Moes 4 button scene switch
If you enable the Debug logging, then remove the batteries for 10 seconds and put them back again - do you see anything in the live logs?
If not - your device was not paired successfully to your C-8 hub.
Use the Double Luck voodoo to pair this Zigbee 3.0 device directly to the hub.
