MCP Server for Hubitat?
Update to the latest version,it should work fine now. It's due to Claude desktop freaking out about output schemas but my most recent update turned them off by default, and don't forget to close and reopen Claude desktop as well after you do so, so it reloads the tool list.
Also please be aware I'm not getting pinged every time you reply to me, I just now noticed your latest post. The best way to reach me is via my GitHub by posting an issue and/or tagging me
@KingPanther13, question, any special configuration needed that you know of to connect to 2 hubs? I have the original hub connecting. both connections show active in claude, but the second hub (C8) keeps closing immediately.
@kraig109 Over cloud or LAN? Are the hubs connected by the multi-hub thing or are they independent? If it's over cloud and they're sharing the same cloud subscription then that might be your problem, they might need their own cloud subscriptions. If it's over LAN then I'm not sure what your problem would be, I would need more details. If you could please file an issue on the GitHub repo, I only have one hub so I can't really test anything but my main collaborator has two so he might be able to mess around with some things more.
@KingPanther13, I just posted details on your github. I’ve never used it before, but think I did it. cheers! Thanks for the review! It’s in the details, but both on LAN.
Hey, the MCP Server is amazing. Claude now runs my Hubitat. Renamed, grouped all devices, optimized my rule machine rules, writes new rules, etc. I love it!! I asked it to setup a Grafana stack on docker and port all webcore charts to Grafana. It did that all by itself. I then asked to migrate all my webcore rules to rule machines. It did that too.
This is how home automation was always meant to be.
How do you get Claude to do things on Hubitat? I have to copy/paste and go back and forth. How do you get Claude to write rule machine rules?
With this I auto-renamed, sorted 251 devices, had claude create all dashboards, assign all devices to the correct room, setup, configure and integrate grafana charts, created, edited and fixed plenty RM 5.1 rules in about 20 minutes.
This is awesome.
Question for you, I see there is an official MCP now available, do you know how this one differentiates from that?
When I implemented this the community driver was way ahead especially in writing stuff into hubitat.
