Min/Max of a group of sensors
Trying to use the Min and Max values of a group of sensors in Rule Machine.
Search got me to this thread: Averaging - #112 by bravenel
Installed the App wrote by @bravenel, Min/Max values are properly calculated and shown in the App itself but their is no Min or Max value in the corresponding child devices.
What did I do wrong?
How can I get the values from the App to the child devices?
Or how can I use the values from the App, in Rule Machine?
Thanks for your input. I'm trying to centralize everything I can in Hubitat. I'll take a look at webCoRE but hope someone will chime in with another solution.
In this app you can assign the Max value into a variable which can be used in Rule Machine. Displays Min in app but cant be assigned to a variable at this time.
Pretty cool app!!! I installed it and will sure find a use for it.
However, it doesn’t seem to do what I want. I have 9 temperature sensors around the house and want to use the differential between the hotter room and colder room in a rule.
I also didn’t find how to link the variables in the app to the Hub variables. I will keep looking for a bit and then post in your thread.
I’m not sure if that is the reason but I rebooted my hub and the app from my first post now works perfectly.
I use this for min / max / avg for temp and humidity sensors.
