I have the Midea U Window Air Conditioner MAW10V1QWT and this driver works perfectly.
However, the implementation required the use of setpoints for the cooling temp, and the unit itself does not really operate this way.
The way it operates is that you select a temperature number, and select cool, dry, fan or auto.
There is a fan speed on a scale of 0%-100%
There is an "eco" and "boost "mode as well (used in conjunction with cool)
I was thinking that I could delete certain lines from the driver code, but I ended up getting lost.
Please can you help?
