C7 running 2.3.8.139
My washer and gas dryer are each monitored by a Moes Zigbee plug using the ‘Tuya Zigbee Metering Plug’ driver version 1.9.0 from @kkossev
When Istart the dryer, it runs for a second then turns off. HE shows the plug is off. I change it back to on, restart the dryer, and most of the time it stays on. I have swapped the Moes plug several tmes, and the shutoff still happens. I monitor the power through Hubigraphs and the power level never goes over 600 or so watts. The plug is rated 15 amps so the dryer is not pulling anywhere near the power it was designed to handle,
I checked the settings in the driver and didn’t see anything about this other than the toggle to keep the plug on.
Note: this is not the flaky Tuya plug. At least it isn’t that ID.
rxCounter : 7088
energyPollingSupported : true
lastResetDate : 2024-04-24 12:47:21.582
lastEnergyRaw : 0
isDigital : false
rejoinCounter : 0
lastSwitchState : on
txCounter : 3057
isRefreshRequest : false
notPresentCounter : 0
lastEnergyCost : 0.0
lastHourlyEnergy :
switchPollingSupported : true
powerPollingSupported : true
lastResetEnergy : 0.0
voltagePollingSupported : true
driverVersion : 1.9.0 2024/01/01 11:15 PM
switchDebouncing : false
currentPollingSupported : true
model : TS011F
destinationEP : 01
endpointId: 01
application: 4A
inClusters: 0003,0004,0005,0006,0702,0B04,E001,E000,0000
manufacturer: _TZ3000_yujkchbz
model: TS011F
outClusters: 0019,000A
dev:24912024-04-26 03:01:00.953 PMdebugDryer ignored amperageEvent (0) - reportAmperage is disabled
dev:24912024-04-26 03:01:00.949 PMdebugDryer ignored voltageEvent (117) - reportVoltage is disabled
dev:24912024-04-26 03:01:00.944 PMdebugDryer ignored power 0 W (change from 0.0 is less than 1 W)
dev:24912024-04-26 03:01:00.940 PMdebugDryer parse: Desc Map: [raw:4C3D010B04240B05290000050500217500080500210000, dni:4C3D, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:0075, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0000, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:24912024-04-26 03:01:00.930 PMdebugDryer parse: description is read attr - raw: 4C3D010B04240B05290000050500217500080500210000, dni: 4C3D, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 0000050500217500080500210000
dev:24912024-04-26 03:01:00.612 PMtraceDryer sendZigbeeCommands : [he raw 0x4C3D 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:24912024-04-26 03:01:00.539 PMdebugDryer polling all 0x0B04 attributes
dev:24912024-04-26 03:01:00.533 PMdebugDryer polling.. refreshAll is false
dev:24912024-04-26 03:01:00.521 PMdebugDryer autoPoll()
dev:24912024-04-26 03:00:55.250 PMdebugDryer ignored amperageEvent (0) - reportAmperage is disabled
dev:24912024-04-26 03:00:55.247 PMdebugDryer ignored voltageEvent (117) - reportVoltage is disabled
dev:24912024-04-26 03:00:55.191 PMinfoDryer power is 0 W (refresh)
dev:24912024-04-26 03:00:55.188 PMdebugDryer parse: Desc Map: [raw:4C3D010B04240B05290000050500217500080500210000, dni:4C3D, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:0075, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0000, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:24912024-04-26 03:00:55.176 PMdebugDryer parse: description is read attr - raw: 4C3D010B04240B05290000050500217500080500210000, dni: 4C3D, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 0000050500217500080500210000
dev:24912024-04-26 03:00:55.058 PMdebugDryer pollPower()..
