Switch Bindings will do a two-way mirror sync and works for Fan Controllers, in fact I am doing the exact same thing as you for when I was messing around with the User vs System Bond apps.
https://github.com/joelwetzel/Hubitat-Switch-Bindings
Switch Bindings app for Hubitat
An app for Hubitat that binds two (or more) switches/dimmers together. When bound, if either one turns on or off, the binding will make the other one also turn on/off. It will also sync dimmer levels, if any of the devices are dimmers. (It works a lot like a z-wave association, but it happens in the Hubitat hub, so that the hub can know/display the updated device states. Because the Hubitat is local, the bā¦
There is also this Mirror Plus app which IMO I like the UI Better but I think it only does a one-way sync similar to the built in Mirror app.
Fork of Phuc Tran's Device Mirror App that adds a couple additional devices and extra mirroring capabilities for devices that already existed.
Device Mirror Plus
One master [Switch], [Motion Sensor], [Contact Sensor], [Humidity Sensor], [Temperature Sensor], [Battery Level], [Audio] or [Single Button] to control one or more slaves.
Motion Sensor can now mirror - Motion, Temperature, Illuminance, Humidity, Acceleration, Tamper, and Battery
Contact Sensor can now mirror - Contact, Temperaturā¦
