Midea Mini Split Wifi Support
Can you explain the difference between what you described as a "temperature number" and a setpoint? I would have assumed they are the same thing. The way this works is that you can setCoolingSetpoint or setHeatingSetpoint (which are equivalent and set the target temperature for the unit). After that, you can set fan modes and the like.
I see "eco" mode in the component that I referenced, but not "boost". Are they distinct settings, or is "not eco" the same as "boost"? I can add eco as a custom command pretty easily, but I'm not sure what to do with boost.
The fan speed is an interesting one. There are some translations (full = 100, high = 80) that make me wonder if the unit will just accept a % for fan speed for that parameter. If I make a version that includes that will you test it out on your unit?