dev:24912024-04-26 03:00:50.023 PMwarnDryer Unprocessed attribute report: cluster=E001 attrId=D001 value=00000000 status=null data=null
dev:24912024-04-26 03:00:50.021 PMdebugDryer parse: Desc Map: [raw:4C3D01E0010E01D01B00000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000000, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:50.017 PMdebugDryer unprocessed TuyaE00xCluster Desc Map: [raw:4C3D01E0010E01D01B00000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000000, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:50.015 PMdebugDryer TuyaE00xCluster Desc Map: [raw:4C3D01E0010E01D01B00000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000000, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:50.012 PMdebugDryer parse: description is read attr - raw: 4C3D01E0010E01D01B00000000, dni: 4C3D, endpoint: 01, cluster: E001, size: 0E, attrId: D001, encoding: 1B, command: 0A, value: 00000000
dev:24912024-04-26 03:00:49.558 PMdebugDryer Event enter: [name:switch, value:off]
dev:24912024-04-26 03:00:49.554 PMdebugDryer parse: description is read attr - raw: 4C3D0100060800001000, dni: 4C3D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
dev:24912024-04-26 03:00:49.467 PMdebugDryer Event enter: [name:switch, value:off]
dev:24912024-04-26 03:00:49.463 PMdebugDryer parse: description is read attr - raw: 4C3D0100060800001000, dni: 4C3D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
dev:24912024-04-26 03:00:49.174 PMwarnDryer Unprocessed attribute report: cluster=E001 attrId=D001 value=00000001 status=null data=null
dev:24912024-04-26 03:00:49.172 PMdebugDryer parse: Desc Map: [raw:4C3D01E0010E01D01B01000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000001, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:49.169 PMdebugDryer unprocessed TuyaE00xCluster Desc Map: [raw:4C3D01E0010E01D01B01000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000001, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:49.167 PMdebugDryer TuyaE00xCluster Desc Map: [raw:4C3D01E0010E01D01B01000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000001, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:49.163 PMdebugDryer parse: description is read attr - raw: 4C3D01E0010E01D01B01000000, dni: 4C3D, endpoint: 01, cluster: E001, size: 0E, attrId: D001, encoding: 1B, command: 0A, value: 01000000
dev:24912024-04-26 03:00:49.157 PMwarnDryer Unprocessed attribute report: cluster=E001 attrId=D001 value=00000001 status=null data=null
dev:24912024-04-26 03:00:49.155 PMdebugDryer parse: Desc Map: [raw:4C3D01E0010E01D01B01000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000001, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:49.152 PMdebugDryer unprocessed TuyaE00xCluster Desc Map: [raw:4C3D01E0010E01D01B01000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000001, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:49.148 PMdebugDryer TuyaE00xCluster Desc Map: [raw:4C3D01E0010E01D01B01000000, dni:4C3D, endpoint:01, cluster:E001, size:0E, attrId:D001, encoding:1B, command:0A, value:00000001, clusterInt:57345, attrInt:53249]
dev:24912024-04-26 03:00:49.141 PMdebugDryer parse: description is read attr - raw: 4C3D01E0010E01D01B01000000, dni: 4C3D, endpoint: 01, cluster: E001, size: 0E, attrId: D001, encoding: 1B, command: 0A, value: 01000000
dev:24912024-04-26 03:00:49.098 PMinfoDryer Dryer Dryer was turned off [physical]
dev:24912024-04-26 03:00:49.041 PMdebugDryer Switch state changed from on to off
dev:24912024-04-26 03:00:49.038 PMdebugDryer Event enter: [name:switch, value:off]
dev:24912024-04-26 03:00:49.032 PMdebugDryer parse: description is read attr - raw: 4C3D0100060800001000, dni: 4C3D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
dev:24912024-04-26 03:00:02.063 PMdebugDryer ignored amperageEvent (0) - reportAmperage is disabled
dev:24912024-04-26 03:00:02.059 PMdebugDryer ignored voltageEvent (117) - reportVoltage is disabled
dev:24912024-04-26 03:00:02.057 PMdebugDryer ignored power 0 W (change from 0.0 is less than 1 W)
dev:24912024-04-26 03:00:02.054 PMdebugDryer parse: Desc Map: [raw:4C3D010B04240B05290000050500217500080500210000, dni:4C3D, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:0075, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0000, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:24912024-04-26 03:00:02.043 PMdebugDryer parse: description is read attr - raw: 4C3D010B04240B05290000050500217500080500210000, dni: 4C3D, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 0000050500217500080500210000
dev:24912024-04-26 03:00:01.998 PMdebugDryer ignored amperageEvent (0) - reportAmperage is disabled
dev:24912024-04-26 03:00:01.995 PMdebugDryer ignored voltageEvent (117) - reportVoltage is disabled
dev:24912024-04-26 03:00:01.991 PMdebugDryer ignored power 0 W (change from 0.0 is less than 1 W)
dev:24912024-04-26 03:00:01.988 PMdebugDryer parse: Desc Map: [raw:4C3D010B04240B05290000050500217500080500210000, dni:4C3D, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:0075, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0000, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:24912024-04-26 03:00:01.977 PMdebugDryer parse: description is read attr - raw: 4C3D010B04240B05290000050500217500080500210000, dni: 4C3D, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 0000050500217500080500210000
dev:24912024-04-26 03:00:01.784 PMdebugDryer ignored hourlyEnergyEvent (0.0) - isEnergyEnabled is false
dev:24912024-04-26 03:00:01.761 PMtraceDryer sendZigbeeCommands : [he raw 0x4C3D 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:24912024-04-26 03:00:01.536 PMdebugDryer polling all 0x0B04 attributes
dev:24912024-04-26 03:00:01.533 PMdebugDryer polling.. refreshAll is false
dev:24912024-04-26 03:00:01.517 PMdebugDryer autoPoll()
WAF is falling. Help!
