What location & timezone do you have your hub set for?
US EST and the location is long/lat of my house.
US EST or US/Eastern?
I'm having a similar problem. Mode manager keeps randomly changing to evening and then night in the middle of the day which then arms my system in the middle of the day and then triggers and intrusion alert. It's getting extremely annoying and I'm lost as to why it is happening. This is a relatively new problem for me (past week or so).
If you set your TimeZone to “EST”, you’ll need to change it to “America/New_York” instead so that it follows typical USA Daylight Savings Time.
Change the timezone as shown in my post to “America/New_York” and see if your sunrise and sunset times adjust accordingly. Yours don’t look correct to me.
I have mine set to US/Eastern and it works correctly.
Look at his sunrise and sunset times. Those don’t make sense at this time of the year. What do yours look like Ryan?
I didn't say that those did....i just said that the timezone of US/Eastern works. EST does not, I agree. But US/Eastern definitely does. He's already said that his location is correct. So...
That's mine. But yes, you are correct. If you're in the US, the place that gets the latest sunset time in the eastern time zone is Marquette michigan and their sunset time is 8:23 right now (They're really part of Wisconsin so they are further west than anywhere else in Eastern. It's very odd in the summer to have it be bright out till 11pm.) So, I agree, those don't make sense. But I would think that's a problem with location, not timezone.
So i changed it to America/New York and updated. I noticed the map wasn't coming through all the way so I added my ZIP code. The map loaded up correctly, and it changed timezone BACK to US/EASTERN but the sunrise/sunset times look better now.
So I was still awake at 3am and it was on day mode. I have evening set 2 start at 9pm... And DAY not starting until 7:30am. I, suppose, my incorrect thinking was that one ends and the next one starts at the next mode time. So last night I changed it to the later of 2 times. 9pm and 6am... Let's see if that does the job tonight. Lol, tired of being up so early to test.
Something else is going on. It should only change at the time you have selected. Take a look at the app's properties window by clicking on the cog wheel. Take a screenshot and post it up here.
After we fixed your location yesterday, did you go back into the app and click done? That is when the next tasks are scheduled for the app. The fixes to your location and timezone won't do anything until the NEXT time that the jobs are scheduled. The properties window will tell use when that is supposed to happen.
Crazy question, but have you rebooted since configuring mode manager?
When I first setup mode manager I had similar issues. Modes not changing, or changing into the wrong modes.
After a reboot it's been flawless for months.
No, I haven't rebooted but will right now.
You said 'until the next time jobs are scheduled'....so my understanding of this is I have designated times I want to say DAY starts here, NIGHT starts here, and EVENING starts here (out of order i know,lol). Independent of other rules, I would expect this to be the case with mode manager. Since I fixed my location, I am seeing Day to Evening, and I even see NIGHT, but way before the DAY mode is supposed to kick in, (2am and such) DAY keeps on BEFORE my designated time.
Yeah...something is wrong with Mode Manager for you. You need to delete it and re-install. You can't do the later of two specific times. That doesn't make any sense. The later of two times or earlier of two times is intended to choose between a specific time and sunset/sunrise. So, if you want day mode to start at 7am or sunrise, whichever is earlier. That would make sense. Starting at the earlier of 6am and 7am doesn't make any sense because 6 am always comes before 7.
I did a quick test and set up mode manager to set day mode at 9am and this is my list of scheduled jobs.
Yours is about 100 times longer. So, I would remove mode manager and re-install it with the correct settings now.
And remember, if you're going to choose the same time every day, you don't have to configure the times by day, you can just enter the one time.
You are also trying to divine what the code is doing. If you have never written an app for hubitat, I would advise against trying to do that. You are most likely going to be wrong and you're just going to confuse yourself more. Just follow the instructions within the app. It doesn't matter how it does it, it matters what it's doing.
None of what is in this properties window looks right to me. It would be best to uninstall and re-install it at this point. Something is VERY wrong.
Me personally, I found it best to change modes based on something other than time, since sunset/sunrise change every day. Yes I am new to using modes (about a month ago) so maybe my opinion is skewed
Sleep to Day via Alexa "Good morning" command where she also turns on some lights (via an HE Scene)
Day to evening at Sunset
Evening to Sleep via Alexa "Good night" command where she also turns off lights (via an HE Scene) and turns on the home security system
Any mode to Away via presence and back again when we return
Everything works like a charm
Good luck, don't give up as the guys and gals here will help you with everything you need
