Cloud hits a cloud endpoint I setup in RM, to check for cloud connection.
  • Local hits the Web UI HTTP (via IP) to check if hub is functional.
  • Push I just added, explained above.
I could probably just replace the HTTP monitor with a rule trigger like you have setup. If the UI on port 80 is down I don't think the rule trigger would be able to work either. Then I could get rid of that extra virtual device I added for the HTTP monitor.
Also would like a way to track the response times of Zwave devices for any lag developing, that has been my only other issue recently. I think it finally quit acting up though, has been solid this week.
Ok, my slightly more complicated spin on your rule. I really wanted to send some sort of "ping" in the push monitor so I did a time diff between runs. Also added a repeating notification. My interval in UK is 120s, 2x is 4 minutes, hence the delay on the notification is 5 minutes.
This eliminated the virtual device driver to monitor UK, everything is done in the rule.
Also hitting the rule endpoint seems to give a better idea of hub response time than just checking the Web UI.
The rule itself
This is the one that hits the rule endpoint
This is what catches the response
(The median ping here should be close to your heartbeat time)
What exactly do you mean by partly go down? What hardware were you using to run Uptime Kuma? If it is a server, can't you configure alerts within its idrac/ilo?
I let the disk space run out on accident and a bunch of stuff went sideways or crashed. Its all running on a Debian VM, on an old mini-PC. It started out with just Homebridge, and has grown a lot. Need to move it all to a new better machine eventually, without the VM setup.
This is probably a stupid question but exactly how did you set this up since it is a driver and not an app.
For a driver like that you add a new virtual device and then pick the driver.
However, after @Alan_F replied I revised my setup and actually got rid of that virtual device, which is my follow up post here: Monitor Uptime Kuma itself via Hubitat - #4 by jtp10181
Would you be able to create a tutorial on how you created and setup the monitoring of UK via Hubitat?
I was trying to set it up yesterday but couldn't figure out the "send GET" to the UK endpoint. Specifically how you got the URL needed.
Its a push type monitor in UK, and then it shows you the URL after you create the Push monitor.
