@bravenel
In Mode and Motion Lighting, is there plans to add the option to use a Hub Variables? I was looking to use variable in one place but had a few more suggestions that could help others since we could use RM to change the variable to True or False which would in turn modify how a ML rule would work based on user's preference.
Options for Turn-on, Disable, and Enable Lights-On Section:
Add option to disable turning on if Variable is True
Options for Additional Sensors, Lights-Off and Off options Section:
Add option here if Variable is true would turn lights off
Add option to disable turning off if Variable is True
