Well good grief, what a difference a good night's sleep makes. Looking at another driver I got it sorted out. Everything is working except transition time. I don't believe the MiLight bulbs support it. In any case you can enter a time and it won't crash the driver, it will just disregard it.
I'm not fami
* ESP8266_MiLight_Hub driver
* Controls MiLight bulbs via the ESP8266 MiLight Hub by sidoh (https://github.com/sidoh/esp8266_milight_hub)
metadata {
definition(name: "MiLight Light", namespace: "community", author: "cometfish", importUrl: "https://raw.githubusercontent.com/cometfish/hubitat_driver_esp8266milighthub/master/lightbulbdriver.groovy") {
capability "Actuator"
capability "Bulb"
capability "Switch"
capability "SwitchLevel"
capability "Light"
capability "ColorControl"
capability "ColorTemperature"
attribute "nightMode", "enum", ["on", "off"]
attribute "level", "number"
attribute "colorTemperature", "number"
command "nightMode"
preferences {
section("URIs") {
input "ipAddress", "text", title: "ESP8266 Hub IP Address", required: true
input "hubID", "text", title: "Hub ID (eg. 0xFFFF)", required: true
input "lightID", "text", title: "Light Group ID", required: true
input "lightType", "text", title: "Light Type", required: true
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
def hsvToRGB(float conversionHue = 0, float conversionSaturation = 100, float conversionValue = 100){
// Accepts conversionHue (0-100), conversionSaturation (0-100), and conversionValue (0-100)
// Returns RGB map ([ red: 0-255, green: 0-255, blue: 0-255 ])
// Check HSV limits
conversionHue > 100 ? ( conversionHue = 1 ) : ( conversionHue < 0 ? ( conversionHue = 0 ) : ( conversionHue /= 100 ) )
conversionSaturation > 100 ? ( conversionSaturation = 1 ) : ( conversionSaturation < 0 ? ( conversionSaturation = 0 ) : ( conversionSaturation /= 100 ) )
conversionValue > 100 ? ( conversionValue = 1 ) : ( conversionValue < 0 ? ( conversionValue = 0 ) : ( conversionValue /= 100 ) )
int h = (int)(conversionHue * 6);
float f = conversionHue * 6 - h;
float p = conversionValue * (1 - conversionSaturation);
float q = conversionValue * (1 - f * conversionSaturation);
float t = conversionValue * (1 - (1 - f) * conversionSaturation);
conversionValue *= 255
f *= 255
p *= 255
q *= 255
t *= 255
if (h==0) { rgbMap = [red: conversionValue, green: t, blue: p] }
else if (h==1) { rgbMap = [red: q, green: conversionValue, blue: p] }
else if (h==2) { rgbMap = [red: p, green: conversionValue, blue: t] }
else if (h==3) { rgbMap = [red: p, green: q, blue: conversionValue] }
else if (h==4) { rgbMap = [red: t, green: p, blue: conversionValue] }
else if (h==5) { rgbMap = [red: conversionValue, green: p,blue: q] }
else { rgbMap = [red: 0, green: 0, blue: 0] }
return rgbMap
void setHue(value) {
if (logEnable) log.debug "setHue($value)"
setColor([hue: value, saturation: 100, level: device.currentValue("level")])
void setSaturation(percent) {
if (logEnable) log.debug "setSaturation($percent)"
setColor([saturation: percent, hue: device.currentValue("hue"), level: device.currentValue("level")])
def setColor(value){
if (value.hue == null || value.saturation == null)
return
if (logEnable)
log.warn "setColor"
rgbColors = hsvToRGB(value.hue, value.saturation, value.level)
if (logEnable)
log.debug "hsvToRGB ${rgbColors}"
try {
def url = "http://" + settings.ipAddress + "/gateways/" + settings.hubID + "/" + settings.lightType + "/" + settings.lightID
if (logEnable) log.debug url
def postParams = [
uri: url,
contentType: "application/json",
requestContentType: "application/json",
body : ["status": "on","color":["r":rgbColors['red'],"g":rgbColors['green'],"b":rgbColors['blue']]]
if (logEnable)
log.debug "postParams ${postParams}"
httpPost(postParams) { resp ->
if (resp.success) {
sendEvent(name: "hue", value: value.hue, isStateChange: true)
sendEvent(name: "saturation", value: value.saturation, isStateChange: true)
if (value.level)
sendEvent(name: "level", value: value.level, isStateChange: true)
if (logEnable)
if (resp.data) log.debug "${resp.data}"
} catch (Exception e) {
log.warn "Call to setColor failed: ${e.message}"
def updated() {
log.info "updated..."
