Ok, so I installed the Z-Wave Universal Device Scanner and had the outlet configured with that driver and it brought up a lot more control over the outlet; however, energy was still not being reported and I didn't see it anywhere in the logs.
This was the data:
{"num":1,"format":1,"size":1,"defaultVal":0,"range":"0..3","title":"Reaction of led","description":"Change the reaction of the indicator."},
{"num":2,"format":1,"size":4,"defaultVal":0,"range":"0..65535","title":"Auto Turn Off","description":"Minutes for turn off automatically."},
{"num":3,"format":1,"size":4,"defaultVal":0,"range":"0..65535","title":"Auto Turn On","description":"Minutes for turn on automatically."},
{"num":4,"format":1,"size":1,"defaultVal":0,"range":"0..2","title":"Status Restore","description":"Restore status after power failure."},
{"num":5,"format":1,"size":1,"defaultVal":5,"range":"5..50","title":"Report threshold of power","description":"Threshold for power report(W)."},
{"num":6,"format":1,"size":4,"defaultVal":5,"range":"1..65535","title":"Report frequency of power","description":"Interval minutes after last report of power."},
{"num":7,"format":1,"size":1,"defaultVal":1,"range":"1..10","title":"Report threshold of currents","description":"Threshold for currents report(x0.1A)."},
{"num":8,"format":1,"size":1,"defaultVal":1,"range":"1..100","title":"Report threshold of electricity","description":"Threshold for electricity report(x0.01KWH)."},
{"num":9,"format":1,"size":1,"defaultVal":2,"range":"0..2","title":"Indicator brightness","description":"Setting indicator's brightness."},
{"num":10,"format":1,"size":1,"defaultVal":0,"range":"0..1","title":"Disable power report","description":"Enable or disable power report."},
{"num":11,"format":1,"size":1,"defaultVal":0,"range":"0..1","title":"Disable currents report","description":"Enable or disable currents report."},
{"num":12,"format":1,"size":4,"defaultVal":60,"range":"1..65535","title":"Report frequency of currents","description":"Interval minutes after last report of currents."},
{"num":13,"format":1,"size":4,"defaultVal":60,"range":"0..65535","title":"Report frequency of voltage","description":"Interval minutes after last report of voltage."}
I then tried the Zooz ZEN Plugs Advanced driver, and that reported Energy immediately after I configured the device with that driver. There's less control of the outlet; however, besides the annoying light on the outlet, there's not much else I would change, so I'm ok with using the your Zooz Driver as that get's me what I was hoping for: Energy monitoring.
... also, the Zooz driver has "amperage" populated now as well along with a more accurate reporting for Power. Previously, I was getting an int return value (5), whereas now I get a decimal (5.4). There is an attribute unpopulated that may be unique to Zooz called "energyDuration" which is at 0.
Thank you for your help!
