Mode not updating with Switch
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
Platform version
2.3.9.174
Hardware version
C-7
Mode Manager is configured to update Mode based on Time or Switch. Time works, Switch does not. I created a button for updating Mode (for testing) and that works. The Switch is a Virtual Switch. I tried changing it to a different switch type (and another physical switch) but that did not work. The log shows a Mode change after the switch is turned on. But the Mode does not actually change as it does not trigger a change in HSM or trigger other apps.
Here is Mode Manager
This is the log after *Goodbye turned on
This is HSM Config
This is what Mode Manager, HSM and Dashboard look like after switch changed
If I create a Rule to update the Mode based on Switch Change it all works
I’m answering my own post as I have a fix. I tried changing switches in Mode Manager, but that did not work. However, when I deleted the entry for a Mode in the Set Mode with Switch table, then recreated it, the issue resolved. I had to do this for each Mode