log.warn "debug logging is: ${logEnable == true}"
if (logEnable) log.debug(description)
def on() {
if (logEnable) log.debug "Sending on request"
try {
def url = "http://" + settings.ipAddress + "/gateways/" + settings.hubID + "/"+settings.lightType+"/" + settings.lightID
def postParams = [
uri: url,
body : ["status": "on"]
if (resp.success) {
sendEvent(name: "switch", value: "on", isStateChange: true)
sendEvent(name: "nightMode", value: "off", isStateChange: true)
if (logEnable)
log.warn "Call to on failed: ${e.message}"
def off() {
if (logEnable) log.debug "Sending off request"
try {
def postParams = [
uri: url,
body : ["status": "off"]
if (resp.success) {
sendEvent(name: "switch", value: "off", isStateChange: true)
if (logEnable)
log.warn "Call to off failed: ${e.message}"
def nightMode() {
if (logEnable) log.debug "Sending night mode request"
try {
def postParams = [
uri: url,
body : ["command": "night_mode" ]
if (resp.success) {
sendEvent(name: "nightMode", value: "on", isStateChange: true)
if (logEnable)
log.warn "Call to nightmode failed: ${e.message}"
def setLevel(level, tt = null) {
if (logEnable) log.debug "Sending level request"
try {
def postParams = [
uri: url,
body : ["level": level]
if (resp.success) {
sendEvent(name: "level", value: level, isStateChange: true)
if (logEnable)
log.warn "Call to level failed: ${e.message} ${level} "
def setColorTemperature(temp, level = null, tt = null) {
if (logEnable) log.debug "Sending color temperature request"
//limitlessled bulbs range from 3000-6500K, 100 to 0
if (temp<3000)
temp = 3000
else if (temp>6500)
temp = 6500
lltemp = 100 - Math.round(((temp - 3000)/(6500-3000))* 100)
if (logEnable) log.debug lltemp
try {
def postParams = [
uri: url,
body : ["temperature": lltemp]
if (resp.success) {
sendEvent(name: "colorTemperature", value: temp, isStateChange: true)
if (logEnable)
log.warn "Call to colorTemperature failed: ${e.message} ${temp} "
if (level != null) {
setLevel(level)
metadata {
capability "Bulb"
capability "Switch"
capability "Light"
command "nightMode"
preferences {
section("URIs") {
// Check HSV limits
f *= 255
p *= 255
q *= 255
t *= 255
return rgbMap
return
if (logEnable)
log.warn "setColor"
if (logEnable)
try {
def postParams = [
uri: url,
if (logEnable)
if (resp.success) {
if (value.level)
if (logEnable)
def updated() {
def on() {
try {
def postParams = [
uri: url,
if (resp.success) {
if (logEnable)
def off() {
try {
def postParams = [
uri: url,
if (resp.success) {
if (logEnable)
def nightMode() {
try {
def postParams = [
uri: url,
if (resp.success) {
if (logEnable)
try {
def postParams = [
uri: url,
if (resp.success) {
if (logEnable)
if (temp<3000)
temp = 3000
else if (temp>6500)
temp = 6500
try {
def postParams = [
uri: url,
if (resp.success) {
if (logEnable)
setLevel(level)
I just setup git and forked the repo but I'm not sure where to proceed to checkout and edit the files. I have some other priorities today so you may use the above code or I'll work on doing a proper pull later.
