Hi guys, thanks in advance for your help. Hiw do understand which zigbee devices are connected directly to my hub and which devices are using repeaters. I'm trying to understand how my mesh works?
It can be really helpful to use an Xbee to visualize/diagnose your ZigBee mesh.
Ah, interesting, so there's no way via hubitat to identify?
http://your.hubitat.ip/hub/zigbee/getChildAndRouteInfo
That won't give you all the information you want necessarily and it's always just a point in time so each time you refresh that endpoint you can get different information. IIRC, if a device is routing through two other devices then you won't see it in the data.
Also on the C8 the child information section is known to be inaccurate.
